Infineon 电源IC 大全--+--各种电路拓扑!!!
下面是Infineon 电源IC 大全
    各位有空的时候进来看看
    ICE X65系列1096126790.pdf
全部回复(31)
PWM (Pulse Width Modulation) control ICs for SMPS
Highly efficient power supply controllers with low power stand-by and power factor correction (PFC) capabilities.1096127638.pdf1096127660.pdf
1096127712.pdf
1096127735.pdf1096127786.pdf1096127806.pdf1096127830.pdf1096127854.pdf
Power Combi (PWM+PFC) control IC for SMPS
IC including the PWM control for an SMPS and the control for the preconverter to improve the Power Factor and to reduce the harmonics of the AC input current.
1096128017.pdf
PFC (Power Factor Correction) control ICs for SMPS
  IC's for sinusoidal line current consumption.
Operating in discontinous mode to control boost converter as an active harmonic filter.
1096128248.pdf
1096128264.pdf
1096128326.pdf
1096128342.pdf
1096128355.pdf
AC-DC selection guide1096128540.pdf
DC-DC
CoreControlTM- PWM Control ICs
  PWM Contol ICs for high precision CPU core supplies
1096128825.pdf
1096128894.pdf
CoreControlTM- Gate Driver
  Single/dual Gate Driver for efficient high-speed DC/DC buck converter designs
1096128963.pdf
1096128978.pdf
1096129001.pdf
1096129013.pdf
1096129029.pdf
CoreControlTM - Integrated Switch
  Driver plus high-side and low-side MOSFET combined in a single package .
1096129148.pdf
Flyback Converter
INTRODUCTION:
The Flyback converter is one of the simplest and most economical SMPS power supply topology, suited best to lower power levels, because the triangular current waveforms incur high peak losses in the primary side switch, and relatively high output ripple current and ripple voltage on the output side.
The flyback transformer is designed as an energy storage and transfer inductor, sized to store the energy required at the peak of the primary current during the first switching state. This maximum energy storage is irrespective of the input line voltage; variations in line voltage merely change the duty cycle required to charge the flyback transformer to the programmed current level. The transformer turns ratio is selected based on the allowable reflected flyback voltage as well as the desired output voltage. During the second switching state, the power switch must block the bus voltage « +Vin » plus the reflected reset voltage determined by the regulated «Vout» and the transformer turns ratio. Uncoupled inductance from the primary to secondary (leakage inductance) will also store energy, and since this energy is not clamped by the output winding, it will cause an avalanche on the primary unless clamped by an RCD snubber network.
BASICS OF OPERATION :
Energy transfer occurs by charging a current into the flyback inductor/transformer primary by turning on the power transistor. When the transistor turns off, the inductor reset on the secondary side conducts through CR1 to the output capacitor. Leakage inductance on the primary must be clamped on primary side (see below).
OVERALL SCHEMATIC
see global schematic below
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096129326.gif');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096129337.gif');}" onmousewheel="return imgzoom(this);">
@power-wang
FlybackConverter    INTRODUCTION:TheFlybackconverterisoneofthesimplestandmosteconomicalSMPSpowersupplytopology,suitedbesttolowerpowerlevels,becausethetriangularcurrentwaveformsincurhighpeaklossesintheprimarysideswitch,andrelativelyhighoutputripplecurrentandripplevoltageontheoutputside.Theflybacktransformerisdesignedasanenergystorageandtransferinductor,sizedtostoretheenergyrequiredatthepeakoftheprimarycurrentduringthefirstswitchingstate.Thismaximumenergystorageisirrespectiveoftheinputlinevoltage;variationsinlinevoltagemerelychangethedutycyclerequiredtochargetheflybacktransformertotheprogrammedcurrentlevel.Thetransformerturnsratioisselectedbasedontheallowablereflectedflybackvoltageaswellasthedesiredoutputvoltage.Duringthesecondswitchingstate,thepowerswitchmustblockthebusvoltage«+Vin»plusthereflectedresetvoltagedeterminedbytheregulated«Vout»andthetransformerturnsratio.Uncoupledinductancefromtheprimarytosecondary(leakageinductance)willalsostoreenergy,andsincethisenergyisnotclampedbytheoutputwinding,itwillcauseanavalancheontheprimaryunlessclampedbyanRCDsnubbernetwork.BASICSOFOPERATION:Energytransferoccursbychargingacurrentintotheflybackinductor/transformerprimarybyturningonthepowertransistor.Whenthetransistorturnsoff,theinductorresetonthesecondarysideconductsthroughCR1totheoutputcapacitor.Leakageinductanceontheprimarymustbeclampedonprimaryside(seebelow).OVERALLSCHEMATICseeglobalschematicbelow[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096129326.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096129337.gif');}"onmousewheel="returnimgzoom(this);">
Two transistor Forward Converter
INTRODUCTION:
This SMPS topology has been widely used because of its robustness, simplicity, and moderately high performance. It is similar in performance characteristics to the single transistor forward converter, excepting that the two-transistor topology is inherently self-clamping for the magnetizing current reset of the power transformer, making avalanche operation unlikely. Additionally, this topology requires power transistors with only 1/2 the VDS blocking capability of the single transistor version. This reduction in voltage requirements dramatically reduces the RDS[on] for silicon area in the case of conventional MOSFET transistors, with the result that the two smaller transistors usually cost less than the single larger transistor, with lower total losses.
The two transistor forward converter is compatible with current mode control, and with the improved operating conditions for the transistor switches due to the lower operating voltage requirements, gives good performance in midrange power applications.
Energy transfer occurs across the isolation transformer, when the power transistors Q1 and Q2 turn on, and the primary voltage is reflected across the output windings, and rectified by CR1, charging the output inductor. When the primary switch turns off, the flyback from the leakage inductance and magnetizing inductance flows through the clamp diodes D1 and D2, clamping the flyback of the primary and returning the energy from the magnetizing inductance of the transformer to the primary power bus (C1 In). The output inductor and output capacitor store energy and integrate the duty cycle so that the output voltage is proportional to the product of the rectified output voltage and duty cycle(see below).
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096129585.gif');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096129776.gif');}" onmousewheel="return imgzoom(this);">
@power-wang
TwotransistorForwardConverter    INTRODUCTION:ThisSMPStopologyhasbeenwidelyusedbecauseofitsrobustness,simplicity,andmoderatelyhighperformance.Itissimilarinperformancecharacteristicstothesingletransistorforwardconverter,exceptingthatthetwo-transistortopologyisinherentlyself-clampingforthemagnetizingcurrentresetofthepowertransformer,makingavalancheoperationunlikely.Additionally,thistopologyrequirespowertransistorswithonly1/2theVDSblockingcapabilityofthesingletransistorversion.ThisreductioninvoltagerequirementsdramaticallyreducestheRDS[on]forsiliconareainthecaseofconventionalMOSFETtransistors,withtheresultthatthetwosmallertransistorsusuallycostlessthanthesinglelargertransistor,withlowertotallosses.Thetwotransistorforwardconverteriscompatiblewithcurrentmodecontrol,andwiththeimprovedoperatingconditionsforthetransistorswitchesduetotheloweroperatingvoltagerequirements,givesgoodperformanceinmidrangepowerapplications.BASICSOFOPERATION:Energytransferoccursacrosstheisolationtransformer,whenthepowertransistorsQ1andQ2turnon,andtheprimaryvoltageisreflectedacrosstheoutputwindings,andrectifiedbyCR1,chargingtheoutputinductor.Whentheprimaryswitchturnsoff,theflybackfromtheleakageinductanceandmagnetizinginductanceflowsthroughtheclampdiodesD1andD2,clampingtheflybackoftheprimaryandreturningtheenergyfromthemagnetizinginductanceofthetransformertotheprimarypowerbus(C1In).Theoutputinductorandoutputcapacitorstoreenergyandintegratethedutycyclesothattheoutputvoltageisproportionaltotheproductoftherectifiedoutputvoltageanddutycycle(seebelow).[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096129585.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096129776.gif');}"onmousewheel="returnimgzoom(this);">
Single Forward Converter
INTRODUCTION:
The single transistor forward converter offers some significant performance advantages compared to the flyback SMPS converter, but at the cost of many additional components. Instead of combining energy storage and voltage isolation/conversion in one magnetic component, a separate transformer and output filter inductor are used. They permit more favorable trapezoidal current waveforms and lower output current and voltage ripple, thus reducing noise and decreasing stress on semiconductors and capacitors. In a conventional scheme, the transformer reset occurs after the power transfer cycle, and requires that the input transistor blocks a minimum of twice the input voltage. For a maximum rectified bus voltage of 360V, a VDS rating of 800V is required for the power transistor Q1, unless alterations to the maximum duty cycle, and special clamp winding arrangements are made to lower the reflected voltage on Q1.
Energy transfer occurs across the isolation transformer. When the power transistor Q1 turns on, the primary voltage is reflected across the output windings and then rectified by CR1, charging the output inductor. When the primary switch turns off, the bifilar primary clamp winding conducts through the clamp diode, clamping the drain voltage of Q1 at twice the input voltage, and returning the energy from the magnetizing inductance of the transformer to the primary power bus (C In). The driven side of the output inductor is clamped at 0.7 volts below ground by the recirculating diode. The output inductor and output capacitor store energy and integrate the duty cycle in such a manner that the output voltage is proportional to the product of the rectified output voltage and duty cycle (see frame below).
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096129929.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096129939.gif');}" onmousewheel="return imgzoom(this);">
power-wang
@power-wang
SingleForwardConverter    INTRODUCTION:ThesingletransistorforwardconverterofferssomesignificantperformanceadvantagescomparedtotheflybackSMPSconverter,butatthecostofmanyadditionalcomponents.Insteadofcombiningenergystorageandvoltageisolation/conversioninonemagneticcomponent,aseparatetransformerandoutputfilterinductorareused.Theypermitmorefavorabletrapezoidalcurrentwaveformsandloweroutputcurrentandvoltageripple,thusreducingnoiseanddecreasingstressonsemiconductorsandcapacitors.Inaconventionalscheme,thetransformerresetoccursafterthepowertransfercycle,andrequiresthattheinputtransistorblocksaminimumoftwicetheinputvoltage.Foramaximumrectifiedbusvoltageof360V,aVDSratingof800VisrequiredforthepowertransistorQ1,unlessalterationstothemaximumdutycycle,andspecialclampwindingarrangementsaremadetolowerthereflectedvoltageonQ1.BASICSOFOPERATION:Energytransferoccursacrosstheisolationtransformer.WhenthepowertransistorQ1turnson,theprimaryvoltageisreflectedacrosstheoutputwindingsandthenrectifiedbyCR1,chargingtheoutputinductor.Whentheprimaryswitchturnsoff,thebifilarprimaryclampwindingconductsthroughtheclampdiode,clampingthedrainvoltageofQ1attwicetheinputvoltage,andreturningtheenergyfromthemagnetizinginductanceofthetransformertotheprimarypowerbus(CIn).Thedrivensideoftheoutputinductorisclampedat0.7voltsbelowgroundbytherecirculatingdiode.Theoutputinductorandoutputcapacitorstoreenergyandintegratethedutycycleinsuchamannerthattheoutputvoltageisproportionaltotheproductoftherectifiedoutputvoltageanddutycycle(seeframebelow).[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096129929.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096129939.gif');}"onmousewheel="returnimgzoom(this);">
Half Bridge Converter
INTRODUCTION:
This converter design offers the possibility of reducing the size of the transformer by nearly 1/2 compared with the single transistor forward converter, because it's single ended push-pull configuration uses the transformer flux in both directions. It doesn't require a clamp winding, but does require two output windings, to support both polarities of output drive from the transformer. By replacing the small flux balance cap with a resonant network, it is possible to easily make a resonant mode converter, with very low switching losses because the voltage turn-on and turn-off occurs at very low current. The body diodes of the switching transistors Q1 and Q2 provide clamping of turn-off transients due to leakage inductance, so avalanche is not normally an issue with this topology.
Energy transfer occurs across the isolation transformer, in single ended push-pull. First, when the power transistor Q1 turns on the primary voltage is reflected across the output windings, and rectified by CR1, charging the output inductor. When Q1 turns off, the voltage drive across the transformer primary drops to zero, and energy stored in the leakage and magnetizing inductances causes a turn-off overshoot, which is clamped by the body diode of Q2. In the second stage, Q2 turns on, and the transformer is driven in the opposite direction, resetting the flux balance in the transformer core. The output of the transformer is connected to a half wave rectifier, so the alternating polarity pulse train is rectified into a unidirectional pulse train of twice the frequency. The output capacitor and inductor store energy and integrate the duty cycle so that the output voltage is proportional to the product of the rectified output voltage and duty cycle (see below).500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096130015.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096130024.gif');}" onmousewheel="return imgzoom(this);">
power-wang
@power-wang
HalfBridgeConverter    INTRODUCTION:Thisconverterdesignoffersthepossibilityofreducingthesizeofthetransformerbynearly1/2comparedwiththesingletransistorforwardconverter,becauseit'ssingleendedpush-pullconfigurationusesthetransformerfluxinbothdirections.Itdoesn'trequireaclampwinding,butdoesrequiretwooutputwindings,tosupportbothpolaritiesofoutputdrivefromthetransformer.Byreplacingthesmallfluxbalancecapwitharesonantnetwork,itispossibletoeasilymakearesonantmodeconverter,withverylowswitchinglossesbecausethevoltageturn-onandturn-offoccursatverylowcurrent.ThebodydiodesoftheswitchingtransistorsQ1andQ2provideclampingofturn-offtransientsduetoleakageinductance,soavalancheisnotnormallyanissuewiththistopology.BASICSOFOPERATION:Energytransferoccursacrosstheisolationtransformer,insingleendedpush-pull.First,whenthepowertransistorQ1turnsontheprimaryvoltageisreflectedacrosstheoutputwindings,andrectifiedbyCR1,chargingtheoutputinductor.WhenQ1turnsoff,thevoltagedriveacrossthetransformerprimarydropstozero,andenergystoredintheleakageandmagnetizinginductancescausesaturn-offovershoot,whichisclampedbythebodydiodeofQ2.Inthesecondstage,Q2turnson,andthetransformerisdrivenintheoppositedirection,resettingthefluxbalanceinthetransformercore.Theoutputofthetransformerisconnectedtoahalfwaverectifier,sothealternatingpolaritypulsetrainisrectifiedintoaunidirectionalpulsetrainoftwicethefrequency.Theoutputcapacitorandinductorstoreenergyandintegratethedutycyclesothattheoutputvoltageisproportionaltotheproductoftherectifiedoutputvoltageanddutycycle(seebelow).[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096130015.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/21/1096130024.gif');}"onmousewheel="returnimgzoom(this);">
Phase shifted ZVT Bridge Converter
INTRODUCTION:
This topology presents a significant complexity compared to the conventional H Bridge because of the control scheme necessary to achieve Zero Voltage Transitions and essentially eliminate switching losses. Instead of using the simple anti-phase PWM modulation, unique timing signals are generated for each switching transistor, so that each side of the H bridge switches roughly in a square wave fashion at drive points A and B, and the displacement in phase between the square wave drives produces an effective PWM. The key advantage is that the drain to source transitions of each transistor are powered by the energy stored in the leakage inductance, or a primary resonant inductor. Each transistor turns on with 0V drain to source over a wide load range. The benefit lies in eliminating almost all of the switching losses of the MOSFET transistors, making possible increases in the operating frequency, reductions in the volume of the transformer and inductors.
Energy transfer occurs across the isolation transformer in balanced push-pull. Key to the operation with no switching losses is the use of a phase shifted modulation scheme, using square waves on both sides of the transformer primary, and controlling the duty cycle across the transformer primary by changing the effective phase between the two square waves. To limit losses, drain to source transitions occur when one transistor in a leg turns off, and the inductance slews the drain to source voltage to the opposite potential, after which the other transistor is turned on. This requires the delays in switching control shown in Delay 1/2 and Delay 3/4, which shows in an exaggerated manner for clarity the timing delays required (see below).
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096130092.gif');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/21/1096130099.gif');}" onmousewheel="return imgzoom(this);">
power-wang
欢迎各位探讨有关电源技术方面的东东,让所有的电源工程师共同进步!
maty
@power-wang
辛苦了!
我頂!
hu303700788
請問DX這個心片可以做到多少W呀
我現在做到600W但是有異音
不知道怎麼解決能幫幫我嗎
yjhudaqing@126.com
hu303700788
我用是的ICE1PCS01心片作APFC電路.
shijian0021
@hu303700788
请问芯片辅助电源怎样解决的?好像自反馈供电起动不了.需要外加辅助电源.
power-wang
@hu303700788
請問DX這個心片可以做到多少W呀我現在做到600W但是有異音不知道怎麼解決能幫幫我嗎yjhudaqing@126.com
肯定没有问题啊,您如果需要什么帮助的话,可以直接和我联系,我会尽自己的努力为各位服务!大家要是有什么问题,可以直接电话或者是电子邮件与我联系:
   Tel: 021-64403296
   E-mail: sh9813@163.com
           colin.wang@sterntec.com.cn
   Contact: Colin
power-wang
@shijian0021
敢问兄弟使用的是那颗IC,变压器的磁气结构是什么?还有就是参数?
shijian0021
@power-wang
用的ice1pcs01做功率因数较正,用铁硅铝磁环作升压电感,从电感上饶几匝作辅助电源,不能起动.(其他公司的功率因数较正可以这样用)
hu303700788
@shijian0021
外加電源VCC用78L15供給
電感用S1300061A的鐵心
請問能做到多少W呢
hu303700788
@power-wang
肯定没有问题啊,您如果需要什么帮助的话,可以直接和我联系,我会尽自己的努力为各位服务!大家要是有什么问题,可以直接电话或者是电子邮件与我联系:  Tel:021-64403296  E-mail:sh9813@163.com          colin.wang@sterntec.com.cn  Contact:Colin
能幫我算一下電感嗎
用那一種鐵心好一點呢
我現在要作到850W不知道能做到嗎?
shijian0021
@hu303700788
外加電源VCC用78L15供給電感用S1300061A的鐵心請問能做到多少W呢
需外加电源,和其它功率因数较正ic相比 失去优势
power-wang
@shijian0021
需外加电源,和其它功率因数较正ic相比失去优势
可以不要啊,只要你把那个电感设计好了,其他的都没有问题啊
lsjiang
@shijian0021
你提出的问题也有道理!
但是,你是否注意到这颗IC.他的优点就在于,它在APFC、PWM组合应用的时候,优点就发挥出来了.启动过程是:PWM电路先工作,电路中可以设置一个时间延时电路,PWM电路工作后,自动开启APFC部分,这样可以减少整个电路启动时的瞬时功率,和APFC输出电压对MOS管造成的应力冲击.也可一说,这样的组合是一个软启动的过程,有利于整个系统的可靠性.
hu303700788
@power-wang
colin:
你好!
我現在能做到600W
但是我把功率加到700W的時候就發出異音.
是電感發出來的
請問可以從電路上解決嗎
電感是S130061A鐵心,繞了40.5Ts
hu303700788
@power-wang
請問電感怎樣設計呢
我那樣設計的有問題嗎
pietyknight
实在是感谢你啊!!!
power-wang
@pietyknight
实在是感谢你啊!!!
没有什么客气的,大家来到这里的目的就是互通有无啊!
power-wang
@shijian0021
您的供电方式是什么类型的?有没有采用两种供电方式同时进行?就是PFC电感和PWM变压器同时都给芯片供电?!
qdchb
2004-10-06 11:04
@hu303700788
我也是用的ICE1PCS01做PFC电路,它的升压电感设计起来的确有些问题,不知道哪位大侠能够指点一二.
llhylyl
2009-09-29 15:03
@power-wang
路过
