求救:与JST RHSR-02VS-1配合的PCB用直插式插座的生产厂家、型号
原来使用的是韩国YEONHO的35002WR-02A00,但是客户使用的PANEL上用的是JST的RHSR-02VS-1,和35002WR-02A00配合时有些松动导致打火,现在需要变更插座的型号,请教各位大侠可以使用的连接器的型号和生产厂家.
全部回复(4)
please contact:
idychen
mail:idychen@nt.cvilux.com.tw
Call Mobile:1371-224-6728
CVILUX GORUP
Power Connectors 3.5mm(.138) Plug Dip Header
Power Connectors 3.5mm(.138) Plug SMT Header
Power Connectors 3.5mm(.138) Housing
Power Connector Crimp Terminal
USE for Use high voltage UL3266 wire assembly.
◎ Rated current and voltage : 1A , 1400V AC(r.m.s)
◎ Dielectric Withstanding Voltage : 3800V AC for one minute
◎ Contact Resistance : <10mΩ
◎ Insulation Resistance : >1000MΩ
◎ Operating Temperature : -25℃~85℃
RoHS Compliant
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1154920201.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1154920208.gif');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/44/1154920216.gif');}" onmousewheel="return imgzoom(this);">
idychen
CVILUX GORUP
RoHS Compliant
@channey
pleasecontact:idychenmail:idychen@nt.cvilux.com.twCallMobile:1371-224-6728CVILUXGORUPPowerConnectors3.5mm(.138)PlugDipHeaderPowerConnectors3.5mm(.138)PlugSMTHeaderPowerConnectors3.5mm(.138)HousingPowerConnectorCrimpTerminalUSEforUsehighvoltageUL3266wireassembly.◎Ratedcurrentandvoltage: 1A,1400VAC(r.m.s)◎DielectricWithstandingVoltage:3800VACforoneminute◎ContactResistance:1000MΩ◎OperatingTemperature:-25℃~85℃RoHSCompliant[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1154920201.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1154920208.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/44/1154920216.gif');}"onmousewheel="returnimgzoom(this);">
我们现在用的是YEONHO的35002WR,有没有和他PIN对PIN直接替代的,同时可以配合JST的
