我做的12V3W电源,有图请各位高手指点下!
还有500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165594636.gif');}" onmousewheel="return imgzoom(this);">
全部回复(17)
alex2720
AC85V输入时的原边和副边电压波
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165560950.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165561073.jpg');}" onmousewheel="return imgzoom(this);">
alex2720
AC256V输入时的原边和副边电压波
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165561495.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165561512.jpg');}" onmousewheel="return imgzoom(this);">
alex2720
@alex2720
AC256V输入时的原边和副边电压波[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165561495.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165561512.jpg');}"onmousewheel="returnimgzoom(this);">
请问高手们,这样的输入和输出正常吗?望高手指教!
叮铛
@alex2720
跟我之前做的电源波形挺像的!要看你的参数选择是不是可以用!最好的办法就是带上负载,量量电压和电流值就知道了!如果看纹波可以接上示波器看看的!
alex2720
@叮铛
这是带了负载测的,我的QQ是272399315,可以加我吗?
alex2720
@叮铛
你做的有没有正式投入生产呀?
alex2720
@叮铛
空载时是这样的
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165566961.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165566980.jpg');}" onmousewheel="return imgzoom(this);">
变压器同名端错了吧
aeolus
@alex2720
很好呀
alex2720
@heaven_meng
变压器同名端错了吧
不好意图纸搞错了,已纠正,但电路没搞错的
叮铛
@alex2720
空载时是这样的[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165566961.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165566980.jpg');}"onmousewheel="returnimgzoom(this);">
呵呵,跟我很像呢!我以前传上来让大家帮我看看的时候也是把同名端画错!我这边的电源没有正式投入生产,不过是连续转了4个小时,测出最低电压185V时的输出电压已经纹波电压,然后正常工作时的电压和空载时的电压,最后数据由老大定的参数看是不是符合结果!
   我觉得你应该根据你的设计参数来看你的电源到底合格不合格!如果符合参数而且能够正常运作,应该就可以了!
alex2720
@叮铛
呵呵,跟我很像呢!我以前传上来让大家帮我看看的时候也是把同名端画错!我这边的电源没有正式投入生产,不过是连续转了4个小时,测出最低电压185V时的输出电压已经纹波电压,然后正常工作时的电压和空载时的电压,最后数据由老大定的参数看是不是符合结果!  我觉得你应该根据你的设计参数来看你的电源到底合格不合格!如果符合参数而且能够正常运作,应该就可以了!
多谢你的指点!纹波电压的标准的多小?
叮铛
@alex2720
多谢你的指点!纹波电压的标准的多小?
这个具体看你的电源用在什么器件上了,如果对电源要求比较高,纹波也就要求小一些了,我觉得12V的电压输出10MV的纹波就在接受范围内了!
alex2720
@叮铛
很感激各位高手的指教!
@alex2720
看空载波形好像你的变压器初级电感量稍大
开拓者1
@求知星际
看空载波形好像你的变压器初级电感量稍大
那个图纸却实是错的.
alex2720
@求知星际
看空载波形好像你的变压器初级电感量稍大
正常的波形应该是怎样的?
