hello-boy
认证:优质创作者
作者动态
分享一个使用C语言实现锁相环(PLL)以跟踪输入电压(正弦波)的例程代码
10-30 17:18
一文读懂几种永磁同步电机(PMSM)的区别
04-10 16:23
SJ/T 11893-2023《便携式锂离子电池储能电源技术规范》解读
01-29 15:44
#征文#基于DSP的无感FOC驱动嵌入式软件设计
01-17 21:15
电机V/F、开环矢量SVC、闭环矢量FVC控制的区别与应用
01-03 17:22
基于滑模观测器的FOC电机驱动算法实现---源码
永磁同步电机采用FOC算法实现电机控制,FOC算法的控制框图如下:
软件实现,ADC采样触发实现算法的软件流程图如下:
PARK变换模块宏定义代码如下:
typedef struct {
  _iq  Alpha;  // Input: stationary d-axis stator variable
  _iq  Beta; // Input: stationary q-axis stator variable
  _iq  Angle; // Input: rotating angle (pu)
  _iq  Ds; // Output: rotating d-axis stator variable
  _iq  Qs; // Output: rotating q-axis stator variable
  _iq  Sine;
  _iq  Cosine;
} PARK;
Default initalizer for the PARK object.
#define PARK_DEFAULTS {
                          0, \
                          0, \
                          0, \
                          0, \
                          0, \
                          0, \
                          0, \
PARK Transformation Macro Definition
#define PARK_MACRO(v) \
v.Ds = _IQmpy(v.Alpha,v.Cosine) + _IQmpy(v.Beta,v.Sine); \
    v.Qs = _IQmpy(v.Beta,v.Cosine) - _IQmpy(v.Alpha,v.Sine);
#endif // __PARK_H__
CLARKE变换模块宏定义代码如下:
typedef struct {
  _iq  As;  // Input: phase-a stator variable
  _iq  Bs;// Input: phase-b stator variable
  _iq  Cs;// Input: phase-c stator variable
  _iq  Alpha;// Output: stationary d-axis stator variable
  _iq  Beta;// Output: stationary q-axis stator variable
} CLARKE;
Default initalizer for the CLARKE object.
#define CLARKE_DEFAULTS {
                          0, \
                          0, \
                          0, \
                          0, \
                          0, \
CLARKE Transformation Macro Definition
#define CLARKE_MACRO(v)\
v.Alpha = v.As;\
v.Beta = _IQmpy((v.As +_IQmpy2(v.Bs)),_IQ(0.57735026918963));\
//  1/sqrt(3) = 0.57735026918963
#endif // __CLARKE_H__
IPARK变换模块宏定义代码如下:
typedef struct {
   _iq  Alpha;  // Output: stationary d-axis stator variable
  _iq  Beta; // Output: stationary q-axis stator variable
  _iq  Ds; // Input: rotating d-axis stator variable
  _iq  Qs; // Input: rotating q-axis stator variable
  _iq  Sine; // Input: Sine term
  _iq  Cosine; // Input: Cosine term
    } IPARK;
Default initalizer for the IPARK object.
#define IPARK_DEFAULTS {
                          0, \
                          0, \
                          0, \
                          0, \
                          0, \
                          0, \
                          0, \
Inverse PARK Transformation Macro Definition
#define IPARK_MACRO(v) \
v.Alpha = _IQmpy(v.Ds,v.Cosine) - _IQmpy(v.Qs,v.Sine); \
v.Beta  = _IQmpy(v.Qs,v.Cosine) + _IQmpy(v.Ds,v.Sine);
#endif // __IPARK_H__
滑模观测器参考代码如下:
// 定义系统参数
R = 1.0;   // 电机内阻
L = 0.1;   // 电机电感
Ke = 0.01;   // 电机电动势常数
Kt = 0.02 ;   // 电机转矩常数
/ /定义控制器参数
Kp = 0.5 ;   //比例增益
Ki = 0.1 ;   // 积分增益
// 定义变量
theta_hat = 0.0;   // 转子位置估计值
theta_dot_hat = 0.0 ;   // 转子速度估计值
theta_ref = 0.0 ;   //目标转子位置
theta_dot_ref = 0.0 ;   // 目标转子速度
u = 0.0 ;   // 控制输入
e_int = 0.0 ;   // 积分误差
//定义滑模观测器参数
lambda1 = 1.0;
lambda2 = 1.0;
#define SMO_MACRO(v) \
Te = Kt * (i_a * sin(theta_hat) - i_b * cos(theta_hat));\    //计算电机电磁转矩
s1 = theta_dot_hat - lambda1 * Te;\    // 计算滑模观测器误差
s2 = theta_hat - theta_ref;\
u = -Kp * s1 - Ki * e_int ;\ // 计算控制器输出
theta_dot_hat += (R / L) * i_a - (Ke / L) * sin(theta_hat) * u theta_hat += theta_dot_hat;\ //更新状态估计
e_int += s2;\ //更新积分误差
#endif // __SMO_H__
申明:由于本人水平一般,分享的知识有误,或者采用的方案不够好的,欢迎各路大神指正批评,给大家带来的不便,敬请谅解,本文观点仅供参考。
赞 2
收藏 3
关注 156
  • hello-boy 2023-12-06 17:04
    本文只是对IPARK、PARK、CLARKE变换以及SMO滑模观测器的算法实现进行说明,实际的FOC算法远比这段伪代码复杂,其中还包括了磁场定向、PI控制器等内容,但是电流采样部分,以及控制器的输出量和PWM的占空比如何联系起来的等等。
    回复 1条回复
