请高手看看我的电磁加热波形图
这是全桥电磁加热波形,不知道为什么是这样.测的是IGBT的CE极,每个都是这样,供电DC40V,没敢再提高电压,电容用的是5UF,退耦电容用的是CBB21 1UF,L=195uh,C=0.3UF,频率在30KHZ.请高手指点一二,谢谢.500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051197998867.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(47)
swq007
这是驱动波形500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051197999539.jpg');}" onmousewheel="return imgzoom(this);">
xiekui
@swq007
这是驱动波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051197999539.jpg');}"onmousewheel="returnimgzoom(this);">
没有主回路原理图,无法分析解答.
swq007
附上电路图500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198040013.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198040017.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198040024.jpg');}" onmousewheel="return imgzoom(this);">
xiekui
@swq007
附上电路图[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198040013.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198040017.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198040024.jpg');}"onmousewheel="returnimgzoom(this);">
主回路是硬开关电路,不是软开关.先加上零电压电容再说.
@swq007
CE波形和驱动波形同时显示一下才能分析出原因(最好电流也同时显示).
swq007
@xiekui
请问xiekui老师,零电压电容是指在IGBT两端加的电容吗?不好意思我刚接触这行,问了个低级的问题.电容多少合适?
swq007
@秋天的风
我这示波器好象不行,示波器X1和X2是共地的
swq007
@swq007
两只上桥C E波形 IGBT上各并了一个473电容  1 500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198077460.jpg');}" onmousewheel="return imgzoom(this);">
      2500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198077469.jpg');}" onmousewheel="return imgzoom(this);">
驱动波形500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198077492.jpg');}" onmousewheel="return imgzoom(this);">
电流波形500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198077519.jpg');}" onmousewheel="return imgzoom(this);">
@swq007
两只上桥CE波形IGBT上各并了一个473电容  1[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198077460.jpg');}"onmousewheel="returnimgzoom(this);">      2[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198077469.jpg');}"onmousewheel="returnimgzoom(this);">驱动波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198077492.jpg');}"onmousewheel="returnimgzoom(this);">电流波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198077519.jpg');}"onmousewheel="returnimgzoom(this);">
波形很好啊
swq007
@秋天的风
波形很好啊
请问秋天的风老师,我谐振电容是0.3UF,L=195uh,LC的谐振频率应该是20.8K,为什么驱动频率在30K的时候电流最大,还有就是在共模电感后面的滤波电容可以用大容量电容不?
xkw1
电容加大点!
@swq007
驱动频率在30K的时候电流最大是正常的.共模电感后面的滤波电容可以用大容量电容.驱动频率太接近谐振频率的话串联电容上的电压就会很高的.
igbtsy
@xkw1
电容加大点!
线圈的电感量要在实际工作位置放上锅测,这才是有载电感量,这样配上谐振电容计算值与实际谐振工作频率是相同的.
xiekui
@秋天的风
有锅时Q值不高,应该工作在临近谐振点,电容上电压不高,非常安全,谐振电容温升也不大,从来没有发生谐振电容有故障的情况.
swq007
@igbtsy
我是放上锅测得的电感量.不放锅的电感量是110uh
swq007
@xkw1
电容加大点!
谢谢xkw1.谢谢各位大师的指点
swq007
@xiekui
我现在用的是DC40V电压,Q值不高应该是供电电压低的原因,因手头没有调压器,且没调试好暂时不敢加高电压
swq007
@swq007
谢谢xkw1.谢谢各位大师的指点
这个波形是两只下管的CE波形,不知波形有交叉是否正常?怎样消除振荡.我用的473的电容,试过104的,振荡只是拉长了些,不知要用多少合适500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/60/1799051198337601.gif');}" onmousewheel="return imgzoom(this);">
huaxi27
@swq007
这个波形是两只下管的CE波形,不知波形有交叉是否正常?怎样消除振荡.我用的473的电容,试过104的,振荡只是拉长了些,不知要用多少合适[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/60/1799051198337601.gif');}"onmousewheel="returnimgzoom(this);">
你这是要做多大功率呀?
igbtsy
@huaxi27
你这是要做多大功率呀?
没有上足高压,没有上足功率,现在来提问题一切都为时太早了,不能说明什么问题.
lth93
@igbtsy
大家帮我看下我的栅极驱动波形:IGBT500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/61/2295811199334200.gif');}" onmousewheel="return imgzoom(this);">
xkw1
@lth93
大家帮我看下我的栅极驱动波形:IGBT[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/61/2295811199334200.gif');}"onmousewheel="returnimgzoom(this);">
幅值?
luyuc
@swq007
回9贴
存在轻微的硬开通现象,可能死区不够;
luyuc
@swq007
回19贴
波形正常
控制问题可参考
2.《嵌入性控制器的实施方案》
http://bbs.dianyuan.com/topic/196416
3.《串联谐振逆变实验 & 波形分析------ IGBT 关断与接通都不容易 》
http://bbs.dianyuan.com/topic/184342
6.《细看 ZVS 前沿、后沿、失调现象》
http://bbs.dianyuan.com/topic/196963
luyuc
@swq007
回4贴
原理图中后边一组桥臂缺少 ZVS 电容;
luyuc
回第一贴
这个波形说明主回路中有饱和型电感器,可能是由磁环绕制,将此电感器移除,再看看波形; 如果一定要加电感器,必须是开磁路的,而且承受峰值 2 倍的电流不应出现饱和迹象;
firefox886
@swq007
朋友,你的这个问题解决了吗?我现在也遇到了同样的问题,有时间交流交流!
firefox886
@firefox886
这是我测的波形图500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1340891212126036.jpg');}" onmousewheel="return imgzoom(this);">
firefox886
2008-05-31 21:25
@firefox886
这是我测的波形图[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/65/1340891212126036.jpg');}"onmousewheel="returnimgzoom(this);">
呵呵...........我的问题现在已解决了!
@luyuc
回第一贴这个波形说明主回路中有饱和型电感器,可能是由磁环绕制,将此电感器移除,再看看波形;如果一定要加电感器,必须是开磁路的,而且承受峰值2倍的电流不应出现饱和迹象;
我也碰到同样的问题,请教高手,楼主波形中的几个尖冲是何故引起,非常感谢!
--------借用一下楼主的波形,一并谢谢!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/67/2766111216560812.jpg');}" onmousewheel="return imgzoom(this);">
