在这里,专设一个对PI产品介绍的话题,
对选型应用,及安规等到方面,将所收集到的资料
与大家共享.如有需要,可直接联系我.
PI 应用及资料共享
全部回复(11)
先将自己整理的PI产品选型,供大家方便参考.
Topswitch-GX 230 VAC ±15% 85-265 VAC
Adapter Open Frame Adapter Open Frame
TOP242P or G 9 W 15 W 6.5 W 10 W
TOP242R 21 W 22 W 11 W 14 W
TOP242Y or F 10 W 22 W 7 W 14 W
TOP243P or G 13 W 25 W 9 W 15 W
TOP243R 29 W 45 W 17 W 23 W
TOP243Y or F 20 W 45 W 15 W 30 W
TOP244P or G 16 W 28 W 11 W 20 W
TOP244R 34 W 50 W 20 W 28 W
TOP244Y or F 30 W 65 W 20 W 45 W
TOP245P or G 19 W 30 W 13 W 22 W
TOP245R 37 W 57 W 23 W 33 W
TOP245Y or F 40 W 85 W 26 W 60 W
TOP246P or G 21 W 34 W 15 W 26 W
TOP246R 40 W 64 W 26 W 38 W
TOP246Y or F 60 W 125 W 40 W 90 W
TOP247R 45 W 70 W 28 W 43 W
TOP247Y or F 85 W 165 W 55 W 125 W
TOP248R 43 W 75 W 30 W 48 W
TOP248Y or F 105 W 205 W 70 W 155 W
TOP249R 44 W 79 W 31 W 53 W
TOP249Y or F 120 W 250 W 80 W 180 W
TOP250R 45 W 82 W 32 W 55 W
TOP250Y or F 135 W 290 W 90 W 210 W
Tinyswitch III 230 VAC ±15% 85-265 VAC
Adapter Peak or Open Frame Adapter Peak or Open Frame
TNY274P or G 6 W 11 W 5 W 8.5 W
TNY275P or G 8.5 W 15 W 6 W 11.5 W
TNY276P or G 10 W 19 W 7 W 15 W
TNY277P or G 13 W 23.5 W 8 W 18 W
TNY278P or G 16 W 28 W 10 W 21.5 W
TNY279P or G 18 W 32 W 12 W 25 W
TNY280P or G 20 W 36.5 W 14 W 28.5 W
Tinyswitch II 230 VAC ±15% 85-265 VAC
TNY263P or G 5 W 7.5 W 3.7 W 4.7 W
TNY264P or G 5.5 W 9 W 4 W 6 W
TNY265P or G 8.5 W 11 W 5.5 W 7.5 W
TNY266P or G 10 W 15 W 6 W 9.5 W
TNY267P or G 13 W 19 W 8 W 12 W
TNY268P or G 16 W 23 W 10 W 15 W
Fairchild FSD200/210 FSD311/321 FSD0165/0265/0365 INFINEON 2A0565/3A0565
ST Viper12A/22A SG6848/6849(CC/CV)
Onsemi NCP1011/2/3/4
Linkswitch-XT 230 VAC ±15% 85-265 VAC
Adapter(1) Open Frame(2) Adapter(1) Open Frame(2)
LNK362P or G 2.8 W 2.8 W 2.6 W 2.6 W
LNK363P or G 5 W 7.5 W 3.7 W 4.7 W
LNK364P or G 5.5 W 9 W 4 W 6 W
Linkswitch-HF 230 VAC ±15% 85-265 VAC
LNK353P or G 3 W 4 W 2.5 W(4) 3 W
LNK354P or G 3.5 W 5 W 3 W(4) 4.5 W
Linkswitch-LP 230 VAC ±15% 85-265 VAC
Adapter(2) Open Frame(3) Adapter(2) Open Frame(3)
LNK562P or G 1.9 W 1.9 W 1.9 W 1.9 W
LNK563P or G 2.5 W 2.5 W 2.5 W 2.5 W
LNK564P or G 3 W 3 W 3 W 3 W
Linkswitch-TN 230 VAC ±15% 85-265 VAC
MDCM(2) CCM(3) MDCM(2) CCM(3)
LNK302P or G 63 mA 80 mA 63 mA 80 mA
LNK304P or G 120 mA 170 mA 120 mA 170 mA
LNK305P or G 175 mA 280 mA 175 mA 280 mA
LNK306P or G 225 mA 360 mA 225 mA 360 mA
Linkswitch 230 VAC ±15% 85-265 VAC No-load input power cc tolerance
LNK500P or G 4 W 3 W <300 mW ±25%
5.5 W 3.5 W <500 mW
LNK501P or G 4 W 3 W <300 mW ±20%
5.5 W 3.5 W <500 mW
LNK520P or G 4 W 3 W <300 mW ±24%
5.5 W 3.5 W <500 mW
Peakswitch 230 VAC ±15% 85-265 VAC
Adapter Cont.(1) Adapter Peak(2) Adapter Cont.(1) Adapter Peak(2)
PKS603P 13 W 32 W 9 W 25 W
PKS604P 23 W 56 W 16 W 44 W
PKS604Y or F 35 W 56 W 23 W 44 W
PKS605P 31 W 60 W 21W 44 W
PKS605Y or F 46 W 79 W 30 W 58 W
PKS606P 35 W 66 W 25 W 46 W
PKS606Y or F 68 W 117 W 45 W 86 W
36-75 vdc input range (forward)2
forward 0.5 W 1 W 2.5 W 4 W 6 W Max Power Output1
DPAswitch
DPA423 12 W 16 W - - - 18 W
DPA424 16 W 23 W 35 W - - 35 W
DPA425 23 W 32 W 50 W 62 W - 70 W
DPA426 25 W 35 W 55 W 70 W 83 W 100 W
36-75 vdc input range (FLYBACK)2
Total Device Dissipation 0.5 W 0.75 W 1 W 1.5 W Max Power Output1
DPAswitch
DPA423 9 W 13 W - - 13 W
DPA424 10 W 14.5 W 18 W 24 W 26 W
DPA425 -4 -4 -4 25.5 W 52 W
1147491331.xls
5.5 W 3.5 W <500 mW
5.5 W 3.5 W <500 mW
5.5 W 3.5 W <500 mW
DPAswitch
DPAswitch
1147491331.xls
@adyj
先将自己整理的PI产品选型,供大家方便参考.Topswitch-GX230VAC±15%85-265VACAdapterOpenFrameAdapterOpenFrameTOP242PorG9W15W6.5W10WTOP242R21W22W11W14WTOP242YorF10W22W7W14WTOP243PorG13W25W9W15WTOP243R29W45W17W23WTOP243YorF20W45W15W30WTOP244PorG16W28W11W20WTOP244R34W50W20W28WTOP244YorF30W65W20W45WTOP245PorG19W30W13W22WTOP245R37W57W23W33WTOP245YorF40W85W26W60WTOP246PorG21W34W15W26WTOP246R40W64W26W38WTOP246YorF60W125W40W90WTOP247R45W70W28W43WTOP247YorF85W165W55W125WTOP248R43W75W30W48WTOP248YorF105W205W70W155WTOP249R44W79W31W53WTOP249YorF120W250W80W180WTOP250R45W82W32W55WTOP250YorF135W290W90W210WTinyswitchIII230VAC±15%85-265VACAdapterPeakorOpenFrameAdapterPeakorOpenFrameTNY274PorG6W11W5W8.5WTNY275PorG8.5W15W6W11.5WTNY276PorG10W19W7W15WTNY277PorG13W23.5W8W18WTNY278PorG16W28W10W21.5WTNY279PorG18W32W12W25WTNY280PorG20W36.5W14W28.5WTinyswitchII230VAC±15%85-265VACAdapterOpenFrameAdapterOpenFrameTNY263PorG5W7.5W3.7W4.7WTNY264PorG5.5W9W4W6WTNY265PorG8.5W11W5.5W7.5WTNY266PorG10W15W6W9.5WTNY267PorG13W19W8W12WTNY268PorG16W23W10W15WFairchildFSD200/210 FSD311/321 FSD0165/0265/0365 INFINEON2A0565/3A0565STViper12A/22ASG6848/6849(CC/CV)OnsemiNCP1011/2/3/4Linkswitch-XT230VAC±15%85-265VACAdapter(1)OpenFrame(2)Adapter(1)OpenFrame(2)LNK362PorG2.8W2.8W2.6W2.6WLNK363PorG5W7.5W3.7W4.7WLNK364PorG5.5W9W4W6WLinkswitch-HF230VAC±15%85-265VACAdapter(1)OpenFrame(2)Adapter(1)OpenFrame(2)LNK353PorG3W4W2.5W(4)3WLNK354PorG3.5W5W3W(4)4.5WLinkswitch-LP230VAC±15%85-265VACAdapter(2)OpenFrame(3)Adapter(2)OpenFrame(3)LNK562PorG1.9W1.9W1.9W1.9WLNK563PorG2.5W2.5W2.5W2.5WLNK564PorG3W3W3W3WLinkswitch-TN230VAC±15%85-265VACMDCM(2)CCM(3)MDCM(2)CCM(3)LNK302PorG63mA80mA63mA80mALNK304PorG120mA170mA120mA170mALNK305PorG175mA280mA175mA280mALNK306PorG225mA360mA225mA360mALinkswitch230VAC±15%85-265VACNo-loadinputpowercctoleranceLNK500PorG4W3W
建议大家直接下载,会更清楚明白
@adyj
PI的好,但成本有点高
@adyj
不错,路过,pi的好像自身的损耗有点高,噪音也比较高,整备采用LNK系列来做电源!有那位高手对此系列有见解的,不妨说说!
