哪家可以提供5KW PFC电源开发?
技术要求:
input : ac185v~265v , 50/60hz(select type ok!) , 1 phase
output : dc400v (+-10% adjustable ok!!)
capacity : normal 100w~3kw , max 5kw peak
power factor : 0.95 over in normal 3kw output
efficiency:0.95 over in normal 3kw output
protect : input uvp , ovp , output ocp , heat sink temperature otp (protect detect to stop & restart + led display)
methode : PFC switching frequency 20~80khz(IGBT , MOSFET ok!!) , non-isolation
type : stand alone module with fan (assembly small size , plate type good!!) - designer spec. ok!!
全部回复(4)
zbl7214
UCC28070做5KW可行
oyxw
@zbl7214
UCC28070做5KW可行
我要购买这种产品,有哪家公司有这种产品?
jim li
@oyxw
想定制开发?还有没有其他要求?
oyxw
@jim li
想定制开发?还有没有其他要求?
暂时就这些要求
