请教:开关管导通和截止的英文?
各位大侠,我在看英文资料时,发现个问题,就是在有关开关管的导通和截止时,英文单词弄的我好晕
closed   open这两个哪一个才是开关管的导通和截止呢?
全部回复(14)
qaz33510
比拟一个开关的开(open)和合(close),所以
Open 是关断/截止,Closed 是导通
bingyuwei
@qaz33510
比拟一个开关的开(open)和合(close),所以Open是关断/截止,Closed是导通
我是这样翻译的,可是如果是这样,就和原文的图形刚好相反,我现在不知道到底是我错了,还是图形有错误
bingyuwei
@bingyuwei
我查到closing有截止的意思,那是否意味着open为导通呢
qaz33510
@bingyuwei
应该不是吧,能否贴上你的原文?
bingyuwei
@qaz33510
应该不是吧,能否贴上你的原文?
In this case, the illumination system is designed in such a way that the current discharge interacting with the transformation ratio of the transformer T generates, after the closing of the switch T.sub.Q, a sufficiently high external voltage across the discharge lamp L in order to allow the latter to arc through.
In the case of the forward converter, a current flow through the primary winding W1 is generated initially in a conventional manner, the turns ratio of the transformer T being designed such that the current flow through the primary winding W1 induces an ignition voltage in the secondary winding W2 and thus indirectly across the discharge lamp L. If the switch T.sub.Q is opened by the control device SE, then energy at least in the form of a residual magnetization of the transformer T remains in the secondary circuit S.
qaz33510
@bingyuwei
Inthiscase,theilluminationsystemisdesignedinsuchawaythatthecurrentdischargeinteractingwiththetransformationratioofthetransformerTgenerates,aftertheclosingoftheswitchT.sub.Q,asufficientlyhighexternalvoltageacrossthedischargelampLinordertoallowthelattertoarcthrough.Inthecaseoftheforwardconverter,acurrentflowthroughtheprimarywindingW1isgeneratedinitiallyinaconventionalmanner,theturnsratioofthetransformerTbeingdesignedsuchthatthecurrentflowthroughtheprimarywindingW1inducesanignitionvoltageinthesecondarywindingW2andthusindirectlyacrossthedischargelampL.IftheswitchT.sub.QisopenedbythecontroldeviceSE,thenenergyatleastintheformofaresidualmagnetizationofthetransformerTremainsinthesecondarycircuitS.
就凭最后一句 - If the switch T.sub.Q is opened by the control device SE, then energy at least in the form of a residual magnetization of the transformer T remains in the secondary circuit S. 可知 open  是关断.
roger8066
open= off, closed = on, is it?
qaz33510
@roger8066
open=off,closed=on,isit?
Bingo
@qaz33510
如qaz33510 所述, 文中的OPEN/CLOSE只是表示开关的开与合.
虽然它们分别与开关管的截止/导通对应,但做为技术翻译, 能不混用最好.
截止似乎有两种说法:cut-off, cut-in;
导通似乎有两种说法:conductive, on.
fync_wsb
@roger8066
支持这种说法.open和colse一般指开关的断开和闭合两种状态,而不关心开关是机械式,还是电子式.
而用二极管、三极管、mos管等,一般用导通(on)和截止(off)表示其工作状态,管子导通表示开关闭合(close),管子截止表示开关断开(open).
axxiao
@fync_wsb
支持这种说法.open和colse一般指开关的断开和闭合两种状态,而不关心开关是机械式,还是电子式.而用二极管、三极管、mos管等,一般用导通(on)和截止(off)表示其工作状态,管子导通表示开关闭合(close),管子截止表示开关断开(open).
switch on/switch off
axxiao
@axxiao
switchon/switchoff
slide to on/off position
wlswdbb
Q1 is TURNED ON as soon as Q2 is TURNED OFF.
Q2一截止Q1马上开通.
At time t1, Q1 is on and Q2 is off.
在时间t1,Q1是导通的Q2是截止的.
表示状态和表示动作的表达式不一样的.
bingyuwei
@fync_wsb
谢谢,我现在已经不从事原来的工作了,很久没上来这个论坛了,还有这么多人回复我的帖子,真的是太感谢了
