三相vienna PFC的MATLAB仿真,只加了电流环,用三个独立的电流环控制,控制不行。
threePFC0809_1.zip
用MATLAB仿真,三个电流环,调节,PFC没有实现,求大师指导。
全部回复(6)
已经被添加到社区经典图库喽
三相独立控制,有没有人懂呀,出来讨论下啦
@liuchenbaidu
用PLECS的飘过,PLECS里面有demo电路图。
@417zhouge
PLECS是什么软件,哪个版本呀,能否告知一下
@liuchenbaidu
Vienna Rectifier with Hysteresis Current Controller
This PLECS demo model shows a Vienna Rectifier with an output voltage of 700 V and an output power of 12.25 kW. The simulation combines the electrical power circuit and the cascaded controls.
Power circuit
The Vienna Rectifier is a unidirectional three-phase three-switch three-level PWM AC-DC converter:
Control
The controls are modeled with functional subsystem blocks. The controls are cascaded and consist of a current loop, a DC center point voltage loop and a DC voltage loop.
The outermost DC voltage loop regulates the sum of the two capacitor voltages using a PI controller. The controller output is the reference for the mains current amplitude IN*. This amplitude is multiplied with a three-phase sinusoidal signal which is synchronized with the mains voltages in order to obtain the three-phase mains current reference iN*. For simplicity, this sinusoidal signal is generated directly from the measured mains voltages.
The mains current reference signal is offset by a DC current reference i0*. This DC reference is the output of a PI controller regulating the difference of the two capacitor voltages.
Finally, the mains current reference signal is used by the hysteresis current controller to generate the gate signals for the semiconductor switches. Due to the operating principle of the Vienna Rectifier, the gate signal of an individual phase needs to be inverted during the negative half-wave of the corresponding mains phase voltage.
Simulation
The simulation shows the controller response to a sudden asymmetrical loading of the output voltage. The scope shows the sinusoidal mains voltage, the hysteresis controlled mains current and DC voltages of the two output capacitors.
At simulation start, the capacitors are charged from their initial 300 V to their nominal level at 350 V. At t=0.4 s, the load becomes unbalanced. Without the center point voltage controller, the capacitor voltages would also quickly become unbalanced. With the controller in operation there is only a small deviation, and the capacitors are balanced again after about 0.1 s.
Try it
This model is available in the PLECS Demo Model library provided in both versions of PLECS.
@417zhouge
ViennaRectifierwithHysteresisCurrentControllerThisPLECSdemomodelshowsaViennaRectifierwithanoutputvoltageof700 Vandanoutputpowerof12.25 kW.Thesimulationcombinestheelectricalpowercircuitandthecascadedcontrols.PowercircuitTheViennaRectifierisaunidirectionalthree-phasethree-switchthree-levelPWMAC-DCconverter:[图片]ControlThecontrolsaremodeledwithfunctionalsubsystemblocks.Thecontrolsarecascadedandconsistofacurrentloop,aDCcenterpointvoltageloopandaDCvoltageloop.[图片]TheoutermostDCvoltageloopregulatesthesumofthetwocapacitorvoltagesusingaPIcontroller.ThecontrolleroutputisthereferenceforthemainscurrentamplitudeIN*.Thisamplitudeismultipliedwithathree-phasesinusoidalsignalwhichissynchronizedwiththemainsvoltagesinordertoobtainthethree-phasemainscurrentreferenceiN*.Forsimplicity,thissinusoidalsignalisgenerateddirectlyfromthemeasuredmainsvoltages.ThemainscurrentreferencesignalisoffsetbyaDCcurrentreferencei0*.ThisDCreferenceistheoutputofaPIcontrollerregulatingthedifferenceofthetwocapacitorvoltages.Finally,themainscurrentreferencesignalisusedbythehysteresiscurrentcontrollertogeneratethegatesignalsforthesemiconductorswitches.DuetotheoperatingprincipleoftheViennaRectifier,thegatesignalofanindividualphaseneedstobeinvertedduringthenegativehalf-waveofthecorrespondingmainsphasevoltage.SimulationThesimulationshowsthecontrollerresponsetoasuddenasymmetricalloadingoftheoutputvoltage.Thescopeshowsthesinusoidalmainsvoltage,thehysteresiscontrolledmainscurrentandDCvoltagesofthetwooutputcapacitors.Atsimulationstart,thecapacitorsarechargedfromtheirinitial300 Vtotheirnominallevelat350 V.Att=0.4 s,theloadbecomesunbalanced.Withoutthecenterpointvoltagecontroller,thecapacitorvoltageswouldalsoquicklybecomeunbalanced.Withthecontrollerinoperationthereisonlyasmalldeviation,andthecapacitorsarebalancedagainafterabout0.1s.TryitThismodelisavailableinthePLECSDemoModellibraryprovidedinbothversionsofPLECS.
多谢,有这个例子可以好好看看。有机会交流
