  • 论坛首页
  • PI论坛
  • 请教PI工程师:关于基于STACKFET拓扑,用TNY274G制作的700mW反激电源
PI工程师你好,现本人制作了一多路输出的反激电源,是基于STACKFET拓扑结构,芯片为TNY274G.
输入电压为300-600VDC
5路输出分别为:
1 17V/6mA   25T  isolated
2 17V/6mA   25T  isolated
3 17V/6mA   25T  isolated
4 17V/2mA   25T  same GND with 5V
5 5V/70mA   8T
变压器:
Primary:   150T 1.1mH  air gap:0.45mm
E16/5 14PIN BOBBIN,ISOLATION:800V
Test voltage:2.5kV
现在对电源已经作了一周的测试,但是效率始终不能够提高,只有45%-50%本人用5V作为反馈回路,同时由于此电源应用于solar inveter, 所以optocouple 在此项目中禁止用.因此采用的是偏置线圈的反馈,在此想请教PI的工程师,对于如此高压输入,小功率输出的电源怎样才能提高效率呢?本人期望的效率是70%,但是觉得很难,功率太小了.请PI的工程师多多赐教,给与建议.
全部回复(5)
No any answer? PI AE: could give me some suggestion on that? what kind of methods would be posibility for realizing the high efficiency aming to the high voltage input and low power output?
Today, I made some improvements on the flyback converter. Untill now the efficiency is up to 54,66% at 380VDC input. In order to make the further step on efficiency, Could PI expert bring some suggestions on that. Thx.
PI的工程师不在吗?怎么没有回复呢?自己顶一下,坛子里的电源高手给个建议,看看有没有什么办法解决效率问题,明天我会将原理图以及PCB的图放上来,请高手赐教!
@liujiehit2000
建议你做以下实验:
1.260vac输入条件下,该电源的效率,
2.260vac输入条件下,不用stack的mosfet,效率能到多少.
通常在条件2下,用274做5v输出为主的设计或者多路输出,效率也只能在70%左右,输入电压提高会使变压器及开关管的结电容损耗增加(这个你可以看380v跟600v输入时效率有无差别),另外附加的mosfet会有额外损耗,在输出功率很小的情况下,一点点多的损耗都会对效率有很大影响.
最后,建议检查一下功率计读数是否准确.
PI engineer, I have made the same experiment without stackfet topology. Then the efficiency is the same with before result. Thereby I think maybe the issue is not the IC. Until now I make some other improvment on that, and the efficiency is about 68,55%. It is little more highter than before. Now I will attachment the schematic, and please help me improve that. I hope that efficiency can reach over 70% at 750mW output power. and input voltage is from 300-600V
output power is about 750mW. 132311190300361.pdf
