我用3842做了一个单端反激24V/5A,Imax=2.7A,开关管选用IRFPF40,4.3A/900V/Rds=2.5ohm,满载很烫,现在是冬天,问题不大,怕到了夏天会挂掉.改用K2611,9A/900V/Rds=1.3ohm,还是很烫,用手摸感觉温度和以前差不多.对不起大家,这个是小日本的,只是做实验用,大家一定原谅啊!
我觉得有点奇怪,大家以为?还有,输出整流管用16A烫手,3倍裕量还不够吗?
有关MOSFET的温升问题
全部回复(35)
It must be overheat,but I have designed 135W power supply it is not overheat.Because of your mosfet ON-resistance too high---2.5OHM/1.3ohm.Did you calculate on-state heat?I think you can use the mosfet 20N60C3 instead your past used.But you should carefully design the snub circuit,the 20n60c3 VDS break down voltage is 600v ONLY.But it is possible.
@superpowersupply
Itmustbeoverheat,butIhavedesigned135Wpowersupplyitisnotoverheat.BecauseofyourmosfetON-resistancetoohigh---2.5OHM/1.3ohm.Didyoucalculateon-stateheat?Ithinkyoucanusethemosfet20N60C3insteadyourpastused.Butyoushouldcarefullydesignthesnubcircuit,the20n60c3VDSbreakdownvoltageis600vONLY.Butitispossible.
看一下英飞凌的手册,20N60C3的Rds是很小,还是TO220封装.只是使用20A的管子会不会很浪费?谁会提供参考价?
@superpowersupply
20n60c3的VDS break down voltage 不一定是600V 這要看尖峰維持時間,如果小於0.2uS電流小于3A是時 bread down voltage is 700V.請查證
@sunnytong
20n60c3的VDSbreakdownvoltage不一定是600V這要看尖峰維持時間,如果小於0.2uS電流小于3A是時breaddownvoltageis700V.請查證
这个问题不是很大.
1139380842.pdf
1139380842.pdf
