用PIC16C84的修正正弦波2kva逆变器(国外)技术资料
有兴趣的做做看
全部回复(3)
qianyibo
*******************主程序*******************
;* INVERT7.ASM   PIC PWM DC->AC Inverter Controller
;*         Generates 60Hz PWM waveform for primary of inverter Xfrm
;*         Begins at 0.5 max. width and uses ADC to sample average
;*         AC output voltage.  Also controls main power relays and
;*         corrects load power factor
;* M. Csele  original version: 96/12/04  version 7: 98/12
;* Hardware: Adapted for PIC Applications PCB with on-board ADC0831
;*           RA0 = ADC DATA Line
;*           RA1 = ADC CLK Line
;*           RA2 = ADC CS Line
;*           RA3 = Alarm Beeper Output
;*                 (Used to announce startup and shutdown)
;*           RA4 = [FUTURE OPTION] Shutdown Input (Active Low)
;*           RB0 = [FUTURE OPTION] Serial Receive/Transmit
;*           RB1 = Power Factor Correction capacitor relay
;*                 (Switches in PF capacitor above 500VA load)
;*           RB2 = Error LED Output
;*                 (Error code when shutdown due to fault)
;*           RB3 = OverLoad LED Output
;*                 (Fast Blink = permissive overload)
;*                 (Constant   = Vout < 115V at max pulse width)
;*                 (Slow Blink = shutdown after 6 secs of overload)
;*           RB4 = PWM Change Status LED Output
;*                 (Lights when PW changing due to voltage error > 2)
;*           RB5 = Main driver bank Relay ON Output
;*                 (Controls main power relays for xfmrs)
;*           RB6 = Phase 2 Output to driver transistors (ACTIVE LOW)
;*           RB7 = Phase 1 Output to driver transistors (ACTIVE LOW)
        LIST    p=16C84       ;PIC16C84 is the target processor
        INCLUDE "P16C84.INC"  ;Include file with register defines
;Register Defines
Temp       equ    2F       ;temp storage during misc functions
ADCresult  equ    2E       ;stores ADC reading
ADCCtr     equ    2D       ;stores count for reading 8 bits from serial ADC
PulseWidth equ    2C       ;Width of var. part of pulse in 10uS increments
Timer      equ    2B       ;Used as a count-down timer
ErrorValue    equ   2A
ErrorTimerLo  equ   29
ErrorTimerHi  equ   28
LedBlinkTimer equ   27     ;Used for blinking LED during max. load
;PORT A Defines
ADCCLK    equ    1
ADCDAT    equ    0
ADCCS     equ    2
BEEP      equ    3
;PORT B Defines
PHASE1    equ    7
PHASE2    equ    6
PWRRELAY  equ    5
LEDPWM    equ    4
LEDOVERLD equ    3
LEDERROR  equ    2
PFCRELAY  equ    1
Main
        movlw   b'00000001'   ;Port B all outputs except unused RB0
        tris    PORTB
        movlw   b'11000000'   ;All Outputs LOW except drivers OFF (high)
        movwf   PORTB
        movlw   b'00010001'   ;Port A all inputs except RA4 and RA0 (DATA)
        tris    PORTA
        movlw   b'00000000'   ;All Outputs LOW
        movwf   PORTA
        movlw   .0          ;Initialize Pulse Width to 0.5 Max. (Min)
        movwf   PulseWidth
        movlw   b'10000110'   ;Set timer 0 to overflow at 240Hz.  7200Hz in =
                              ;Internal clock, Divide by 128 prescaler
        bsf     STATUS,RP0    ;select Page 1
        movwf   OPTION_REG
        bcf     STATUS,RP0    ;select Page 0
        clrwdt
        movlw   .226          ;Initialize timer for 240Hz overflow
        movwf   TMR0
        bsf     PORTA,BEEP    ;Beep for 1 second
        movlw   .240          ;1 second delay using timer
        movwf   Timer
NextDly
        call    WaitForTmr
        decfsz  Timer,f
        goto    NextDly
        bcf     PORTA,BEEP
        bsf     PORTB,PHASE1   ;Turn Phases OFF
        bsf     PORTB,PHASE2
        bsf     PORTB,PWRRELAY ;Main Power Relay ON
        bcf     PORTB,PFCRELAY ;Power Factor Correction OFF
        ;Starting Value: Minimum pulse width
        movlw   .1
        movwf   PulseWidth
;** Inverter main loop: Generate 60Hz PWMed Sine Wave and check system
MainLoop
        ;Phase A half-cycle output
        ;Generate fixed width pulse of 1/240th sec.
        bcf     PORTB,PHASE1  ;Phase A ON (active low)
        ;During Phase A fixed delay, check output voltage and adjust
        ;Pulse Width Accordingly for the next cycle
        call    ReadADC
        call    AdjustPulseWidth
        call    WaitForTmr    ;Wait for 1/240th second to elapse
        ;Generate variable width pulse of 0 to 1/240th sec
        movfw   PulseWidth
        movwf   Timer
NextPhaseADly
        call    Delay10uS     ;Generate from 1 to 255 10uS delays
        decfsz  Timer,f
        goto    NextPhaseADly
        bsf     PORTB,PHASE1  ;Phase A OFF
        call    WaitForTmr    ;Wait for rest of 1/240th sec period
        ;Phase B half-cycle output
        bcf     PORTB,PHASE2  ;Phase B ON (active low)
        movfw   PulseWidth
        movwf   Timer
NextPhaseBDly
        decfsz  Timer,f
        goto    NextPhaseBDly
        bsf     PORTB,PHASE2  ;Phase B OFF
        goto    MainLoop
@qianyibo
*******************主程序*******************;*******************************************************************;*INVERT7.ASM  PICPWMDC->ACInverterController;*        Generates60HzPWMwaveformforprimaryofinverterXfrm;*        Beginsat0.5max.widthandusesADCtosampleaverage;*        ACoutputvoltage.  Alsocontrolsmainpowerrelaysand;*        correctsloadpowerfactor;*;*M.Csele  originalversion:96/12/04  version7:98/12  ;*;*Hardware:AdaptedforPICApplicationsPCBwithon-boardADC0831;*;*          RA0=ADCDATALine;*          RA1=ADCCLKLine;*          RA2=ADCCSLine;*          RA3=AlarmBeeperOutput;*                (Usedtoannouncestartupandshutdown)  ;*          RA4=[FUTUREOPTION]ShutdownInput(ActiveLow)  ;*;*          RB0=[FUTUREOPTION]SerialReceive/Transmit;*          RB1=PowerFactorCorrectioncapacitorrelay;*                (SwitchesinPFcapacitorabove500VAload);*          RB2=ErrorLEDOutput;*                (Errorcodewhenshutdownduetofault);*          RB3=OverLoadLEDOutput;*                (FastBlink=permissiveoverload);*                (Constant  =Vout<115Vatmaxpulsewidth);*                (SlowBlink=shutdownafter6secsofoverload);*          RB4=PWMChangeStatusLEDOutput;*                (LightswhenPWchangingduetovoltageerror>2);*          RB5=MaindriverbankRelayONOutput;*                (Controlsmainpowerrelaysforxfmrs)    ;*          RB6=Phase2Outputtodrivertransistors(ACTIVELOW);*          RB7=Phase1Outputtodrivertransistors(ACTIVELOW);*******************************************************************        LIST    p=16C84      ;PIC16C84isthetargetprocessor        INCLUDE"P16C84.INC"  ;Includefilewithregisterdefines;RegisterDefinesTemp      equ    2F      ;tempstorageduringmiscfunctionsADCresult  equ    2E      ;storesADCreadingADCCtr    equ    2D      ;storescountforreading8bitsfromserialADCPulseWidthequ    2C      ;Widthofvar.partofpulsein10uSincrementsTimer      equ    2B      ;Usedasacount-downtimerErrorValue    equ  2AErrorTimerLo  equ  29ErrorTimerHi  equ  28LedBlinkTimerequ  27    ;UsedforblinkingLEDduringmax.load    ;PORTADefinesADCCLK    equ    1ADCDAT    equ    0ADCCS    equ    2BEEP      equ    3;PORTBDefinesPHASE1    equ    7PHASE2    equ    6PWRRELAY  equ    5LEDPWM    equ    4LEDOVERLDequ    3LEDERROR  equ    2PFCRELAY  equ    1Main        movlw  b'00000001'  ;PortBalloutputsexceptunusedRB0        tris    PORTB        movlw  b'11000000'  ;AllOutputsLOWexceptdriversOFF(high)        movwf  PORTB        movlw  b'00010001'  ;PortAallinputsexceptRA4andRA0(DATA)        tris    PORTA        movlw  b'00000000'  ;AllOutputsLOW        movwf  PORTA        movlw  .0          ;InitializePulseWidthto0.5Max.(Min)        movwf  PulseWidth        movlw  b'10000110'  ;Settimer0tooverflowat240Hz.  7200Hzin=                              ;Internalclock,Divideby128prescaler        bsf    STATUS,RP0    ;selectPage1        movwf  OPTION_REG        bcf    STATUS,RP0    ;selectPage0        clrwdt        movlw  .226          ;Initializetimerfor240Hzoverflow        movwf  TMR0        bsf    PORTA,BEEP    ;Beepfor1second        movlw  .240          ;1seconddelayusingtimer        movwf  TimerNextDly        call    WaitForTmr        decfsz  Timer,f        goto    NextDly        bcf    PORTA,BEEP        bsf    PORTB,PHASE1  ;TurnPhasesOFF        bsf    PORTB,PHASE2        bsf    PORTB,PWRRELAY;MainPowerRelayON        bcf    PORTB,PFCRELAY;PowerFactorCorrectionOFF                ;StartingValue:Minimumpulsewidth        movlw  .1        movwf  PulseWidth;**Invertermainloop:Generate60HzPWMedSineWaveandchecksystemMainLoop        ;PhaseAhalf-cycleoutput        ;Generatefixedwidthpulseof1/240thsec.        bcf    PORTB,PHASE1  ;PhaseAON(activelow)        ;DuringPhaseAfixeddelay,checkoutputvoltageandadjust        ;PulseWidthAccordinglyforthenextcycle        call    ReadADC        call    AdjustPulseWidth        call    WaitForTmr    ;Waitfor1/240thsecondtoelapse        ;Generatevariablewidthpulseof0to1/240thsec        movfw  PulseWidth        movwf  TimerNextPhaseADly        call    Delay10uS    ;Generatefrom1to25510uSdelays        decfsz  Timer,f        goto    NextPhaseADly            bsf    PORTB,PHASE1  ;PhaseAOFF        call    WaitForTmr    ;Waitforrestof1/240thsecperiod        ;PhaseBhalf-cycleoutput        ;Generatefixedwidthpulseof1/240thsec.        bcf    PORTB,PHASE2  ;PhaseBON(activelow)        call    WaitForTmr    ;Waitfor1/240thsecondtoelapse        ;Generatevariablewidthpulseof0to1/240thsec        movfw  PulseWidth        movwf  TimerNextPhaseBDly        call    Delay10uS    ;Generatefrom1to25510uSdelays        decfsz  Timer,f        goto    NextPhaseBDly            bsf    PORTB,PHASE2  ;PhaseBOFF        call    WaitForTmr    ;Waitforrestof1/240thsecperiod        goto    MainLoop
太麻烦了,我觉得用带AD的单片机来设计更简单,更重要是可以节省银子.
qghqgh
@heromeethero
dddddd
