求助:关于DSP的C语言编程问题
本人近来用C语言开发一个液晶显示的小项目.程序编译后下载成功,液晶显示也正确.不过我想把程序烧到flash中却出现问题.程序下到最后阶段提示下面的错误
Can't Set Breakpoint: Error 0x00000008/-1076 Error during: Break Point,  Cannot set/verify breakpoint at 0x0000141F Breakpoint Manager: An error was encountered attempting to set a breakpoint used
for end of program detection.
用的是2407DSP.我试了一下以前编的汇编程序,发现能烧到flash中.第一次用c语言开发DSP,想尽办法也不能解决这一问题,还请各位高手不吝赐教,小弟在此感激不尽.
全部回复(2)
我也遇到这个问题啊,谁知道请提携一把,大谢!
yu_jsh
@一苇渡江
是变量未初始化造成的.const类型,CONST_COPY .set 1.
注意看TI的帮助文档.DSP是代码、数据分离的,上电时候必须把常数copy到RAM区域.
*  boot   v7.01
*  Copyright (c) 1988-1996 Texas Instruments Inc.
*   This module contains the following definitions :
*         __stack    - Stack memory area
*         _c_int0    - Boot function
*         _var_init  - Function which processes initialization tables
.global  _c_int0, cinit
.global  _main, _abort
.global .bss, end
* FOR C50, DEFINE ADDRESSES OF MEMORY MAPPED REGISTERS
.if .tms32050
.mmregs
.endif
* CONST COPY OPTION
* If your system cannot support allocating an initialized section to data
* memory, and you want the boot routine to copy .const from program to
* data memory, then set this CONST_COPY variable to 1
* Note the code that does the copy depends on you having the following
* in your linker command file
* MEMORY
*   PAGE 0 : PROG : ... /* 'PROG' AND 'DATA' ARE EXAMPLE NAMES */
*   PAGE 1 : DATA : ...
* SECTIONS
*   .const : load = PROG PAGE 0, run = DATA PAGE 1
*      __const_run = .;
*      *(.c_mark)
*      *(.const)
*      __const_length = . - __const_run;
CONST_COPY .set 1
* FOR CONST COPY, DEFINE THE LOAD ADDRESS OF THE .const SECTION
* DEPENDS ON LINKER COMMAND FILE BEING WRITTEN AS ABOVE
.if CONST_COPY
.sect ".c_mark"
.label __const_load
.global __const_run, __const_length
.text
.endif ; CONST_COPY
* C50 ONLY.  ZERO THE WAIT STATES.  IF YOUR SYSTEM USES A C5x AND SUPPORTS
* ZERO WAIT STATES, CHANGE THIS FLAG TO 1
ZERO_WAIT_STATES .set 0
* DECLARE THE STACK.  SIZE IS DETERMINED BY THE LINKER OPTION -stack
__stack: .usect ".stack",0
* FUNCTION DEF : _c_int0
*   1) Set up stack
*   2) Set up proper status
*   3) If "cinit" is not -1, init global variables
*   4) call users' program
_c_int0:
*  SET UP INITIAL STACK AND FRAME POINTERS
LRLK    AR0,__stack ; set up frame pointer
LRLK    AR1,__stack ; set up stack pointer
* INITIALIZE STATUS BIT FIELDS *NOT* INITIALIZED AT RESET
ROVM ; turn off overflow mode
* INITIALIZE STATUS BIT FIELDS WHICH ARE SET TO THESE SAME VALUES BY RESET.
* IF YOU RUN THIS ROUTINE FROM RESET, YOU CAN COMMENT OUT THIS CODE.
SPM     0 ; product shift count of zero
.if .tms32050
LDPK 0 ; access memory mapped regs
APL #0fff9h,PMST ; set NDX = 0 and TRM = 0
.endif
SSXM ; set SXM=1 for LALK cinit
* ON THE C50, OPTIONALLY ZERO THE WAIT STATE REGISTER
.if ZERO_WAIT_STATES & .tms32050
LDPK 0
SPLK #0,PDWSR
.endif
*  IF cinit IS NOT -1, PROCESS INITIALIZATION TABLES
LALK    cinit ; get pointer to init tables
ADDK    1
BZ      skip ; if (cinit == -1)
CALL    _var_init,AR1 ; var_init()
*  CALL USER'S PROGRAM
skip:
.if CONST_COPY
CALL const_copy
.endif
CALL    _main,AR1
CALL    _abort,AR1 ; to never return...
.page
* FUNCTION DEF : _var_init
*  PROCESS INITIALIZATION TABLES.  TABLES ARE IN
*  PROGRAM MEMORY IN THE FOLLOWING FORMAT :
*       .word
*       .word
*       .word
*       .word  ...
*  The init table is terminated with a zero length
_var_init:
* C2x/C2xx VERSION
.if .tms32025 | .tms3202xx
        ADRK    2 ; allocate two words of local memory
        LALK    cinit ; load accumulator with base of table
LARP    AR0
*  READ INIT RECORD HEADER
*  AN INIT RECORD WITH A ZERO LENGTH TERMINATES LIST
loop:
TBLR    *+ ; read length
ADDK    1
TBLR    * ; read address
LAR     AR2,*- ; load variable address into ar2
LAR     AR3,*,AR3 ; load count into ar3
BANZ    copy,*-,AR2 ; check for end of table
*  AT END OF LIST, RETURN TO CALLER
        LARP    AR1
SBRK    2 ; deallocate locals
RET ; return to _c_int0
*  PERFORM THE COPY OF DATA FROM PROGRAM TO DATA
copy:
ADDK    1 ; increment pointer to data
TBLR    *+,AR3 ; copy data from program to variable
BANZ    copy,*-,AR2 ; until count is zero
ADDK    1 ; point to beginning of next record
B       loop,AR0 ; go process next record
.endif ; .tms32025 | .tms3202xx
* C5x VERSION
.if .tms32050
LDPK 0 ; set page to 0 for AR2 ==> BRCR
loop:
TBLR * ; read length
ADDK 1
LAR AR2,*,AR2 ; into AR2
BANZ continue,*-,AR1 ; continue if not zero, decrement
RET
continue:
LMMR BRCR,AR2 ; BRCR = AR2 = length - 1
TBLR *
ADDK 1
LAR AR2,*,AR2 ; AR2  = address
RPTB copy - 1
TBLR *+
ADDK 1
NOP
copy:
B       loop,AR1 ; go process next record
.endif ; .tms32050
.page
* CONST COPY ROUTINE - COPIES THE .const SECTION FROM PROGRAM TO DATA MEMORY
.if CONST_COPY
const_copy:
* C2x/C2xx VERSION - CAN'T USE RPT.  COUNTER IS ONLY 8-BITS WIDE
LARP AR3
LRLK AR3,#__const_length ; AR3 = length of section
BANZ cont,*-,AR2 ; Check for zero and decrement
B quit ; if (zero) quit
cont:
LRLK AR2,#__const_run ; AR2 = const address in data
LALK #__const_load ; ACC = const address in program
cloop:
TBLR *+,AR3 ; copy from program to data
ADDK 1 ; increment program address
BANZ cloop,*-,AR2 ; check for zero and decrement
quit:
LARP AR1 ; restore ARP to SP
RET ; return
* C5x VERSION - USES RPTK
.if .tms32050
LALK #__const_length ; load length of const section
BZ quit ; if 0, quit
LARP AR2
RPT #__const_length-1 ; repeat length times
BLKP #__const_load,*+ ; block copy from program
quit:
RET ; return
.endif ; .tms32050
.endif ; CONST_COPY
.end
