关于占空比的资料
我现在是刚学电源,有很多知识都不知道,就象占空比的问题,我不知道怎么样来确定它,不知道在电路中怎么样设置它呢?
关于占空比的资料
全部回复(20)
@zzysccd
我也请教一下具体说,我现在用3842设计单端反激型电源,设计变压器绕组时先算原边电感量,算这个电感量就要设计占空比D,如果象你说的不用我们设置,那我该取什么值来算电感量呢???
for reference
we must set a Dmax first when we design a transformer.
Lp=VinDT/(Ipk-Imin),
Vinmin corresponds Dmin,Vinmax corresponds Dmax.
But in real circuit,maybe Dmax is not just the value you assumed.so the variation of Duty just changes the value of (Ipk-Imin),Lp is designed out to be a constant parameter.
@yakyao
占空比各种电源的占空比决定的参数应该不一样吧,我接触的开关电源都是由输入电压和输出电压决定的.考虑到电压变化范围,瞬态响应,启动等问题,决定最大占空比.
how it works?
could you explain it in detail?
I think if duty is too large,it is harmful to Vds(br),Idiode.
if duty is too small, it is harmful to Ids, Vdiode
just for reference.
just for reference.
@smps
forreferencewemustsetaDmaxfirstwhenwedesignatransformer.Lp=VinDT/(Ipk-Imin),VinmincorrespondsDmin,VinmaxcorrespondsDmax.Butinrealcircuit,maybeDmaxisnotjustthevalueyouassumed.sothevariationofDutyjustchangesthevalueof(Ipk-Imin),Lpisdesignedouttobeaconstantparameter.
糊涂
麻烦解释一下Vinmin和Dmin的关系,Vinmin是否输入的最低电压
