什么是凡立水?
各位好!问一个很弱的问题:什么是凡立水?有什么作用?
全部回复(9)
自己先顶一下,怎么没人理呀!
就是绝缘油漆.
gang1379
金山词霸2002是这样解释的:
varnish
AHD:[v鋜搉箂h]
D.J.:[6v$8ni.]
K.K.:[6v$n!.]
n.
A paint containing a solvent and an oxidizing or evaporating binder, used to coat a surface with a hard, glossy, transparent film.
The smooth coating or gloss resulting from the application of this paint.
Something suggestive of or resembling varnish.
A deceptively attractive external appearance; an outward show.
varnish
v.tr.
var.nished; var.nish.ing; var.nish.es;
To cover with varnish.
To give a smooth and glossy finish to.
To give a deceptively attractive appearance to; gloss over.
Middle English vernisshe
fromOld French vernis
fromMedieval Latin veronix, vernix[ sandarac resin ]
fromLate Greek verenik?
fromGreek Berenik禰 Berenice (Benghazi), an ancient city of Cyrenaica ]
var搉isher n
varnish
AHD:[v鋜搉箂h]
D.J.:[6v$8ni.]
K.K.:[6v$n!.]
n.
清漆,罩光漆一种颜料,含有溶解剂和氧化或脱水的粘合剂,用于把表面涂成坚硬的,有光泽的透明的膜
光泽面光滑的涂层或光泽面,通过这种漆的运用而得到的
假漆让人联想起清漆或与清漆相似的东西
虚饰,外表骗人的吸引人的外表;外在的表现
varnish
v.tr.
覆盖有清漆
使有光泽对…施加光滑的并有光泽的润饰
粉饰,文饰给…欺骗性有吸引人的外表;掩饰
中古英语 vernisshe
源自古法语 vernis
源自中世纪拉丁语 veronix, vernix[ 香松树脂 ]
源自后期希腊语 verenik?
源自希腊语 贝勒耐克[ 贝勒奈西(Benghazi),昔兰尼加的一座古老的城市 ]
var搉isher n
varnish
[5vB:nIF]
n
清漆
(清漆形成的)光泽面
The varnish protected the table from being damaged.
光泽面保护桌子不受损坏.
varnish
vt
涂清漆
掩饰;粉饰
camouflage coat color disguise distort falsify lacquer misrepresent paint shellac
varnish
[5vB:niF]
n.
清漆, 亮漆, 釉子
表面光泽, (瓷器等)光泽面
指甲油
[喻]掩饰; 文饰
[pl. ](=varnished car)[俚]旅客列车
She covers her selfishness with a varnish of good manners.
她用一种表面上很有礼貌的态度来掩饰她的自私.
varnish
[5vB:niF]
vt.
给...上清漆, 涂油漆于
文饰; 掩饰
Scrape the old paint off, sand the surface down, and then varnish over it.
刮掉旧漆, 用砂纸将表面打磨光, 然后涂漆.
varnish
[5vB:niF]
vi.
涂饰清漆
varnished
adj.
浸渍过的, 涂漆的
varnisher
n.
varnishing
n.
上漆
varnishy
adj.
清漆的, 与清漆有关的或类似清漆的
put a varnish on  ...
文饰, 掩饰
varnish over
涂漆
acid resisting black varnish
耐酸沥青(黑)漆
adhesive varnish
粘合清漆
agricultural varnish
农业用清漆
air dried coil varnish
自干绕组清漆; 自干线圈清漆
air drying varnish
气干清漆; 自干清漆
alcohol varnish
醇溶性清漆
alkali-proof varnish
耐碱清漆
alkyd varnish
醇酸清漆
alkyd resin varnish
醇酸(树脂)清漆
amber varnish
琥珀上光油(由琥珀、亚麻仁油、松节油制成的优质上光油)
antiseptic varnish
上光油
anti-tracking varnish
防迹漆(在高电压下不起碳黑迹)
asphalt varnish
沥青漆
bakelite varnish
电木漆, 胶木漆
baking varnish
烘干清漆; 烤干清漆
baking black varnish
(黑)沥青(清)烘漆; 沥青(黑)烤漆
bitumen varnishes
【有化】沥青清漆
bituminous varnish
沥青(清)漆
black varnish
黑色假漆
black backing varnish
(地沥青)黑底漆
boat varnish
船用清漆
body varnish
车身漆
bookbinders' varnish
书脊清漆
bronze varnish
金胶(配金、银粉漆用的漆料); 大漆
cable varnish
电缆漆
cellulose varnish
纤维素清漆
cellulosic varnish
纤维素涂料
chian varnish
醇溶性松香清漆
松香钙脂清漆
Chinese varnish
清漆
church oak varnish
短油内用清漆, 教堂栎木清漆
clear finishing varnish
上光涂料
coach varnish
制作不善的上光油(如亚麻仁油在开着盖子的壶里煎制)
coating varnish
罩光清漆
coil varnish
线圈漆, 线圈绝缘
coil finishing varnish
(电机)绕圈覆盖清漆
coil impregnating varnish
绕组浸渍漆
cold-cut varnish
冷溶清漆
colored varnish
透明(着)色漆
confectioners' varnish
防止点心粘黏模型的涂料
copaiba varnish
苦配巴上光油(一种南美产树液)
copal varnish
柯巴上光油(用于透明底色和上光)
core varnish
硅钢片清漆; 磁心清漆
crystal varnish
晶纹清漆
crystal paper varnish
(糊墙)纸用晶纹清漆
dammar varnish
达马胶漆(玻璃装饰用)
dammar picture varnish
达马上光油
dammar retouching varnish
达马修描上光油
desert varnish
【地质】沙漠岩漆
dip varnish
浸渍漆
dipping varnish
浸涂清漆
electric varnish
高度绝缘清漆
electro-insulating finishing varnish
绝缘覆盖漆
emulsified asphalt varnish
乳化沥青漆
emulsion varnish
乳液漆, 乳胶漆
enamel varnish
瓷漆
engine varnish
发动机清漆; 发动机(零件)积炭
epoxy varnish
环氧清漆
epoxy alkyd varnishes
环氧醇酸清漆
epoxy resin varnish
环氧(树脂)清漆
exterior varnish
室外用清漆
filling varnish
补充漆
fining [finishing, finish] varnish
罩面清漆
finishing varnish
罩光漆
flat varnish
平光清漆, 无光漆
flat-finish varnish
本色清漆
flatting varnish
无光清漆
floor varnish
地板清漆
food can varnish
食品罐头清漆
four hour varnish
四小时快干漆
furniture varnish
家具清漆
general-purpose varnish
通用清漆(内用, 外用均可)
gold stoving varnish
金色清烘漆
healed varnish
综清漆
high temperature varnish
高温漆
浸渍清漆
impregnating insulating varnish
浸渍绝缘清漆
insulating varnish
绝缘清漆
insulation varnish
绝缘漆
interior varnish
内用(清)漆
interior finishing varnish
内用末道清漆
内用罩光清漆
isocyanate varnish
异氰酸酯清漆
kauri varnish
贝壳杉漆
knotting varnish
木节封闭漆
lac varnish
虫胶的酒精溶液(可用作绘画基底或在涂金中稀释油彩)
lacquer varnish
亮漆, 凡立水
limed rosin varnish
钙脂清漆; 石灰松香清漆
linseed oil varnish
亚麻油凡立水, 亚麻油漆
litho varnish
平版用调墨油
lithographic varnish
石印清漆
long oil varnish
长油清漆
low-temperature varnish
低温油漆
matt picture varnish
绸面上光油
medium oil varnish
中油度清漆
melamine resin varnish
三聚氰胺(树脂)清漆
mineral varnish
石漆
natural resin varnish
天然树脂清 漆
Ningpo varnish
金漆
none gloss varnish
平光清漆; 无光清漆
oak varnish
栎木清漆; 橡木清漆
oil varnish
用于绘画或雕塑表面的光油
oil modified polyurethane varnish
油改性聚氨酯涂料
oleoresincus varnish
油基树脂清漆
overprint varnish
复印清漆(油墨)
pasteurising varnish
耐温水清漆
phenol formaldehyde varnish
酚醛清漆
phenolic resin varnish
酚醛(树脂)清漆
picture varnish
绘画用光油
polishing varnish
擦亮清漆; 擦光(清)漆
polystryrene varnish
聚苯乙烯漆
pyroxyline varnish
低氮硝化纤维漆
quick drying varnish
快干清漆
rapid-drying varnish
快干清漆
resin varnish
树脂漆
resinous varnish
树脂涂料
retouch varnish
修描润色剂; 在油画最后上光前用的无色透明上光油(如达马光油)
rosin varnish
松香清漆
rosinate varnish
松脂酸酯制清漆
rubbing varnish
可打磨清漆
screening varnish
丝漏清漆
semiconductor varnish
半导体漆
shellac varnish
虫胶清漆
short oil varnish
短油清漆
shrivel varnish
皱纹清漆
silicon(e) varnish
硅基漆
silicon steel sheet varnish
硅钢片清漆
size varnish [coating]
层底涂料
sizing varnish
封闭清漆; 上浆清漆; 贴金漆
solvent epoxy varnish
溶剂型环氧树脂
solvent silicone varnish
溶剂型有机硅清漆
solventless epoxy varnish
无溶剂环氧清漆
solventless polyester varnish
无溶剂聚酯清漆
spar varnish
桅杆清漆
spare varnish
维修用漆; 备用清漆
spirit varnish
挥发(清)漆, 酒精清漆
spraying varnish
喷涂清漆
stoving varnish
烤漆, 烘漆
taking varnish
热干燥漆, 烘漆
thermoset varnish
热固(性)清漆
thermosetting varnish
热固油漆
two container varnish
分装清漆; 两罐装清漆
under coating varnish
打底漆
volatile varnish
挥发性清漆
wrinkle varnish
皱纹清漆
varnish
[ 5vB:niF ]
n.清漆, 凡立水, 光泽面, 掩饰
v.修饰
@gang1379
金山词霸2002是这样解释的:varnishAHD:[v鋜搉箂h]D.J.:[6v$8ni.]K.K.:[6v$n!.]n.Apaintcontainingasolventandanoxidizingorevaporatingbinder,usedtocoatasurfacewithahard,glossy,transparentfilm.Thesmoothcoatingorglossresultingfromtheapplicationofthispaint.Somethingsuggestiveoforresemblingvarnish.Adeceptivelyattractiveexternalappearance;anoutwardshow.varnishv.tr.var.nished;var.nish.ing;var.nish.es;Tocoverwithvarnish.Togiveasmoothandglossyfinishto.Togiveadeceptivelyattractiveappearanceto;glossover.MiddleEnglishvernisshefromOldFrenchvernisfromMedievalLatinveronix,vernix[sandaracresin]fromLateGreekverenik?fromGreekBerenik禰Berenice(Benghazi),anancientcityofCyrenaica]var搉ishernvarnishAHD:[v鋜搉箂h]D.J.:[6v$8ni.]K.K.:[6v$n!.]n.Apaintcontainingasolventandanoxidizingorevaporatingbinder,usedtocoatasurfacewithahard,glossy,transparentfilm.清漆,罩光漆一种颜料,含有溶解剂和氧化或脱水的粘合剂,用于把表面涂成坚硬的,有光泽的透明的膜Thesmoothcoatingorglossresultingfromtheapplicationofthispaint.光泽面光滑的涂层或光泽面,通过这种漆的运用而得到的Somethingsuggestiveoforresemblingvarnish.假漆让人联想起清漆或与清漆相似的东西Adeceptivelyattractiveexternalappearance;anoutwardshow.虚饰,外表骗人的吸引人的外表;外在的表现varnishv.tr.var.nished;var.nish.ing;var.nish.es;Tocoverwithvarnish.覆盖有清漆Togiveasmoothandglossyfinishto.使有光泽对…施加光滑的并有光泽的润饰Togiveadeceptivelyattractiveappearanceto;glossover.粉饰,文饰给…欺骗性有吸引人的外表;掩饰MiddleEnglishvernisshe中古英语vernisshefromOldFrenchvernis源自古法语vernisfromMedievalLatinveronix,vernix[sandaracresin]源自中世纪拉丁语veronix,vernix[香松树脂]fromLateGreekverenik?源自后期希腊语verenik?fromGreekBerenik禰Berenice(Benghazi),anancientcityofCyrenaica]源自希腊语贝勒耐克[贝勒奈西(Benghazi),昔兰尼加的一座古老的城市]var搉ishernvarnish[5vB:nIF]n清漆(清漆形成的)光泽面Thevarnishprotectedthetablefrombeingdamaged.光泽面保护桌子不受损坏.varnishvt涂清漆掩饰;粉饰camouflagecoatcolordisguisedistortfalsifylacquermisrepresentpaintshellacvarnish[5vB:niF]n.清漆,亮漆,釉子表面光泽,(瓷器等)光泽面指甲油[喻]掩饰;文饰[pl.](=varnishedcar)[俚]旅客列车Shecoversherselfishnesswithavarnishofgoodmanners.她用一种表面上很有礼貌的态度来掩饰她的自私.varnish[5vB:niF]vt.给...上清漆,涂油漆于文饰;掩饰Scrapetheoldpaintoff,sandthesurfacedown,andthenvarnishoverit.刮掉旧漆,用砂纸将表面打磨光,然后涂漆.varnish[5vB:niF]vi.涂饰清漆varnishedadj.浸渍过的,涂漆的varnishern.varnishingn.上漆varnishyadj.清漆的,与清漆有关的或类似清漆的putavarnishon  ...文饰,掩饰varnishover涂漆acidresistingblackvarnish耐酸沥青(黑)漆adhesivevarnish粘合清漆agriculturalvarnish农业用清漆airdriedcoilvarnish自干绕组清漆;自干线圈清漆airdryingvarnish气干清漆;自干清漆alcoholvarnish醇溶性清漆alkali-proofvarnish耐碱清漆alkydvarnish醇酸清漆alkydresinvarnish醇酸(树脂)清漆ambervarnish琥珀上光油(由琥珀、亚麻仁油、松节油制成的优质上光油)antisepticvarnish上光油anti-trackingvarnish防迹漆(在高电压下不起碳黑迹)asphaltvarnish沥青漆bakelitevarnish电木漆,胶木漆bakingvarnish烘干清漆;烤干清漆bakingblackvarnish(黑)沥青(清)烘漆;沥青(黑)烤漆bitumenvarnishes【有化】沥青清漆bituminousvarnish沥青(清)漆blackvarnish黑色假漆blackbackingvarnish(地沥青)黑底漆boatvarnish船用清漆bodyvarnish车身漆bookbinders'varnish书脊清漆bronzevarnish金胶(配金、银粉漆用的漆料);大漆cablevarnish电缆漆cellulosevarnish纤维素清漆cellulosicvarnish纤维素涂料chianvarnish醇溶性松香清漆松香钙脂清漆Chinesevarnish清漆churchoakvarnish短油内用清漆,教堂栎木清漆clearfinishingvarnish上光涂料coachvarnish制作不善的上光油(如亚麻仁油在开着盖子的壶里煎制)coatingvarnish罩光清漆coilvarnish线圈漆,线圈绝缘coilfinishingvarnish(电机)绕圈覆盖清漆coilimpregnatingvarnish绕组浸渍漆cold-cutvarnish冷溶清漆coloredvarnish透明(着)色漆confectioners'varnish防止点心粘黏模型的涂料copaibavarnish苦配巴上光油(一种南美产树液)copalvarnish柯巴上光油(用于透明底色和上光)corevarnish硅钢片清漆;磁心清漆crystalvarnish晶纹清漆crystalpapervarnish(糊墙)纸用晶纹清漆dammarvarnish达马胶漆(玻璃装饰用)dammarpicturevarnish达马上光油dammarretouchingvarnish达马修描上光油desertvarnish【地质】沙漠岩漆dipvarnish浸渍漆dippingvarnish浸涂清漆electricvarnish高度绝缘清漆electro-insulatingfinishingvarnish绝缘覆盖漆emulsifiedasphaltvarnish乳化沥青漆emulsionvarnish乳液漆,乳胶漆enamelvarnish瓷漆enginevarnish发动机清漆;发动机(零件)积炭epoxyvarnish环氧清漆epoxyalkydvarnishes环氧醇酸清漆epoxyresinvarnish环氧(树脂)清漆exteriorvarnish室外用清漆fillingvarnish补充漆fining[finishing,finish]varnish罩面清漆finishingvarnish罩光漆flatvarnish平光清漆,无光漆flat-finishvarnish本色清漆flattingvarnish无光清漆floorvarnish地板清漆foodcanvarnish食品罐头清漆fourhourvarnish四小时快干漆furniturevarnish家具清漆general-purposevarnish通用清漆(内用,外用均可)goldstovingvarnish金色清烘漆healedvarnish综清漆hightemperaturevarnish高温漆impregnatingvarnish浸渍清漆impregnatinginsulatingvarnish浸渍绝缘清漆insulatingvarnish绝缘清漆insulationvarnish绝缘漆interiorvarnish内用(清)漆interiorfinishingvarnish内用末道清漆内用罩光清漆isocyanatevarnish异氰酸酯清漆kaurivarnish贝壳杉漆knottingvarnish木节封闭漆lacvarnish虫胶的酒精溶液(可用作绘画基底或在涂金中稀释油彩)lacquervarnish亮漆,凡立水limedrosinvarnish钙脂清漆;石灰松香清漆linseedoilvarnish亚麻油凡立水,亚麻油漆lithovarnish平版用调墨油lithographicvarnish石印清漆longoilvarnish长油清漆low-temperaturevarnish低温油漆mattpicturevarnish绸面上光油mediumoilvarnish中油度清漆melamineresinvarnish三聚氰胺(树脂)清漆mineralvarnish石漆naturalresinvarnish天然树脂清漆Ningpovarnish金漆noneglossvarnish平光清漆;无光清漆oakvarnish栎木清漆;橡木清漆oilvarnish用于绘画或雕塑表面的光油oilmodifiedpolyurethanevarnish油改性聚氨酯涂料oleoresincusvarnish油基树脂清漆overprintvarnish复印清漆(油墨)pasteurisingvarnish耐温水清漆phenolformaldehydevarnish酚醛清漆phenolicresinvarnish酚醛(树脂)清漆picturevarnish绘画用光油polishingvarnish擦亮清漆;擦光(清)漆polystryrenevarnish聚苯乙烯漆pyroxylinevarnish低氮硝化纤维漆quickdryingvarnish快干清漆rapid-dryingvarnish快干清漆resinvarnish树脂漆resinousvarnish树脂涂料retouchvarnish修描润色剂;在油画最后上光前用的无色透明上光油(如达马光油)rosinvarnish松香清漆rosinatevarnish松脂酸酯制清漆rubbingvarnish可打磨清漆screeningvarnish丝漏清漆semiconductorvarnish半导体漆shellacvarnish虫胶清漆shortoilvarnish短油清漆shrivelvarnish皱纹清漆silicon(e)varnish硅基漆siliconsteelsheetvarnish硅钢片清漆sizevarnish[coating]层底涂料sizingvarnish封闭清漆;上浆清漆;贴金漆solventepoxyvarnish溶剂型环氧树脂solventsiliconevarnish溶剂型有机硅清漆solventlessepoxyvarnish无溶剂环氧清漆solventlesspolyestervarnish无溶剂聚酯清漆sparvarnish桅杆清漆sparevarnish维修用漆;备用清漆spiritvarnish挥发(清)漆,酒精清漆sprayingvarnish喷涂清漆stovingvarnish烤漆,烘漆takingvarnish热干燥漆,烘漆thermosetvarnish热固(性)清漆thermosettingvarnish热固油漆twocontainervarnish分装清漆;两罐装清漆undercoatingvarnish打底漆volatilevarnish挥发性清漆wrinklevarnish皱纹清漆varnish[5vB:niF]n.清漆,凡立水,光泽面,掩饰v.修饰
多謝兩位!
@协力电子
多謝兩位!
高,实在是高哇!
smidahk
凡立水是绝缘漆的俗称,目前有一种进口的品牌用得比较多,
Dolphs绝缘漆 ,通过无卤 、UL、RoSH认证,几十年的品牌,可以到网上查查
例如:美国Dolphs(中文译读为“道尔富”也有人简称“道夫”)AC-43常温自干凡立水;它耐温高H级(180℃)以上;耐电压3000-4000伏;有较好的耐磨、抗压延伸力强等。它在常温下表干5分钟,但全干透要10h(10小时)以上。它烘干效果更好,AC-43可适用于含浸法,刷涂法及喷雾法等多种处理过程,烘烤来增其抗油性及耐化学性。为了产品的质量于美观(防止漆膜出现气泡)我建议先用60℃-80℃烘烤5分钟左右,然后再用100℃以上温度烘烤。一般处理过程在110℃温度下仅需1小时即可完成。如果预缩短其烘烤时间可于148℃温度下烘烤10-15分。钟而且AC-43经烘烤后会于产品上覆盖一层薄膜以增加其强度及连接性。在作业流程中我建议加配15%之稀释剂比例调合使用。
烘干绝缘漆凡立水:有高温烘烤(130℃以上温度)凡立水;低温烘烤(130℃以下)凡立水。例如美国Dolphs公司产品:BC-346A高温烘烤是凡立水;它耐温高(240℃),烘烤温度也高,耐电压5000伏以上,在各方面指标都很优越。它受美国国防部认定产品,它深受电气产品与电子零件,各类型线圈、马达、变压器、发电机、电机等生产用户的青睐。在近期有些新用户反映产品有漆膜气泡、有铁锈铜釉的颜色出现。他们以为是产品有水分,其实是操作流程有点误。在目前市场上Dolphs公司产品没有仿制品。我们常看的资料操作流程大致是:
将凡立水调解到合适稀释的浓度,产品预热到105℃,然后 冷却至65℃至75℃, 浸没于凡立水中,15-30分钟待气泡消失为止,将产品滴干15-30分钟。(我建议为了产品更强的结合力,滴干时间愈短愈好)。
烤箱烘烤操作时间 2.5-5小时 135℃; 1.5-4小时 150℃;1-2小时 165℃
如果把烤箱烘烤时间改动一下,一切都OK。那些漆膜气泡、铁锈铜釉的颜色都没了。我们先用低温80℃-100℃烘烤1小时左右,然后再用高温130℃温度烘烤,以此类推,产品自然完美。
凡立水的耐温等级是指最高允许工作温度(℃);超越后绝缘漆会炭化。它的耐温等级为:Y级(90℃)、A级(105℃)、E级(120℃)、B级(130℃)、F级(155℃)H级(180℃)、C级(200℃)、S级(240℃)。这些等级中B,F,H级在市场上较广。 中国总代理   质量价格有保证,新产品合成石 15195632536吴斌
凡立水就是你绕完变压器要泡一会的那水,味道很不好闻,泡上十五分钟,再把变压器放到烤箱里面去烤。你的变压器就OK啦
xu20110617
@富华黄先生
高,实在是高哇!
凡立水是绝缘漆的俗称。是以高分子聚合物为基础,能在一定的条件下固化成绝缘膜或绝缘整体的重要绝缘材料。一般由漆基、溶剂或稀释剂以及辅助材料三部分组成,按使用范围及形态分为:浸渍漆、覆盖漆、硅钢片漆、防电晕漆等四种。凡立水,即英文Varnish的音译。凡立水是绝缘漆的俗称.
  GB/T5206.1-1995《色漆和清漆 词汇1通用术语》规定,不再使用凡立水术语。
  清漆(凡立水)——不含着色物质的一类涂料。涂于底材时,能形成具有保护、装饰或特殊性能的透明漆膜。
  凡立水 又称假漆。人造漆的一类,有光泽,粘性好。
  主要成分是树脂和溶剂或树脂、油和溶剂。涂施于物体表面之后,溶剂挥发,树脂或树脂和油结成光滑的薄膜,显出物体原有的花纹。易干耐用,并能耐酸和油。可刷、可喷、可烤。这里是制冰花漆的主要原料。选用工业品。各地油漆厂均有生产。
1、浸渍漆
  浸渍漆分为有溶剂和无溶剂漆两大类,主要用于浸渍电机、电器的线圈和绝缘零部件,以填充其间隙和微孔,浸渍漆固化后能在浸漆物表面
  形成连续平整的漆膜,并使线圈粘结成一个结实的整体,以提高绝缘结构的耐潮、导热、介电强度和机械强度的性能。
2、覆盖漆
  硅钢片漆覆盖漆可分为表面瓷漆和清漆,干燥方式有烘干和自干性等。
  绝缘漆的选择应具有良好的介电性能,有较高的绝缘电阻和电气强度;与电机电器使用环境相匹配的耐热性能;良好的机械性能和耐磨性能;良好的导热性和防潮性能;经济、可靠,来源广泛等。
  耐热等级: 最高允许工作温度(℃)
  Y:90 用未浸渍过的棉纱、丝及纸等材料或其组合物所组成的绝缘结构
  A:105 用浸渍过的或浸在液体电介质(如变压器油中的棉纱、丝及纸等材料或其组合物所组成的绝缘结构)
  E:120 用合成有机薄膜、合成有机瓷漆等材料其组合物所组成的绝缘结构
  B:130 用合适的树脂粘合或浸渍、涂覆后的云母、玻璃纤维、石棉等,以及其他无机材料、合适的有机材料或其组合物所组成的绝缘结构
  F:155 用合适的树脂粘合或浸渍、涂覆后的云母、玻璃纤维、石棉等,以及其他无机材料、合适的有机材料或其组合物所组成的绝缘结构
  H:180 用合适的树脂(如有机硅树脂)粘合或浸渍、涂覆后的云母、玻璃纤维、石棉等材料或其组合物所组成的绝缘结构
  C:180以上 用合适的树脂粘合或浸渍、涂覆后的云母、玻璃纤维、以及未经浸渍处理的云母、陶瓷、石英等材料或其组合物所组成的绝缘结构
凡立水功能与用途
  用于变压器、线圈、漆包线之含浸或涂装,有防潮、散热、绝缘、固定、保护线路板及美观等作用。
凡立水分类
  1、凡立水依照材料,可大概区分为以下几类:醇酸树脂类、环氧树脂类、SilicoNe(胶类)
  2、凡立水依照稀释剂用法不同,可大概区分为以下几种:溶剂型、无溶剂型、水溶性型
  3、凡立水按耐温等级之区分,常用的有:烘干型凡立水和自干型凡立水
耐温等级 耐温℃
  E级 120℃ B级 130℃ F级 155℃ H级 180℃ R级 200℃
凡立水使用工艺推荐
  1、变压器预热80~150℃,1~2小时
  a.烘干变压器中的水气;
  b.使变压器中绝缘材料更硬化(如胶带);
  c.提高凡立水含浸渗透力。2、凡立水调配
  a.溶 剂 型 添加适量稀释剂;
  b.无溶剂型 按比例调配。3、变压器须降温到50~60℃左右
  (若温度太高会缩短凡止水之可使用时间)4、含浸
  a、小变压器可不抽真空,直接放入凡立水含浸10分钟左右:
  b.大变压器或不规则变压器须放入含浸槽抽贞空含浸。
  ①干抽真空到75mmHg以上10分钟 ②引入凡立水浸泡变压器近10分钟
  ③保持真空75mmHg以上10分钟 ④破除真空
  5、静置: a.大变压器静置一段时间(静置时间以凡立水不堆积在底部为原则),一般15~30分钟:
  b、小变压器用东西擦一擦底部即可。
  6.烘干: a.自干型,以自然固化为原则;
  b.加温型,80~150℃×1~4hrs(因变压器大小,烤箱效率而定)。
 买凡立水找总代理 质量价格有保障 15195632536 吴斌
