UL1310與UL1012的區別?
謝謝!
全部回复(1)
zbh-2000
Power units with all outputs identified as Class 2 are covered under the Standard for Class 2 Power
Units, UL 1310.
portable, stationary, and fixed power units having an input rating of 600 volts or less, direct- and alternating- current, with at least one output not marked Class 2, and that are intended to be employed in ordinary locations, UL1012
