BROWN-OUT Test
BROWN-OUT Test
what's the meaning?How to do Brown-out test?TKS~
全部回复(6)
rich2005
anybody here~~?
rich2005
@rich2005
anybodyhere~~?
who can tell me ~?
stevenlee
@rich2005
whocantellme~?
input voltage step up and step down test.for example:input voltage step down from 264V to 0V and return to 264V.the test unit shoul not occur any damage.
rich2005
@stevenlee
inputvoltagestepupandstepdowntest.forexample:inputvoltagestepdownfrom264Vto0Vandreturnto264V.thetestunitshoulnotoccuranydamage.
thanks the first!but i don't know why test with this way!the power will be used at 90-264v.why no be tested under the voltage 0-264-0V?
stevenlee
@rich2005
thanksthefirst!butidon'tknowwhytestwiththisway!thepowerwillbeusedat90-264v.whynobetestedunderthevoltage0-264-0V?
I think that yor can understand them after you have more working experience.
rich2005
@stevenlee
Ithinkthatyorcanunderstandthemafteryouhavemoreworkingexperience.
ok!i will work hard forever~TKS
米修儿
【 DigiKey DIY原创大赛】1、开发环境篇
无言的朝圣
【 DigiKey DIY原创大赛】综合帖-解压小工具
无言的朝圣
【深度剖析】带你玩转工业物联网设计,实现安全与效率并重!
地瓜patch
