There is someone that is coming or passing away in your life around the clock, so you may lose sight of those seen, and forget those remembered. There is gain and loss in your life, so you may catch sight of those unseen, and remember those forgotten. Nevertheless, doesn‘t the unseen exist for sure? Will the remembered remain for ever?
It‘s true that we have been leading a difficult life, for we need not only to be under various external pressures, but also to be in the face of internal perplexities.You would be affected by the warmth of life if someone gives you a understanding look during your bitter struggle.Even a mere glance would make you moved and inspired.
I wouldn‘t care success or failure, for I will only struggle ahead as long as I have been destined to the distance. I wouldn‘t care the difficulties around, for what I can leave on the earth is only their view of my back since I have been marching toward the horizontal.
Regret is something that enervates our spirit, causing a greater loss than loss itself and making a bigger mistake than mistake itself, so never regret.
