![](http://u.dianyuan.com/bbs/u/37/1137592555.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/37/1137592555.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
电路如上,如果照原图的话, 将R1或R2直接短路会烧坏PCB,对此,我们在N极有加一个保险管,以保护R1或R2短路时PCB不会被烧坏,而烧断保险管.
可是图中R1,R2是2W,实际工作中很难让它们的两个脚短路呀,为何安规方面会做这种测试要求.还请各位老师指点一下了.
