東陽科技集團主推ATMEL(愛特梅爾),ST-ERICSSON 品牌全系列的晶片應用!憑藉優勢的現貨庫存,持續穩定供貨,為廣大客戶提供進口全新原裝正品,並贏得行業內外的信賴和好評。產品廣泛應用於儀錶儀器,安防,門禁,通訊網絡…USB 芯片接口;另經營NXP(PHILIPS) ,INFINEON, ST,IR ,ATMEL等知名品牌半导体 。
我司一直堅守客戶至上,互惠互利的經營理念,堅持誠實守信的商業原則,竭誠為客戶提供多元服務,並期待與您真誠合作,共謀發展!
強力推薦,優勢庫存:
ATMEL
AVR系列
ATMEGA8L-8AU; ATMEGA48V-10AU;
ATMEGA88V-10MU ; ATMEGA169PV-8AU
ATTINY13A-SU ; ATTINY26-16SU; ATTINY48-AU,ATMEGA88PA-MU
串列EEPROM系列
AT24C01/01A/02/04/08/16/32/64/128/256/512/1024
ST-ERICSSON
USB Commercial:
PDIUSBD12PW ISP1161A1BDTM ISP1181BBSUM
ISP1568AETUM ISP1760ETUM ISP1761BEGE
*NXP(PHILIPS)半導體系列照明驅動晶片
UBA2014T(P): 600 V driver IC for HF fluorescent lamps 螢光燈可調光電子鎮流器
UBA2021T(P): Half-bridge power IC for CFL lamps 節能燈驅動IC
UBA2024P/T : Half-bridge power IC for CFL lamps 內置MOS節能燈驅動IC
UBA2028T :600V dimmable power IC for Compact Fluorescent Lamps內置MOS調光IC
UBA2030T : Full bridge driver IC for HID全橋驅動
UBA2032T(TS): Full bridge driver IC for HID全橋驅動
UBA2033TS : Full bridge driver IC for HID全橋驅動
UBA2035TS : HF Full-bridge control IC for HID lighting 商用全橋驅動
UBA2036TS : Full-bridge control IC for HID automotive lighting 高級車用全橋驅動
UBA2037T(TS) : Full-bridge control IC for HID automotive lighting 全橋驅動
UBA2070T(P) : 600 V CCFL ballast driver IC for CCFL backlighting LCD 背光驅動
UBA2071T(TS) : Full bridge control IC for. CCFL backlighting LCD 背光驅動
UBA2072T(TS) : Full bridge control IC for. CCFL backlighting LCD 背光驅動!
SSL2101:SMPS IC for dimmable LED lighting LED可調光開關模式電源控制晶片
SSL2102:Mains LED driver IC for dimmable LED lighting LED調光驅動晶片
*NXP(PHILIPS)半導體系列快恢復二極體
BYC8-600 : Rectifier diode ultrafast, 超快恢復19ns,8A/600V TO220
BYC8X-600 : Rectifier diode ultrafast, 超快恢復19ns,8A/600V TO220F
BYC10X-600 : Rectifier diode ultrafast, 超快恢復19ns,10A/600V TO220F
BYV29X-600 : Rectifier diode ultrafast, 超快恢復55ns,9A/600V TO220F
BYT79-600: Rectifier diode ultrafast, 超快恢復60ns,16A/600V TO220
BYV34-500:Rectifier diode ultrafast, 超快恢復 60ns,20A/500V TO220
BYQ28E-200:Rectifier diode ultrafast, 超快恢復 25ns,10A/200V TO220
BYQ28X-200:Rectifier diode ultrafast, 超快恢復 25ns,10A/200V TO220F
BYW29E-200: Rectifier diode ultrafast, 超快恢復 25ns,8A/200V TO220
BYQ30E-200:Rectifier diode ultrafast, 超快恢復 25ns,15A/200V TO220
BYV72EW-200:Rectifier diode ultrafast, 超快恢復 28ns,30A/200V TO247
*NXP(PHILIPS)半導體MOSFET:
PSMN010-55D : 75A 55V 10.5Mohm 125W TO252 , 電源MOSFET
PSMN015-100B :75A 100V 15Mohm 300W D2PAK(TO263) ,電源 MOSFET
PSMN015-100P :75A 100V 15Mohm 300W TO220 , 電源MOSFET
PSMN015-110P :75A 110V 15Mohm 300W TO220 , 電源MOSFET
PSMN009-100P :75A 100V 9Mohm 300W TO220 ,電源 MOSFET
PHP45NQ10T : 47A 100V 25Mohm 150W TO220 ,電源MOSFET
*NXP(PHILIPS)其他主推產品:
TDA1308T:Class AB stereo headphone driver 耳機專用功放晶片 SOP8
UDA1330ATS:Low-cost stereo filter DAC多媒體音頻數位/類比轉換器 SSOP16
UDA1341TS:Low-cost stereo filter DAC多媒體音頻數位/類比轉換器 SSOP28
PDIUSBD12D:USB interface device with parallel bus USB介面晶片 SOP28
PDIUSBD12PW:USB interface device with parallel bus USB介面晶片 SSOP28
TDA8920CTH: IC CLASS-D POWER AMP;2X100W /D類功放晶片,2X110W HSOP24
*INFINEON半導體COOLMOS:
SPD03N60C3: COOLMOS 3.2A 600V 1.4ohm 38W DPAK(TO252)
SPP03N60C3: COOLMOS 3.2A 600V 1.4ohm 38W TO220
SPD04N60C3:COOLMOS 4.5A 600V 0.95ohm 50W DPAK(TO252)
SPP04N80C3: COOLMOS 4A 800V 1.3ohm 63W TO220
SPP06N80C3:COOLMOS 6A 800V 0.9ohm 83W TO220
SPA06N80C3: COOLMOS 6A 800V 0.9ohm 39W TO220F
SPD07N60C3:COOLMOS 7.3A 600V 0.6ohm 83W DPAK(TO252)
SPP07N60C3:COOLMOS 7.3A 600V 0.6ohm 83W TO220
SPA07N60C3:COOLMOS 7.3A 600V 0.6ohm 32W TO220F
SPA08N80C3: COOLMOS 8A 800V 0.65ohm 40W TO220F
SPP11N60C3:COOLMOS 11A 600V 0.38ohm 120W TO220
SPA11N60C3:COOLMOS 11A 600V 0.38ohm 33W TO220
SPP11N80C3: COOLMOS 11A 800V 0.45ohm 156W TO220
SPW11N80C3: COOLMOS 11A 800V 0.45ohm 156W TO247
SPP17N80C3: COOLMOS 17A 800V 0.29ohm 208W TO220
SPW17N80C3: COOLMOS 17A 800V 0.29ohm 208W TO247
SPP20N60C3:COOLMOS 20.7A 600V 0.19ohm 208W TO220
SPA20N60C3:COOLMOS 20.7A 600V 0.19ohm 34.5W TO220F
SPP21N50C3:COOLMOS 21A 500V 0.19ohm 208W TO220
SPW20N60C3:COOLMOS 20.7A 600V 0.19ohm 208W TO247
SPW24N60C3:COOLMOS 24.3A 600V 0.16ohm 240W TO247
SPW35N60C3:COOLMOS 34.6A 600V 0.1ohm 313W TO247
SPW47N60C3:COOLMOS 47A 600V 0.07ohm 415W TO247
英飛淩半導體其他主推產品:
ICB1FL02/03G : 螢光燈,高性能電子鎮流器控制晶片 SOP18
ICB2FL01/02G :可調光智慧螢光燈控制器 SOP19
TDA4863-2/2G :PFC 功率因數校正積體電路 DIP8/SOP8
ICE2PCS01/02G :PFC功率因數校正積體電路 DIP/SOP8
ICE3B0565/J:COOLSET;小功率充電器,LED;DVB電源應用 12W-25W DIP8
ICE3B0365/J:COOLSET;小功率充電器,LED;DVB電源應用 10W-22W DIP8
TDK5110(F):汽車胎壓檢測項目,發射積體電路TSSOP10/TSSOP16
*STM意法半導體:
L6561/D : PFC 功率因數校正積體電路 DIP8/ SOP8
L6562/D: PFC 功率因數校正積體電路 DIP8/SOP8
L6574/D : 電子鎮流器控制驅動積體電路 DIP16/SOP16
TDA7297SA:10W+10W DUAL BRIDGE AMPLIFIER 音頻功率放大器
*ADI模擬器件公司:
ADXRS401ABG : 角速度轉感器 航模產品專用
ADXRS610BBGZ: 角速度轉感器 航模產品專用
*其他產品:
6N139: 高倍率達靈頓光藕合IC DIP8 (FSC)
ATMEGA88V-10MU:單片機 MFL-32 (ATMEL)
