1. NPT(Non Punch-through) chip technology; 非冲压穿透技术
2. 10us short circuit capability (短路能力10us); 10us短路能力
3. Smaller turn-off loss ;较小的开关损失
4. Lower tail current; 较低的浪涌电流
5. Positive Temperature efficiency of Vce (on); 集电极-发射级通态电压的正面温度效应
SV-Series 1200v Application SV-系列1200V应用
1.AC&DC motor control; 交/直流马达控制
2.nverter type welder; 逆变电焊机
3.UPS/EPS power supply; UPS/EPS电源
4.Servo controller; 伺服控制器
5.Metal plating Power supply; 金属电镀电源
6.Frequency:10-30KHZ; 频率:10-30KHZ
AV-series 1200V two-pack IGBT feature AV-系列1200V二单元模块IGBT特性
1.Using new trench-gate technology; 使用新沟道门技术
2.Lower Vce (on):1.7V; 低集电极-发射极通态电压:1.7V
3.10us短路能力;
4.Lower Turn-off losses; 较低的开关损失
5.Low tail current; 较低的浪涌电流
6.Positive Temperature efficiency of Vce (on); 集电极-发射级通态电压的正面温度效应
AV-Series 1200V Application AV-系列1200V应用
2.UPS/EPS power supply; UPS/EPS电源
3.Telecommunication Power; 通信电源
4.Induction heating Power supply; 感应加热电源
5.AC TIG welding machine; 交流TIG电焊机
6.Frequency:15-40KHZ; 频率:15-40KHZ
V-series 600V two-pack IGBT Feature V-系列600V二单元模块IGBT特性
1.Using PT (Punch-through) technology; 使用冲压穿透技术
2.10us短路能力;
3.Fast-switching; 快速开关
4.Lower thermal resistance; 低热变电阻
5.Lower VCE (on); 低集电极-发射级通态电压
V-series 600V IGBT Application V-系列600V IGBT应用
1. AC&DC motor control; 交/直流马达控制
2. Inverter type welder; 逆变电焊机
3. UPS/EPS power supply; UPS/EPS电源
4. Servo controller; 伺服控制器
5. Robotics(机器人) Power supply; 机器人提供电源
6. Ferquency:10-20KHZ; 频率:10-20KHZ
AV-aeries 600V two-pack IGBT Feature AV-系列600V二单元模块IGBT特性
.Using trench-gate technology; 使用沟道门技术
.10us短力能力;
.Lower turn-off loss; 较低的开关损失
.Lower VCE(on):1.5V 低集电极-发射级通态电压:1.5V
AV-series 600V IGBT Application AV-系列600V IGBT应用
6. Ferquency:15-40KHZ; 15-40KHZ
SCR module (60A, 90A, 116A) Feature SCR模块(60A,90A,116A)特性
.High blocking voltage:1700V; 高阻断电压:1700V
.DBC-A12O3 ceramic base-plate Instead of Cu-plate; DBC-A12O3陶瓷片代替铜板
.Space & weight saving; 节省空间和重量
.Planar passivated chip design; 钝化的平面芯片设计
.High reliability in thermal circle test;高可靠性的热量循环测试
.Isolation voltage 3600V; 3600V隔离电压
SCR module main Application SCR模块主要应用
.DC motor controller; 直流马达控制
Soft-starter AC-motor controller; 软启动交流马达控制器
.Lighter ,heater; 引燃器,加热器
Temperature controller; 温度控制器
![](http://u.dianyuan.com/bbs/u/54/1835531182861122.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
深圳市山墨电子有限公司是一家专门从事电子零件代理销售及相关技术支持与服务的专业化公司,总部设在香港,在香港、深圳、广州均设经营单位.目前是韩国Fine SPN品牌的POWER SEMICONDUCTORS(功率元件如IBGT模块)的一级代理商.同时代理经销安森美ON和国际整流器公司IR的元件,是ON和IR的主要现货代理经销商.
韩国Fine SPN公司成立1990年,我们在功率模块的研发生产上已有10年的历史.在韩国,SPN是独家而且是唯一一家从事大功率的电力电子模块、IGBT模块、二极管和IPM等产品研发和生产的厂家.SPN生产的IGBT模块已经向欧洲的英国、法国、意大利、德国等国家大量出口.SPN生产的IGBT模块主要用在三个领域:(1)大功率的电力电子装置;(2)大功率的家用电器;(3)汽车电子的产业化和自动化.SPN产品已经得到韩国政府的认可,并且和韩国的几所大学和研究所取得了韩国科技部电力电子的重大项目.这些模块很快就会进入中国市场.日本的三菱公司、欧洲的STM(意法半导体),德国的IXYS等有名的模块制造公司,都是SPN的技术合作伙伴.
Fine SPN总部位于韩国ASAN市,它集高功率IGBT,二极管模块,IPM的研发,研造于一体已有六年历史,其始终致力于服务高端仪器(例如工业逆变器、电焊机、UPS、电机控制),汽车行业,以及高能低耗的家用电器(例如PDP,洗衣机,空调)等领域.
Fine SPN提供电源开关系列以及工业标准为2单元,6单元,7单元的电源模块,以及种类繁多的晶体管产品.
详细的型号规格,欢迎来电/传真查询!
地址:广州市天河区五山路267号瑞华大厦北塔18C
业务:陈 英 手机:15915846799 市话通:020-39892433
电话:020-38480873(直线) 传真:020-38480899 QQ:381779590 MSN:cysunmoon2007@hotmail.com
邮箱:CY4811978@126.COM
网址:WWW.SUNMOONSEMI.COM
