线艺电感供应商
[产品介绍]:线艺(coilcraft)电感在全球处于领先地位,高频绕线电感占全球70%市场占有率。对coilcraft电感感兴趣的朋友,我将为您提供最新产品咨询和技术解决服务。
六大理由选购线艺电子产品:
1. 标准品均有库存;
2.最小包装订购量
3.最短交货期
4.最小误差值
5.所有产品符合ROHS
6.工程支援销售和生产地:*唯一在三大洲(亚洲、欧洲和北美)八个工厂都有生产贴片电感产地的公司.
以下是线艺电感常用的型号,欢迎咨询
POE13P-12LD
LPS3015-222MLC
0805LS-272XJLC
144-06J12SL
C1173-AL
C1174-AL
DO1813H-472MLB
DO3316H-472MLD
SLC7530
SLC7649
SLC1049-151MLB
MVRT
MVRC
MLC
MLC-1
SER1360-472KLD
SER1590-681MLB
DO5010H-392MLD
SER2009-681MLB
SER2010-681MLB
DO5040H-392MLB
SER2011-681MLB
SER2012-801MLB
SER2013-681MLB
SER2014-801MLB
0603PS-222KLC
0805PS-224MLB
LPS3008-472MLC
LPO4815-392MLB
LPS3010-472MLC
DO2010-473MLC
MSS4020-473MLD
LPS3314-474MLC
LPS5010-473MLB
LPS3015-222MLB
LPO6610-154MLB
DO3314-332MLB
LPS4012-472NLB
1812PS-274JLC
ME3220-472MLC
1008PS-224KLC
MSS5131-394MLB
DO1605T-334MLC
LPS4414-473MLB
MOS6020-472MLC
DO1608C-152ML
LPS5015-472MLB
LPS4018-472MLC
LPS5030-475MLB
MSS6122-562MLC
MSS6132-472MLB
MSS7341-473MLB
LPS6225-472MLC
LPS6235-563MLB
DO3308P-473
DO3316P-105MLD
MSS1038-473MLB
MSS1260-472MXB
DO3340P-474
MSS1278-472MXB
DO5022P-222ML
PF Sensor
Potted Sensor
PowerChoke-Axial
PowerChoke-Radial
DrumChoke
China Drum Choke
0906 /1606 SMT Spring (Micro)
0906 /1606 Non-RoHS SMT Spring (Micro)
A0XT / BXXT SMT Spring (Mini)
A0XT / BXXT Non-RoHS SMT Spring (Mini)
1812SMS SMT Spring (Midi)
1812SMS Non-RoHS SMT Spring (Midi)
132-xxSM SMT Spring (Maxi)
132-xxSM Non-RoHS SMT Spring (Maxi)
1508 / 2508 SMT LP Spring
 型号
Square Spring (0806SQ, 0807SQ, 0908SQ)
EP Core
Force Solenoids
Flat Wire (MLC, SER, SLC -China) (MVR - Mexico)
Planar
Machine Wound Toroid
Misc. Fixed Inductor
1206CS
1008CT
1008CS
0402CS
0603CS / 0603HC
0302CS
1812CS
0201DS
0805CS
0402AF
1008HT
1008HS
0805HT
0603HS
1008HS Encap
0805HQ Encap
1008HQ Encap
0805HS
0604HQ
0403HQ
1008LS
0402HP
0603LS
0603HP
1812LS
0402ME/0603ME Chip Ind
0805LS
Misc Small Toroids
PWB - small Toroids
Fixed Linearity
Adjustable Linearity
EE / EI / EC / EFD Core
BU9,BU10-16, FL Series
Pot Core
Laminated Core
Small Toroids/Table Tops
CCDLF8000/8500, CCDLF10000, TTDLF 10000
PDLF / PTRF
Tuneable Unicoils
Fixed Unicoils (China mfg - 142,143,144,146,150)
Fixed Unicoils - China only
1008AF
0603CT
0603AF
Small Toroids/Hollow Pin
EPL2010
EPL2014
EPL3010
EPL3015
EPL3012
XPL2010
Spring
Conical Spring (BCL/BCS/BCR)
PFL1610
PFL2010
PFL1005
PFL2510
PFL4514
PFL4517
XFL4020-152MEC
XFL3010
XFL3012
XFL2006
XAL1010
XAL4020/4030/4040
XAL1060
XAL7070
XAL5030
XAL6030/6060
Chip Transformer
1206USB
0603USB
0805USB
4308TC Transponder Coil
4312TC Transponder Coil
5315TC Transponder Coil
4308RV Transponder Coil
4312RV Transponder Coil
4513TC Transponder Coil
Raw Material
Metalized Forms
Work in Process (WIP)
Single Inline Package
Dual Inline Package
SMT LC Filters (S3HP/S3LP)
TRF-RJ & PCRJ
1812FS Inductor
0603PS Inductor
1812PS Inductor
1008PS Inductor
0805PS Inductor
LPD3015
LPD4012/LPR4012
LPD6235/LPR6235
LPD5010
LPD5030
Bead/Balun
Hand Wound Toroid
Hand Wound China SPT
DO1606T/F
DO1607 / DO1607BL
DO1608
DO1813HC
DO1605T
DO2010
DO3308 / DO3310
DO3308HC / DO3310HC
DO3316
DO3316HC
DW3316
DO3340
DO3340LW
DO5022
DO5022HC
DS1608
DS1608BL
DS3316 / DH3316
DS5022
DT1608
DT3316
DT3316HC
LPO3310
LPO30xx
LPO2506OB / LPO2506IB
LPT3305
LPO1704 / LPO6610
LPO6013
LPO48xx
LPO3314 / LPO3313
MSS1260 / MSS1260T
MSS5131
MOS6020
MSS6122
MSS6132
MSS4020
MSS1278 / MSS1278T
MSS7341 / MSS7341T
MSS1038
DO3314
LPS3010
LPS3015
LPS4012
LPS4018-104MC
LPS4018
LPS3008
LPS3314
DO5010HC
DO5040HC
ME3220
MSS1048
MSS1246 / MSS1246T
MSS5121
MSD7342
MSD1278
MSD1260
LPS4414
LPS50xx
LPS62xx
ZXC Z-AXIS TRANSPONDER
Experimental Kit
PC Assy & Test Fixture
0201DS-0N5XKLW
0201DS-1N5XJLW
0201DS-3N4XJLW
0201DS-3N9XJLW
0201DS-7N0XJLW
0201DS-9N4XJLW
040HP-1N0XJLW
040HP-3N3X_LW
040HP-5N1X_LW
040HP-8N2X_LW
040HP-11NX_LW
040HP-18NX_LW
040HP-23NX_LW
040HP-30NX_LW
040HP-40NX_LW
全部回复(3)
怎没个联系方式啊。
peterzou
@bluechipsemi
怎没个联系方式啊。
QQ512952681
pinzhan
@peterzou
QQ512952681
需要变压器电感可以联系我,完全能替代线艺,TDK,一线大厂产品,单价也有优势
联系QQ:2487952442
邮箱:justin_029@163.com
