请帮忙翻译以下资料,非常感谢
32NS rated 3.5A obtained acceptable results for the Temperature Test, 110% Clearing Time and 35A Interrupting Test.
32NS rated 5.0A obtained acceptable results for the Temperature Test, 110% Clearing Time.
51NM rated 3.5A obtained acceptable results for the Temperature Test, 110%, 135% and 200% Clearing Time and 35A Interrupting Test.
51NM rated 6.3A obtained acceptable results for the Temperature Test, 110% and 200% Clearing Time and 63A Interrupting Test.
51NS rated 1A obtained acceptable results for the Temperature Test, 110%, 135% and 200% Clearing Time and 35A Interrupting Test.
51NS rated 3.5A obtained acceptable results for the Temperature Test, 110%, 135% and 200% Clearing Time.
51NS rated 6.3A obtained acceptable results for the Temperature Test, 110%, 135% and 200% Clearing Time.
52NM rated 3.5A obtained acceptable results for the Temperature Test, 110% and 200% Clearing Time and 35A Interrupting Test.
52NM rated 6.3A obtained acceptable results for the Temperature Test, 110% and 200% Clearing Time and 63A Interrupting Test.
52NS rated 1A obtained acceptable results for the Temperature Test, 110%, 135% and 200% Clearing Time and 35A Interrupting Test.
52NS rated 3.5A obtained acceptable results for the Temperature Test, 110%, 135% and 200% Clearing Time.
52NS rated 6.3A obtained acceptable results for the Temperature Test, 110%, 135% and 200% Clearing Time.
61NM rated 3.5A obtained acceptable results for the Temperature Test, 110% and 200% Clearing Time and 35A Interrupting Test.
61NM rated 10A obtained acceptable results for the Temperature Test, 110% and 200% Clearing Time and 100A Interrupting Test.
