JAPAN FUDEN富电 在线UPS MD730 3KVA
1996年制造,内置YUASA 12V7AH*12电池,现电池全坏.500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093913642.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(36)
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093913738.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093913778.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093913814.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
请各位DX提供原理图.500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093913853.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
或者介绍一下工作原理500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093913889.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093913992.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093914028.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093914077.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093914101.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093914142.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/20/1093914173.jpg');}" onmousewheel="return imgzoom(this);">
bbhh
  请问各位前辈,这种UPS在没接电池的情况下能正常用吗?(作为稳压器和滤波器使用)
我这样试了,在没接负载时正常,接了一个台式风扇时就报警,FAULT红灯亮,同时转为旁路工作.
helaoliu
@bbhh
  请问各位前辈,这种UPS在没接电池的情况下能正常用吗?(作为稳压器和滤波器使用)我这样试了,在没接负载时正常,接了一个台式风扇时就报警,FAULT红灯亮,同时转为旁路工作.
UPS在不接电池的情况下,可以打到旁路,继续使用.看来可能是逆变部分电路坏了.这下可惨了,居我所知,富电的UPS早就不产了.配件可能都找不到.
bbhh
@helaoliu
旁路只是在启动时工作,无论有否电池,启动完后都会转到在线方式.而且旁路没有稳压/滤波作用呀!
终于弄了12个12V电池充好电试机(电池容量不一样2个100AH 4个24AH 6个7AH).一开机蜂鸣器告警(嘀-嘀-嘀-嘀),指示灯正常,有/没市电都能带动负载,断开电池蜂鸣器不告警了.请前辈们赐教?可能会出现那些问题?
helaoliu
@bbhh
旁路只是在启动时工作,无论有否电池,启动完后都会转到在线方式.而且旁路没有稳压/滤波作用呀!终于弄了12个12V电池充好电试机(电池容量不一样2个100AH4个24AH6个7AH).一开机蜂鸣器告警(嘀-嘀-嘀-嘀),指示灯正常,有/没市电都能带动负载,断开电池蜂鸣器不告警了.请前辈们赐教?可能会出现那些问题?
你的UPS是标机,还是长机?
bbhh
@helaoliu
你的UPS是标机,还是长机?
找出蜂鸣器告警原因了,是电池没充够电.
我也不是很清楚,这机器是别人送的.
应该是长机吧,机箱后有外接电池端子.(请看第5帖图)
今天用电池启动逆变,带动29寸电视和DVB一小时很正常.
helaoliu
@bbhh
找出蜂鸣器告警原因了,是电池没充够电.我也不是很清楚,这机器是别人送的.应该是长机吧,机箱后有外接电池端子.(请看第5帖图)今天用电池启动逆变,带动29寸电视和DVB一小时很正常.
你的电池不能混用,否则电池的寿命缩短
bbhh
@helaoliu
你的电池不能混用,否则电池的寿命缩短
只是试几次机应该没什么问题.
bbhh
@bbhh
只是试几次机应该没什么问题.
想不接电池用来作2.2KVA小型汽油发电机的稳压/滤波器.
因发电机输出的波形/频率不理想,接白炽灯/日光灯有明显闪烁,接山特500VA后备UPS电源时常保护没输出.
FUDEN UPS实验如下:
1.接电池时各项正常.
2.不接电池,以市电启动,最多只能带20W-30W负载,负载大了就告警,转旁路(旁路没有稳压/滤波作用).
3.不接电池,但断开最下面电路板(电池逆变+交流滤波板,参考第11帖图和第9帖图)的红黑电池144V输入线,能带动几百W电饭煲工作,而且不告警,不转旁路.(这种应该是以交流输入--滤波--最上面一块电路板的整流--逆变--输出交流)
不知这样接对UPS是否有害?请指教!
fj828
@bbhh
想不接电池用来作2.2KVA小型汽油发电机的稳压/滤波器.因发电机输出的波形/频率不理想,接白炽灯/日光灯有明显闪烁,接山特500VA后备UPS电源时常保护没输出.FUDENUPS实验如下:1.接电池时各项正常.2.不接电池,以市电启动,最多只能带20W-30W负载,负载大了就告警,转旁路(旁路没有稳压/滤波作用).3.不接电池,但断开最下面电路板(电池逆变+交流滤波板,参考第11帖图和第9帖图)的红黑电池144V输入线,能带动几百W电饭煲工作,而且不告警,不转旁路.(这种应该是以交流输入--滤波--最上面一块电路板的整流--逆变--输出交流)不知这样接对UPS是否有害?请指教!
这个UPS同山特的3KV内部一模一样.(从图片上看)
bbhh
@fj828
能告诉我是山特3KVA的什么型号吗?最好能给个地址连接.
爬山鱼
@bbhh
你是后备式的,当然不能接电机,你找一下说明书,它一定会注明此点或是在接口地方贴了警告!
fj828
@bbhh
我是在二手市场上看到的,电池电压96V
panch
@bbhh
根据你提供的情况来看,UPS的逆变部分及电池升压部分应是没问题的.
在线式UPS一般在市电正常范围内工作不带电池是可以带载运行的.
此问题的原因可能出现在市电输入部分的电路及AC/DC.
UPS带发电机得看它的允许工作频率范围,否则要改锁相部分的电路.
bbhh
@panch
根据你提供的情况来看,UPS的逆变部分及电池升压部分应是没问题的.在线式UPS一般在市电正常范围内工作不带电池是可以带载运行的.此问题的原因可能出现在市电输入部分的电路及AC/DC.UPS带发电机得看它的允许工作频率范围,否则要改锁相部分的电路.
你的很正确,应该是AC/DC部分出问题.
有市电情况下:
  1.当负载小于50W左右时,UPS向电池组充电,整机工作正常;
  2.当负载大于50W左右时,电池组要向UPS供电(在电池组中串电流表测出).
  3.当负载大于50W左右且不接电池组,DC电压低于80V,告警进入保护转到旁路.
但没有图纸,很多线路被变压器和散热器压在下面,很难看清,维修很困难.
panch
@bbhh
你的很正确,应该是AC/DC部分出问题.有市电情况下:  1.当负载小于50W左右时,UPS向电池组充电,整机工作正常;  2.当负载大于50W左右时,电池组要向UPS供电(在电池组中串电流表测出).  3.当负载大于50W左右且不接电池组,DC电压低于80V,告警进入保护转到旁路.但没有图纸,很多线路被变压器和散热器压在下面,很难看清,维修很困难.
也许这种电源有图纸的不多了只有凭经验修了,累点儿.
whh2003
@bbhh
你的ups没有在用市电,是在用电池放电,不用电池可以带轻载,是因为
本机的充电器在代替电池给后级供电.
你图片中下面那个板子有个白色保险,要查看是否已坏.
很多侦测,充电线路是不经过那个保险的,那个保险只是功率回路
的保险.
bbhh
@whh2003
你的ups没有在用市电,是在用电池放电,不用电池可以带轻载,是因为本机的充电器在代替电池给后级供电.你图片中下面那个板子有个白色保险,要查看是否已坏.很多侦测,充电线路是不经过那个保险的,那个保险只是功率回路的保险.
两个保险都测过了没坏.
kv3000
2005-01-09 14:45
@bbhh
两个保险都测过了没坏.
各位前辈: 你们好!
我也有一个富电UPS 3KVA的,与本文所说一模一样,它原来在内部装有12个12V,7AH的小电池(都已经坏了? 测出每个的电压只有零点几伏),现找来12个12V,65AH的电池(测出各个电池有些为10点多伏,有些为14伏),接上后打开开关,LOAD灯、LINE灯、BYPASS灯灯,还有LEVEL灯也亮,但几钞后LEVEL灯灭,报警器长鸣[断开电池组时也是长鸣不止].
   请问各位是什么原因?(已经这样开着几个小时了,还是长鸣不止)
我有一只和你的一模一样,但是山特的
