请帮忙翻译一下 !!! 急 !!! Thanks !!!
采用长寿命陶瓷轴承风扇强制冷却,接口形式为快速热插拔,交流输入为单相,前级采用boost升压主电路进行功率因数校正,后级采用双管正激软开关技术
全部回复(2)
It is cooled by long-life porcelain bearing fan.The mode of interface is fast hot interpose, Ac input is single-phase,primary stage uses boost rise voltage circuit to revise the factor of power,secondary stage uses double pipe positive stimulate soft switch technology.
mmaary
@123liuxiao
Itiscooledbylong-lifeporcelainbearingfan.Themodeofinterfaceisfasthotinterpose,Acinputissingle-phase,primarystageusesboostrisevoltagecircuittorevisethefactorofpower,secondarystageusesdoublepipepositivestimulatesoftswitchtechnology.
thank you!
