python字符串、列表和bytes的相互转换 日常积累
1、字符串转bytes
方式一:
''' string to bytes eg:
'0123456789ABCDEF0123456789ABCDEF' b'0123456789ABCDEF0123456789ABCDEF' '''
def stringTobytes(str):
    return bytes(str,encoding='utf8')
方式二:
    b=str.encode('utf-8')
    print(b)
2、bytes转字符串
# bytes转字符串方式一
''' bytes to string eg:
def bytesToString(bs):
     return bytes.decode(bs,encoding='utf8')
# bytes转字符串方式二
b=b'\xe9\x80\x86\xe7\x81\xab'
string=str(b,'utf-8')
print(string)
# bytes转字符串方式三
string=b.decode() # 第一参数默认utf8,第二参数默认strict
print(string)
# bytes转字符串方式四
b=b'\xe9\x80\x86\xe7\x81haha\xab'
string=b.decode('utf-8','ignore') # 忽略非法字符,用strict会抛出异常
print(string)
# bytes转字符串方式五
string=b.decode('utf-8','replace') # 用?取代非法字符
print(string)
3、十六进制字符串转bytes
''' hex string to bytes eg:
'01 23 45 67 89 AB CD EF 01 23 45 67 89 AB CD EF'
b'\x01#Eg\x89\xab\xcd\xef\x01#Eg\x89\xab\xcd\xef' '''
def hexStringTobytes(str):
    str = str.replace(" ", "")
     return bytes.fromhex(str)
     # return a2b_hex(str)
4、bytes转十六进制字符串
bytes to hex string
eg:
def bytesToHexString(bs):
    # hex_str = ''
    # for item in bs:
    #     hex_str += str(hex(item))[2:].zfill(2).upper() + " "
    # return hex_str
    return ''.join(['%02X ' % b for b in bs])
5.字符串转列表
str1 = "hi hello world"
print(str1.split(" ")) 输出: ['hi', 'hello', 'world']
6.列表转字符串
l = ["hi","hello","world"]
print(" ".join(l)) 输出: hi hello world
 7.十进制和十六进制相互转换
    7.1十进制 、十六进制转换
10进制转16进制: hex(16)  ==>  0x10
16进制转10进制: int('0x10', 16)  ==>  16
类似的还有oct()bin()
  7.2 字符串转整数:
10进制字符串: int('10')  ==>  10
16进制字符串: int('10', 16)  ==>  16
16进制字符串: int('0x10', 16)  ==>  16
赞 2
收藏 2
关注 19
