该D1067是单片降压开关
mode converter with a built in internal power
以一个内置的内部权力模式转换器
MOSFET. It achieves 2A continuous output
MOSFET。它达到2A的连续输出
current over a wide input supply range with
目前在宽输入电压范围
excellent load and line regulation.
优异的负载和线路调整。
The D1067 requires a minimum number of readily
该d1067需要的最小数目的容易
available standard external components.
提供标准的外部元件。
Current mode operation provides fast transient
电流模式操作提供了快速瞬态
response and eases loop stabilization.
环稳定响应和简化。
Fault condition protection includes cycle-by-cycle
故障条件下保护包括循环
current limiting and thermal shutdown. In
电流限制和热关机。在
shutdown mode the regulator draws 25μA of
关机模式得出的25μ调节
supply current.
电源电流。
可以QQ:303790057咨询资料
