我们目前的A5102可以做到,PDF有发你邮箱,有意后面把BOM过来,大概参数如下:
• High Voltage : Vin and Vout Up to 40V.
• 2A Switch Current
• Buck, Boost or Buck-Boost Operation
• Current Mode PWM with 500KHz Switching Frequency.
• Easy Dimming : Analog, PWM
• Soft Start to Avoid Inrush Current
• Programmable Over Voltage Protection to Limit Output Voltage
• VIN Under voltage Lockout and Thermal Shutdown
