AAP6153A中文规格书
AAP6153A资料中文资料PDF资料中文规格书datasheet资料下载
AAP6153A车充芯片 5V5A双路限流车充方案本公司可以协助Lay 板,调试直至产品可以大批量量产,以及帮忙过认证,提供FAE全程服务,为您提供全程无忧的服务
免费提供样品、方案开发以及技术支持,欢迎来电咨询:135547 99885 QQ:137997 1917冷先生
TheAAP6153Ais a step down PWM controller with a driving dual output current to 4.8A (2.4A+2.4A). It is designed to allow for operating a wide supply voltage range from 9V to 40V. The external shutdown function can be controlled by logic level to pull COMP/EN pin down, and then comes into standby mode. The external compensation makes feedback control have good line and load regulation with flexible external design.
TheAAP6153Aoperates in the CC(Constant output Current) mode or CV(Constant output Voltage) mode, and the OCP current value is set by current sensing resisters.
TheAAP6153Ais suitable for the DC/DC switching power applications when requested the current limit function. The devices are available in MSOP-10L packages and require very few external devices for operation.AAP6150AFEATURES
VIN Operate with 9V ~ 40V Supply Voltage
- VOUT Accuracy (VREF =1.0V) ±2.0%
- Dual-Channeling CC/CV Mode Control
- External Current Limit Setting for 2 channel
- Over Temperature Protection
- Internal Soft Start ~ 3ms
- Fixed Frequency 120KHz
- UVLO Protection (min=7V, typ=7.5V, max=8V)
- Duty Cycle Range (0~90%)
- Single Pin to External Compensation and Shutdown Control
- COUT MLCC support.
- Built in Adjustable Line-Compensation
- MSOP-10L Package
AAP6150AAPPLICATION
- Car Charger
- High-Brightness Lighting
- Portable Charger Devices
- General-Purpose DC/DC Controller with Current Limit 本公司可以协助Lay 板,调试直至产品可以大批量量产,以及帮忙过认证,提供FAE全程服务,为您提供全程无忧的服务
AAP6153A, AAP6150A, AAP6030A, AAP6040A, AAP6050A,AAP6036A,车充芯片,PDF资料,规格书,供应商,代理商,原厂,替代芯片,代替芯片,资料,中文资料,车充方案,说明书,pdf.应用电路图,datasheet,真实价格,报价,价格,一级代理,一级代理商,技术资料
