好像是nom.lib 那个总的索引没有了。 每个元件的仿真库 每次都要挨个添加 太麻烦了 请高手赐教 怎么弄啊 以前在 pspice 下面的library 文件夹里面的仿真用的.lib文件 都系统都是自己就找到了 不用手动添加 。现在每个器件仿真都要手动添加 太麻烦了 。
Pspice高手请进,
![](http://www.dianyuan.com/statics/image/icon/doc.gif)
谢谢 ,我试了不行 。我知道怎么弄了
仿造nom.lib用记事本重写一个***.lib(自己命名)文件,内容如下:
* Library of My devices: Analog andDigital
* Copyright Feilong, Inc. 2010 All RightsReserved.
* $Revision: 1.3 $
* $Author: HIRASUNA $
* $Date: 11 May 2000 13:26:32 $
* $Revision: 1.4 $
* $Author: JAISWAL $
* $Date: 04 JULY 2002 14:05:32 $
* This "master library" filecalls out the other libraries which we supply.
* It takes time for PSpice to scan eachlibrary file. PSpice creates an
* index file, called .IND,to speed up the search process.
* The index file is re-created wheneverPSpice senses that it might be invalid.
* If the library search times are toolong, you may want to "comment out"
* references to device libraries which youare not using. Also, you can always
* bypass the library approach and simplycopy the model or subcircuit which you
* need directly into your circuit file.
* My Analysis libraries
.lib "此处写你要添加的库.lib"
*end of library file
然后保存成.lib文件即可。
