how to translate "贴片电阻, 插件电阻" into english?
全部回复(8)
qaz33510
SMD resistor
Thru-hole (Through-hole) resistor
nullpunkt
chip resistance
plug-in resistance
sunboy13005
SMD resistor &dip resistor
莫等闲
贴片电阻:surface mounted resistor 简称SMD resistor
插件电阻:dip resistor
wllvc
@nullpunkt
chipresistanceplug-inresistance
Perfect!It is the general use!
shaking928
@莫等闲
贴片电阻:surfacemountedresistor简称SMDresistor插件电阻:dipresistor
有DIP(dual inline package)电阻吗,谁看到过?我觉得smd对应的是through hole.
qaz33510
@shaking928
有DIP(dualinlinepackage)电阻吗,谁看到过?我觉得smd对应的是throughhole.
确实是有DIP电阻的,是排阻.
你是对的,Through Hole Components(穿孔插装元件),又称插件.
psdesign
@qaz33510
确实是有DIP电阻的,是排阻.你是对的,ThroughHoleComponents(穿孔插装元件),又称插件.
SMD resistor;
axial resistor;
【深度剖析】如何将LoRaWAN用于物联网设计?
【得捷之选】MAX78000FTHR 图片模型
青龙出海
难以启齿的交流电源整流问题,还是请教一下吧
jmkl128
【西安站】电源网高新电源技术线下研讨会
电源网-天边
简单的PWM式MPPT
百能电器
