业内体积最小、低成本电源方案
一、DU8623 reference design for E14/Candle 10mm*16mm*10.5mm
E14 candle
For 1 to 3W non-isolated LED lighting
Input Voltage Range: 85V ~ 265Vac
Output Voltage Range: 3V ~ 60Vdc
Output Current: up to 35mA
Overall Output Current Regulation: 2%
Conversion Efficiency: 85% @ 110V / 60Hz; 88% @ 230V / 50Hz
Conversion Power Factor: 0.6 @ 110V / 60Hz; 0.5 @ 230V / 50Hz
EMI: Meet EN55015B standard
用DU8623做的10mm*16mm*10.5mm尺寸3W方案,勘称业内最小体积。可以内置E14,使用了贴片电感,体积小,成本有所增加。总体BOM成本在RMB2.5左右
二、DU8623 reference design for Bulb
GU10/Candle
For 1 to 5W non-isolated LED lighting
Output Voltage Range: 3V ~ 42Vdc
Output Current: up to 120mA
Conversion Efficiency: 88% @ 110V / 60Hz; 86% @ 230V / 50Hz
Conversion Power Factor: N/A
EMI: N/A
5W 球泡,BOM成本2.2左右,成本、体积都很不错。
三.DU8623 reference design for Bulb
GU10/Candle
Input Voltage Range: 180V ~ 264Vac
Output Voltage Range:3V-52Vdc
Output Current: up to 60mA
Conversion Efficiency: 92% @ 230V / 50Hz
EMI: N/A
3W球泡,BOM成本2.2以下,无电解电容,成本低、寿命加长。
详细可以联系QQ:2397811510
TEL:15814401239 陈 R
全部回复(4)
123aaaatt
你好,我是代理分销元器件的,有需要配套欢迎咨询报价!欢迎来公司考察,这是我们的网店http://jiexuandianzi.taobao.com/index.htm?spm=2013.1.w854162535.2.mtpx92
lcp196696
@123aaaatt
QQ:554602178,lcp196696@163.com,请发资料给我
KingBboy
@lcp196696
资料以发,注意查收
@KingBboy
资料以发,注意查收[图片]
有收获,顶顶顶
