LT spice 中的问题 flyback多路输出 vin :16V-35V Vout:24V/6A,26V,12,5V,-1V,-3V 等
Circuit: * C:\Program Files\LTC\LTspiceIV\Draft2.asc
Error on line 27 : l9 0 n041 15 mh
  Unknown parameter "mh"
Unknown node in .ic card: "vcc" -- ignoring
Direct Newton iteration failed to find .op point.  (Use ".option noopiter" to skip.)
Starting Gmin stepping
Gmin = 10
Gmin = 1.07374
vernier = 0.5
vernier = 0.666667
Gmin = 0.326867
vernier = 0.888888
Gmin = 0.055448
vernier = 1
Gmin = 0.006089
Gmin = 0.000653801
Gmin = 7.02013e-005
Gmin = 7.53781e-006
Gmin = 8.09366e-007
Gmin = 8.6905e-008
Gmin = 9.33136e-009
Gmin = 1.00195e-009
Gmin = 1.07583e-010
Gmin = 1.15517e-011
Gmin = 1.24035e-012
Gmin = 1.33182e-013
Gmin = 0
Gmin stepping succeeded in finding the operating point.
Heightened Def Con from 0.0092746 to 0.0092746
Heightened Def Con from 0.0146929 ++++++++++++++++++++++++++++++++++++++++++++++++++Fatal Error: Analysis:  Time step too small; time = 0.0146929, timestep = 1.25047e-017: trouble with bzx84c15l-instance d9
请各位大哥大姐赐教,LT spice出现上面的仿真出错时怎么解决。还有我用UC3842B仿真不出来,后来用LT1243才可以,这是为什么呢,我看了资料说着两个IC差不多。
经过多日的奋斗还是把它仿真出来,仿真效果和实际还是瞒相近的,电路稍微做了点修改,但是S26V 实际中需要加入假负载。实物中用的是UC3843,一些管子也做了修改。
全部回复(1)
scwangpan
楼主您好,我最近也在使用LTSPICE这个模拟软件,想请教下这个软甲的变压器模型怎么做的。另外请问可以上传你这个例子中的变压器模型吗??  承蒙帮助不胜感激!!
