Features
Input voltage: 4.2V to 40V. Output voltage: 0.8V to V .
IN Duty ratio: 0% to 100% PWM control Oscillation frequency: 150KHz typ. Soft-start, Current limit, Enable function Thermal Shutdown function Built-in internal P-channel MOS SOP-8P Package.
YF1210 电流2.1A,非同步降压IC
输入电压
4.2-40V,输出ADJ,电流2.1A,非同步降压,我司还有FP6180,FP6112,应用于车充DVB;PDVD便携式播放设备电子书,MID;
