我想要买一款高压电源 输入电压220V 输出电压10kV 输出电流1mA 调节方式为电位器调节的!请问哪里买比较好?如果有 厂家合适请跟我发站内信联系!
求购一款高压电源!
全部回复(12)
Input | |
Voltage | 240V ± 10% |
Phase | Three |
Frequency | 50/60 Hertz |
Current | 60 Amps |
Power | 20KW |
Output | |
Voltage | 0 - 10,000 Volts |
Current | 0 - 2.00 Amperes |
Regulation | |
Voltage | 0.05% For ±10% Line Changes and 0-100% Load Changes within the specified range. |
Ripple | 0.5% RMS of Rated Voltage at Full Load |
Stability | 0.02% Per Hour .05% Per 8 Hours after warm up |
Polarity | Fixed Positive Negative Low End Grounded |
Efficiency | Greater than 85% |
LED Indicators (Front Panel) | |
Power On | Indicates AC power is active |
Fault | Indicates a power supply fault is present |
Positive | Output polarity is positive |
Negative | Output polarity is negative |
Kilovolts | Indicates when unit is in voltage regulation mode |
Amperes | Indicates when unit is in current regulation mode |
@changeshaw
InputVoltage240V±10%PhaseThreeFrequency50/60HertzCurrent60AmpsPower20KWOutputVoltage0-10,000VoltsCurrent0-2.00AmperesRegulationVoltage0.05%For±10%LineChangesand0-100%LoadChangeswithinthespecifiedrange.Ripple0.5%RMSofRatedVoltageatFullLoadStability0.02%PerHour.05%Per8HoursafterwarmupPolarityFixedPositiveNegativeLowEndGroundedEfficiencyGreaterthan85%LEDIndicators(FrontPanel)PowerOnIndicatesACpowerisactiveFaultIndicatesapowersupplyfaultispresentPositiveOutputpolarityispositiveNegativeOutputpolarityisnegativeKilovoltsIndicateswhenunitisinvoltageregulationmodeAmperesIndicateswhenunitisincurrentregulationmode[图片]
Mechanical Specifications
Chassis Dimensions | |
Panel | 19" W x 10-1/2" H |
Chassis | 21" Deep |
Weight | 60Lbs. |
10kw | |
