Looks like, this is a switching power supply, the "bad" frequency" from your pic are 160K, 320K and around 640K. They're narrow Band. I guess your primary switching freq is around 80K or 160K. Thus, you need to improve your primary design to kill this low freq spur. Without Schematic, I don't know how to improve it.As far as the 8MHz, it is wide band, try to use a larger common choke at AC input side, and see if it works.
