我开发了DC12 DC20V/4A升压模块(图),找合作开发销售的投资商
俺的非隔离型电源模块!升压输出20V/4A,不用变压器!!!输入为DC9-18V,输出DC20V/4A,效率90%.请大家指正!!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162814529.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
带笔记本的照片
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162962955.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162962987.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
系统正在启动
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162963046.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
看清楚了!!!电池可是拿掉了的,技术人员绝对不能打诳语!!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162963128.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
已进入系统!!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162963162.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(36)
pi-power
顶!!!!顶!!!!顶!!!!顶!!!!
pi-power
@pi-power
DC24V/DC20V是否可以做出来??? 体积能做到多少??
pi-power
@jacky.chan
DC24V/DC20V是否可以做出来???体积能做到多少??
可以
体积45*40*14
可以吗?
还可以适当小点
pi-power
pi-power
@pi-power
顶得好啊 顶得妙啊
大家顶啊!!
pi-power
@pi-power
顶得好啊顶得妙啊大家顶啊!!
大家都有很成熟的产品???
拿出来看看,都学习学习嘛!!!
pi-power
@pi-power
大家都有很成熟的产品???拿出来看看,都学习学习嘛!!!
我可以给大家批量做这款模块,价格相当低!!
kingmusic
能否把效率再做高一点,体积再小一点,元件少点,单路输出,输出为22v,5a,传导散热
qq:499617551
jacky.chan
@pi-power
可以体积45*40*14可以吗?还可以适当小点
输入:24V(18-36)V
输出:16V/4.7A
工作频率要160KHZ(避开200KHZ),还要考虑散热情况!环境温度是55度,设备内部放热器件比较多,所以散热情况要比较好!    能不能做好??
我已经拿到2只样品,体积比较大!价格也高!
pi-power
@kingmusic
能否把效率再做高一点,体积再小一点,元件少点,单路输出,输出为22v,5a,传导散热qq:499617551
可以,你的输入是多少?
pi-power
@jacky.chan
输入:24V(18-36)V输出:16V/4.7A  工作频率要160KHZ(避开200KHZ),还要考虑散热情况!环境温度是55度,设备内部放热器件比较多,所以散热情况要比较好!    能不能做好??我已经拿到2只样品,体积比较大!价格也高!
下次一定做到你满意!!
pi-power
@pi-power
可以,你的输入是多少?
pi-power
新的模块方案:
DC12V TO 5V/20A方案样板  体积:50*30*14
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164807544.gif');}" onmousewheel="return imgzoom(this);">
DC12V TO 5V/10A方案样板  体积:50*30*14
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164807861.gif');}" onmousewheel="return imgzoom(this);">
DC12V TO 12V/3A 7V/3A方案样板  体积:58*50*14 半砖左右
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164808002.gif');}" onmousewheel="return imgzoom(this);">
DC12V TO 24V/6A方案样板 体积:50*30*14
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164808090.gif');}" onmousewheel="return imgzoom(this);">
请大家关注!!
pi-power
@pi-power
新的模块方案:DC12VTO5V/20A方案样板  体积:50*30*14[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164807544.gif');}"onmousewheel="returnimgzoom(this);">DC12VTO5V/10A方案样板  体积:50*30*14[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164807861.gif');}"onmousewheel="returnimgzoom(this);">DC12VTO12V/3A7V/3A方案样板  体积:58*50*14半砖左右[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164808002.gif');}"onmousewheel="returnimgzoom(this);">DC12VTO24V/6A方案样板体积:50*30*14[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164808090.gif');}"onmousewheel="returnimgzoom(this);">请大家关注!!
请大家关注!!
pudafu1
@pi-power
请大家关注!!
关注中!
pudafu1@163.com
pi-power
@pudafu1
关注中!pudafu1@163.com
有需要请联系我!
我电话:13477121678 陈生
QQ:14404288  tujiaren1980@126.com
pi-power
@pi-power
大家看看实际的样板
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165338298.jpg');}" onmousewheel="return imgzoom(this);">
左边是30*50MM 的DCDC模块
参数为 DC7-18V输入 16V/3A输出 纹波50mV
左边是33*77MM 的DCDC模块
参数为 DC7-18V输入 16V/3A+5V/3A输出 纹波50mV
pi-power
@pi-power
大家看看实际的样板[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165338298.jpg');}"onmousewheel="returnimgzoom(this);">左边是30*50MM的DCDC模块参数为DC7-18V输入16V/3A输出纹波50mV左边是33*77MM的DCDC模块参数为DC7-18V输入16V/3A+5V/3A输出纹波50mV
30*50MM 的DCDC模块
DC7-18V输入 5V/10A输出 纹波30mV
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165488152.gif');}" onmousewheel="return imgzoom(this);">
pi-power
@pi-power
30*50MM的DCDC模块DC7-18V输入5V/10A输出纹波30mV[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165488152.gif');}"onmousewheel="returnimgzoom(this);">
30*50MM 的DCDC模块
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165765675.jpg');}" onmousewheel="return imgzoom(this);">
pi-power
@pi-power
30*50MM的DCDC模块DC7-18V输入5V/10A输出纹波30mV[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165765675.jpg');}"onmousewheel="returnimgzoom(this);">
DC12TO5V/3A 效率95% 体积20X26X7.5MM
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165938988.jpg');}" onmousewheel="return imgzoom(this);">
monkeyhz
@pi-power
DC12TO5V/3A效率95%体积20X26X7.5MM[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165938988.jpg');}"onmousewheel="returnimgzoom(this);">
我需要DC12TO24V12A,的电源,要求电路板体积是80MMx80MM.
PI-POWER,可以提供吗.我的邮箱是kill_eweee@163.com
pi-power
@monkeyhz
我需要DC12TO24V12A,的电源,要求电路板体积是80MMx80MM.PI-POWER,可以提供吗.我的邮箱是kill_eweee@163.com
可以做
有现在的方案,但得加风扇!!请联系!
我的QQ:14404288
Email:tujiaren1980@126.com
电话:13477121678 陈生
pi-power
@pi-power
可以做有现在的方案,但得加风扇!!请联系!我的QQ:14404288Email:tujiaren1980@126.com电话:13477121678陈生
请大家关注!!
grace123456
@pi-power
左边是33*77MM 的DCDC模块
参数为 DC7-18V输入 16V/3A+5V/3A输出 纹波50mV 这款价格如何.是隔离式的吗?E-mail:jinyinh@163.com
pi-power
@grace123456
左边是33*77MM的DCDC模块参数为DC7-18V输入16V/3A+5V/3A输出纹波50mV这款价格如何.是隔离式的吗?E-mail:jinyinh@163.com
非隔离的!
有需求请联系我
13477121678  0717-6331995 QQ:14404288
pi-power
@pi-power
非隔离的!有需求请联系我tujiaren1980@126.com13477121678  0717-6331995QQ:14404288
顶!!顶!!
jacky.chan
@pi-power
顶!!顶!!
ding ding ding  ~~~~全部顶掉之后就再也顶不起来啦~~~大哥~~~ 哈哈
pi-power
2006-12-25 14:12
车载的 5V/4A 电源 带线
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1167027128.jpg');}" onmousewheel="return imgzoom(this);">
pi-power
2007-01-23 19:30
12V4A样板(输入电压7-36V,效率90%)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/49/1169551489.jpg');}" onmousewheel="return imgzoom(this);">
3.3V/3A样板(输入电压9-16V,效率92%)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/49/1169551525.jpg');}" onmousewheel="return imgzoom(this);">
16V/3A+5V/3A样板 带ITPS功能和单片机电源管理  非常适合于车载!!(输入电压7-16V,效率91%)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/49/1169551603.jpg');}" onmousewheel="return imgzoom(this);">
请大家提意见!!
