请帮忙分析原理
高手帮忙分析一下RCC电路原理
全部回复(37)
@aanali
C2/R3/R5参数如何确定,C2/R3作用是什么。
RCC变压器参数计算
输入交流:100V-240V
输出:5V 0.35A
电源效率设定:66%
频率设定:80KHz
占空比设定:0.45
最小输入直流电压:VinDC(min)=100*1.2=120V
最大输入直流电压:VinDC(MAX)=240*1.4=336v
最大输出功率:Po=5V*0.35A*1.2=2.1W
输入平均电流:Ipv=(Po/η)/VinDC(min)
=3.182/120
=0.0265A
开关周期:T=1/Fosc=1/80K=12.5uS
开关导通时间:Ton=D*T=0.45*12.5uS=5.625uS
原边峰值电流:Ipk=2*Ipv/D=2*0.0265/0.45=0.118A
初级电感:Lp=VinDC(min)*Ton/Ipk
=120*5.625/0.118
=5.72mH
根据功率大小选择磁芯:EE13 Ae=17mm2
磁通密度:△B=2000GS
初级绕组匝数:Np=VinDC(min)*Ton/(Ae*△B)
=120*5.625/(17*0.2)
=675/3.4
=198Ts
反射电压:Vor=D*VinDC(min)/(1-D)
=98V
初次级匝比:N=Vor/(Vo+Vf)
=98/(5+0.7)
=17.2
次级绕组匝数:Ns=Np/N=98/17.2=6Ts
辅助供电绕组:Na=(VCC+Vf1)*Np/VinDC(min)
=(9+1)*198/120
=17Ts
输入交流:100V-240V
输出:5V 0.35A
电源效率设定:66%
频率设定:80KHz
占空比设定:0.45
=3.182/120
=0.0265A
=120*5.625/0.118
=5.72mH
磁通密度:△B=2000GS
=120*5.625/(17*0.2)
=675/3.4
=198Ts
=98V
初次级匝比:N=Vor/(Vo+Vf)
=98/(5+0.7)
=17.2
=(9+1)*198/120
=17Ts
@aanali
RCC变压器参数计算输入交流:100V-240V输出:5V0.35A电源效率设定:66%频率设定:80KHz占空比设定:0.45=========================================最小输入直流电压:VinDC(min)=100*1.2=120V最大输入直流电压:VinDC(MAX)=240*1.4=336v最大输出功率:Po=5V*0.35A*1.2=2.1W输入平均电流:Ipv=(Po/η)/VinDC(min) =3.182/120 =0.0265A开关周期:T=1/Fosc=1/80K=12.5uS开关导通时间:Ton=D*T=0.45*12.5uS=5.625uS原边峰值电流:Ipk=2*Ipv/D=2*0.0265/0.45=0.118A初级电感:Lp=VinDC(min)*Ton/Ipk =120*5.625/0.118 =5.72mH根据功率大小选择磁芯:EE13Ae=17mm2磁通密度:△B=2000GS初级绕组匝数:Np=VinDC(min)*Ton/(Ae*△B) =120*5.625/(17*0.2) =675/3.4 =198Ts反射电压:Vor=D*VinDC(min)/(1-D) =98V初次级匝比:N=Vor/(Vo+Vf) =98/(5+0.7) =17.2次级绕组匝数:Ns=Np/N=98/17.2=6Ts辅助供电绕组:Na=(VCC+Vf1)*Np/VinDC(min) =(9+1)*198/120 =17Ts=========================================
受教!排长!
@aanali
能否帮我设计一下变压器参数
输入电压:200~240V AC
输出: 19V 210mA
电源效率:70%
频率设定:60K
占空比设定;0.45
