最近准备出国,手里面事都清理干净了,同时也整理出一些比较有价值的资料、英文原版书,放在淘宝上,欢迎有需要的兄弟看一下。
尤其是要写论文的:)
http://shop109727037.taobao.com/?spm=a1z10.5.0.0.95yJzj
李泽源先生(Dr. Fred Lee)是开关电源行业的泰山北斗,是弗吉尼亚(Virginia)电力电子中心(CPES)的灵魂人物,行业内不知道谁也不应该不知道他老人家。
CPES的优秀博士论文集:
Multiphase Voltage Regulator Modules with Magnetic Integration to Power Microprocessors
Unified Zero-Current-Transition Techniques for High-Power Three-Phase PWM Converters
Three-Phase Power Factor Correction Circuits for Low-Cost Distributed Power Systems
Design and Analyses of a Dimple Array Interconnect Technique for Power Electronics Packaging
Thermal Characterization of Die-Attach Degradation in the Power MOSFET
Performance Improvement of Power Conversion by Utilizing Coupled Inductors
Novel DC-DC Converters for High-Power Distributed Power Systems
Analysis and Evaluation of Soft-Switching Inverter Techniques in Electric Vehicle Applications
On the Circuit Oriented Average Large-Signal Modeling of Switching Power Converters and its Applications
Topology Investigation for Front-End DC-DC Power Conversion for Distributed Power System
Advanced Semiconductor Device and Topology for High Power Current Source Converter
Optimization of Power MOSFET for High-Frequency Synchronous Buck Converter
Integrated Electrical and Thermal Modeling, Analysis and Design of IPEM
High-Frequency and High -Perfomance VRM Design for the Next Generation of Processors
Generalized Frequency Plane Model of Integrated Electromagnetic Power Passives
High Frequency High-Efficiency Voltage Regulators for Future Microprocessors
Integrated EMI filters for Swtich Mode Power Supplies
Assessment of Thermal Behavior and Development of Thermal Design Guidelines for Integrated Power Electronics Modules
High Frequency, High Current Density Voltage Regulators
High Frequency, High Efficiency Two-Stage Approach for Future Microprocessors
Densification Behavior of Ceramic and Crystallizable Glass Materials Constrained on a Rigid Substrate
Distributed, Modular, Open Control Architecture for Power Conversion Systems
Characterization and Cancellation of High-Frequency Parasitics for EMI Filters and Noise Separators in Power Electronics Applications
A Novel High-Power High-Efficiency Three-Phase Phase-Shift DC-DC Converter for Fuel Cell Applications
Electrical, Magnetic, Thermal Modeling and Analysis of a 5000A Solid-State Switch Module and Its Application as a DC Circuit Breaker
Low-temperature sintering of nanoscale silver paste for semiconductor device interconnection
High-Frequency Modeling and Analyses for Buck and Multiphase Buck Converters
Modular Approach for Characterizing and Modeling Conducted EMI Emissions in Power Converters
New Multi-Pulse Diode Rectifier Average Modules for AC and DC Power System Studies
High Temperature SiC Embedded Chip Module (ECM) with Double-sided Metallization Structure
Improved Forward Topologies for DC-DC Applications with Built-in Input Filter
Planar Metallization Failure Modes in Itegrated Power Electronics Modules
Altermative Structures for Integrated Electromagnetic Passives
Investigation of High-Density Integrated Solution for the AC-DC Conversion of a Distributed Power System
An Investigation of Fundamental Frequency Limitations for HF-VHF Power Conversion
Design of High-Density Transformers for High-Frequency High-Power Converters
Investigation of Power Semiconductor Devices for High Frequency High Density Power Converters
Dynamic Performance Analyses of Current Sharing Control for DC-DC Converters
Voltage Stability and Control in Autonomous Electric Power Systems with Variable Frequency
Advanced Control Schemes for Voltage Regulators
System Level Black-Box Models for DC-DC Converters
Low Temperature Co-fired Ceramics Technology for Power Magnetics Integration
Investigation of Alternative Power Architectures for CPU Voltage Regulators
Thermal and Electrical Considerations for the Design of Highly-Integrated Point-of-Load Converters
Technology for Planar Power Semiconductor Devices Package with Improved Voltage Rating
Integrated Frequency-Selective Conduction Transmission-Line EMI Filter
Analysis and Design for a High Power Density Three-Phase AC Converter Using SiC Devices
Three Dimensional Passive Integrated Electronic Ballast for Low Wattage HID Lamps
Common Mode EMI Noise Reduction Techniques in Switch Mode Power Supplies
A High Power Density Three-level Parallel Resonant Converter for Capacitor Charging
Current-Mode Control Modeling and its Digital Application
Investigation of Multiphase Coupled-Inductor Buck Converters in Point-of-Load Applications
Investigation on Interleaved Boost Converters and Applications
Phase-Locked Loops, Islanding Detection and Microgrid Operation for Single-Phase Systems
Generalized Terminal Modeling of Electro-Magnetic Interference
An Algorithm and System for Measuring Impedance in D-Q Coordinates
Topology Investigation and System Optimization of Resonant Converters
Investigations in High Power Density EMI Filter Solutions for DC-Fed Three-Phase Motor Drive Systems
Thermo-Mechanical Reliability of Low-Temperature Sintered Attachments on Direct Bonded Aluminum (DBA) Subtrate for High-Temperature Electronics Packaging
Analysis and Design of Paralleled Three-Phase Voltage Source Converters with Interleaving
Design and Development of High Density High Temperature Power Module with Cooling System
Modeling of Power Electronics Distribution Systems with Low-Frequency, Large-Signal (LFLS) Models
Low-Profile Magnetic Integration for High-Frequency Point-of-Load Converter
Research on Topologies and Efficiency Optimization of Converters for Distributed Power Supply Systems
High Frequency, High Power Density Integrated Point of Load and Bus Converters
High Power Density and High Temperature Converter Design for Transportation Applications
AC-DC Bus-Interface Bi-Directional Converters in Renewable Energy Systems
Optimization of the power processing in photovoltaic pumping systems and single-phase conversion
Equivalent Circuit Model for Current Mode Controls and Its Extensions
High Frequency Magnetic Core Loss Study
State-Trajectory Analysis and Control of LLC Resonant Converters
Behavioral EMI Models of Switched Power Converters
Electrical Integration of SiC Power Devices for High-Power-Density Applications
Investigation of Topology and Integration for Multi-Element Resonant Converters
ETH博士学位论文内容如下:
An Ultra High-Speed Electrical Drive System 2008
Bidirectional Galvanically Isolated 25 kW 50 kHz 5 kV 700V Si-SiC SuperCascode Si-IGBT DC-DC Converter 2010
Comparative Evaluation of Three-Phase Si and SiC AC-AC Converter Systems 2010
Current Control Strategies for Multilevel Grid Connected Inverters 2007
EMC Filtering of Three-Phase PWM Converters 2007
High Efficiency Electrostatic Precipitator Systems with Low Effect on the Mains 2012
High Output Voltage Series-Parallel Resonant DC-DC Converter for Medical X-Ray Imaging Applications 2005
High Temperature Power Density Output Frequency SiC DC-AC Converter System for Hybrid Electric Vehicles 2013
Hybrid Amplifier for AC Power Source Applications 2008
Isolated Three-port Bidirectional DC-DC Converter 2010
Modeling and Multi-Objective Optimization of Inductive Power Components 2012
Modeling and Optimization of Bidirectional Dual Active Bridge DC-DC Converter Topologies 2010
Modelling and Analysis of Electric Power Systems[ETH]
Novel Hybrid Unidirectional Three-Phase AC-DC Converter Systems 2008
Optimal Modulation and Wideband Current Sensing for Three-Level PWM Rectifiers 2007
System-Oriented Efficiency Optimization of Variable Speed Drives 2012
Ultra-Compact and Ultra-Efficient Three-Phase PWM Rectifier Systems for More Electric Aircraft 2011
Ultra-Flat Isolated Single-Phase AC-DC Converter Systems 2013
Ultra-High Performance Telecom DC-DC Converter 2012
