上班摸鱼?C语言玩魂斗罗!
最近玩了docker,发现真的很方便,和Java 、Python这种类似,一次写好,到处运行。
虽然是一项技术,也是工作技能,但只是工作怎么行,闲暇之余,还是可以用来摸摸鱼的。
超级玛丽
只要是nes游戏,应该都支持。
双人模式下,目前数字键使用的是小键盘。
nes-dockerfile 文件
FROM ubuntu:18.04 as builder
MAINTAINER Osprey
#docker build -f nes-dockerfile -t nes.osprey.io/nes-build-run .
# docker start nes-build
# docker attach nes-build
# docker exec -it  nes-build  /bin/bash
# 创建用户 cmd:id
ARG USERNAME=osprey
ARG USER_UID=1000
ARG USER_GID=$USER_UID
RUN groupadd --gid $USER_GID $USERNAME \
    && useradd --uid $USER_UID --gid $USER_GID -m $USERNAME \
    && apt-get update \
    && apt-get install -y sudo \
    && echo $USERNAME ALL=\(root\) NOPASSWD:ALL > /etc/sudoers.d/$USERNAME \
    && chmod 0440 /etc/sudoers.d/$USERNAME
RUN apt-get update
# for cmd: add-apt-repository
RUN apt -y install software-properties-common dirmngr apt-transport-https lsb-release ca-certificates
RUN add-apt-repository ppa:xmake-io/xmake -y && apt-get update && apt-get install -y xmake
RUN apt-get install -y libsdl2-dev
RUN apt-get install -y git make gcc
# option
RUN  apt-get install -y nano iputils-ping
# setting the password of root to 123456
RUN echo 'root:123456' | chpasswd
USER $USERNAME
ENV HOME=/home/$USERNAME
RUN mkdir /home/$USERNAME/work
WORKDIR /home/$USERNAME/work
RUN git clone https://gitee.com/Dozingfiretruck/nes && cd nes && xmake
FROM ubuntu:18.04 as prod
#设置时区
ENV TZ=Asia/Shanghai
RUN ln -snf /usr/share/zoneinfo/$TZ /etc/localtime && echo $TZ > /etc/timezone
# 创建用户 cmd:id
ARG USERNAME=osprey
ARG USER_UID=1000
    && apt-get update \
RUN apt-get update
RUN apt-get install -y p7zip-full libsdl2-dev
USER $USERNAME
RUN echo "PS1='\[\e[0;33m\]\u@\h\[\e[0m\]:\[\e[0;34m\]\w\[\e[0m\]\$ '" >> /home/$USERNAME/.bashrc
COPY --from=0 /home/$USERNAME/work/nes/build/linux/x86_64/release/nes .
COPY contra.nes .
COPY SuperMarioBrosWorld.nes .
#CMD ["~/work/nes contra.nes"]
# run cmd:
# docker run --name=nes-test --rm -it -v /tmp/.X11-unix:/tmp/.X11-unix -v /dev/snd:/dev/snd --privileged -e DISPLAY=unix$DISPLAY nes.osprey.io/nes-build-run /bin/bash -c "./nes contra.nes"
编译命令(前提是安装好docker,参考:docker通用安装使用指南-Ubuntu-树莓派5):
摸鱼指令(nes-build-run 由前面的命令生成
如果有新的 nes 游戏,可以拷贝到容器中后,再进入容器中运行该文件
docker cp xx.nes nes-test:/home/osprey/nes
最后为了更好的摸鱼,可以配合vscode使用,随时随地打开模拟器摸鱼,爽歪歪。
ubuntu18 以下版本只能下载v1.85的deb 文件,最新版本安装不了(其他版本安装最新的vscode就行):
https://update.code.visualstudio.com/1.85.2/linux-deb-x64/stable
安装deb文件
sudo dpkg -i code_1.85.2-1705561292_amd64.deb
vscode打开 nes,
# forkr from https://gitee.com/Dozingfiretruck
git clone https://gitee.com/embeddedosprey/nes -b docker
# docker 分支目前含有编译好的镜像 nes-build-run 565M,直接使用 load 命令导入即可
code nes
# 如果是自己导入的镜像,可能需要需要修改一下镜像名称
安装插件 Dev Containers
右下角点击重新打开 Reopen in Container(如果没有,可以通过 ctrl + shift+p,输入 rebuild
容器内执行命令
导出镜像:
docker save nes.osprey.io/nes-build-run > nes-build-run.tar
在虚拟机的代码仓库.devcontainer里面导入镜像:
docker load < nes-build-run.tar
nes C语言模拟器开源仓库地址:
https://github.com/Dozingfiretruck/nes
魂斗罗 nes 下载参考链接
https://www.fcnes.com/fc/act/38.html#downadress
赞 1
收藏 2
关注 160
