BQ20Z655采用的是什么技术,使得符合SBS1.1标准的?
全部回复(2)
higel
Impedance Track™ Technology
详细请参见datasheet
http://www.ti.com/lit/ds/symlink/bq20z655.pdf
zvszcs
LV.12
@higel
ImpedanceTrack™Technology详细请参见datasheethttp://www.ti.com/lit/ds/symlink/bq20z655.pdf
slua623
The bq20z655 SBS-compliant gas gauge and protection IC, incorporating patented Impedance Track™ technology, is a single IC solution designed for battery-pack or in-system installation. The bq20z655 measures and maintains an accurate record of available charge in Li-ion or Li-polymer batteries using its integrated high-performance analog peripherals. The bq20z655 monitors capacity change, battery impedance, open-circuit voltage, and other critical
采用了Impedance Track™ technology
