![](http://u.dianyuan.com/bbs/u/26/1108551380.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
三洋快速脉冲充电器----内部解剖图片1
全部回复(191)
三洋快速脉充充电器----解剖图片2
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108551549.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108551549.jpg?x-oss-process=image/format,webp)
@大林电源
三洋快速脉充充电器----解剖图片2[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108551549.jpg');}"onmousewheel="returnimgzoom(this);">
三洋快速脉充充电器----解剖图片3
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108551796.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108551796.jpg?x-oss-process=image/format,webp)
@大林电源
三洋快速脉充充电器----解剖图片3[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108551796.jpg');}"onmousewheel="returnimgzoom(this);">
看PVB照片,3种充电器所装配的元器件有差别.
不知道楼主是否可以介绍特点及其电路?
不知道楼主是否可以介绍特点及其电路?
@大林电源
![](http://u.dianyuan.com/bbs/u/26/1108604112.jpg?x-oss-process=image/format,webp)
@大林电源
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108604112.jpg');}"onmousewheel="returnimgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108604140.jpg?x-oss-process=image/format,webp)
@大林电源
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108604140.jpg');}"onmousewheel="returnimgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108604171.jpg?x-oss-process=image/format,webp)
@大林电源
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108604171.jpg');}"onmousewheel="returnimgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108604194.jpg?x-oss-process=image/format,webp)
@abt-bj
看PVB照片,3种充电器所装配的元器件有差别.不知道楼主是否可以介绍特点及其电路?
抛砖引玉!我也想知道!我买了台NC-MQR01-S挺好用!
谁能介绍特点及其电路!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108691163.jpg');}" onmousewheel="return imgzoom(this);">
谁能介绍特点及其电路!
![](http://u.dianyuan.com/bbs/u/26/1108691163.jpg?x-oss-process=image/format,webp)
@大林电源
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108604194.jpg');}"onmousewheel="returnimgzoom(this);">
做工不错,成本不低,好象没有温度探头?如果是这样,不能算很完善.
@大林电源
是否仅仅外测2个电池是快速的,中间2个就不是快速的?
@大林电源
抛砖引玉!我也想知道!我买了台NC-MQR01-S挺好用!谁能介绍特点及其电路![图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108691163.jpg');}"onmousewheel="returnimgzoom(this);">
zt--快速充电器和超快速充电器的用途差别很大,超快速充电器更加注重充电速度,而忽略便携性,所以其体积和重量一般都比较大,而且多数还带有一个大的电源适配器,它比较适合在固定场所需要短时间内超高速完成充电的情况下使用.超快速充电器一般在充电过程中电池发热较大,对电池寿命不利.而快速充电器则更加注重兼顾充电速度和便携性,比较适合一般大众的需要.所以大家应该根据自己的使用定位确定是选择超快速充电器和快速充电器.
.要选择能够对单节电池进行充电的快速充电器(即我们通常所说的4个独立充电回路控制).虽然我们在实际使用时多数情况下都是2或4节电池同时充电,1或3节电池同时充电的情况比较少,但是只有能够对单节电池进行充电的快速充电器,才能在对每个电池进行快速充电的过程中使充电得到最好的控制.众所周知,即使是同一品牌、同一容量的电池,在使用过程中电池的性能也会出现一些差异,这种现象在国产电池中更加严重,在充电过程中如果不对每个电池进行独立控制,那就很难保证充电控制的精确性,因为将2或4节电池串联起来充电时,就会出现一节电池充满的时候而另一节电池可能还没有充满或者已经过充了,这样长期使用,对电池寿命极其不利.
.目前快速充电器的电源接入方式一般有两种,即直插式和电源线方式.这两种方式可以说是各有优缺点.直插式就是充电器本身带一个可折叠的活动电源插头,需要充电的时候只要将活动插头扳出来,直接插在墙上或桌上的接线板上就可以了.由于其电源插头是和充电器一体的,所以具有携带方便的特点,特别适合旅行时使用.这种直插式设计在绝大多数日版的快速充电器中被采用.但这种直插式充电器的缺点就是占用接线板面积较大,在接线板比较满的情况下不是很方便.电源线方式则是充电器带一根电源线,通过电源线和接线板连接,在家里使用比较方便,旅行时除充电器外还需要多带一根电源线,略显麻烦.
.按照常理,镍氢电池的记忆效应很小,在正常使用的时候是不需要放电的.在实际使用中却发现,由于数码产品耗电量较多,当提示电池没电的时候其实电池还剩余较多的电量,再通过快速充电,经过一段时间的使用,一部分电池确实会出现容量、电压降低等记忆效应,这时通过完全放电功能,就可以消除电池的这种记忆效应,恢复电池的容量.SONY公司对放电功能的使用效果进行了测试,电池初期的容量是100%,经过50次的循环使用后,电池的容量下降为87%,通过完全放电,电池的容量可以恢复到98%,可见放电功能确实有一定作用.但电池并不是每次充电前都需要放电,一般使用30-50次后,彻底放电一次即可.所以选择带放电功能的快速充电器,能够自己进行充电前的放电操作,在消除电池记忆效应方面还是有一定优势的.如果充电器没有放电功能,也可以用手电筒、剃须刀或者收音机等小电器自行放电,也能够达到消除电池记忆效应的效果,不过要手工操作,并且要注意不要过放电.
.日本品牌中的Fujifilm、Maxell、Toshiba、Olympus、Fujitsu等,其快速充电器和镍氢电池都是从SANYO OEM的,它们的快速充电器除了颜色和品牌和SANYO不同外,其内部电路和功能和SANYO对应的型号完全相同,而销售的价格却比SANYO品牌的略低,所以相对于SANYO品牌具有更高的性价比,是不错的选择.
目前日本品牌的快速充电器主要集中在三个品牌:三洋、索尼、松下.
SANYO 日本三洋是全球最大的镍氢电池生产厂家,自从几年前收购了日本东芝公司的电池部门后,技术研发得到了很大地增强,技术水平一直处于世界领先的地位,其2500mAh(Min.2300mAh)的5号(AA)镍氢充电电池目前仍然是世界上最大容量的5号镍氢充电电池.凭借着镍氢电池的技术优势,其快速充电器的技术也是十分优秀的,SANYO具有多款快速充电器产品,具体型号如下:
NC-M70 30分钟超快速充电器(日本国内专用,在中国未销售),2003年11月推出
NC-M60 1小时超快速充电器,2003年5月推出
NC-MR57 带放电功能的快速充电器,NC-MR56的升级版本,2004年8月推出
NC-M57 不带放电功能,NC-M55的升级版本,2004年8月推出
NC-M54 早期的型号,配1700mAh电池.
其中,NC-MR57是SANYO系列快速充电器中最新型号,其主要特点是:
.4回路独立控制,可以充电1-4节5号镍氢充电电池或1-2节7号镍氢充电电池,不同容量和不同型号的电池可以混合充电.
.带4个充电指示灯和1个放电指示灯,明确指示充放电状态和4个电池分别的充电状态.
.具有放电功能,可以消除电池记忆效应,放电结束后自动进行充电.
.好脉冲充电算法,充电过程中电池发热很校
.充电判断准确,加入新电池或者长期放置的电池检测机制,对这类电池充电曲线发生变化进行监视,大幅度减少充电失败的现象.
.大幅度减少因电池电极不洁或者接触不良造成的充电失败现象.
.满充电保持功能,弥补电量的自然流失,使电池始终保持满充电状态.
.具有2个快充槽,当充电1-2节电池时,可以人为选择倍速充电/快速充电.
.各种充电保护功能齐全.
.100-240V全球通用电压设计
NC-MR57(NC-MR56)的最大特点就是在充电控制方面功能最好,保护最全面,电池发热最校是购买快速充电器的首选,SANYO NC-MR57 快速充电器的参数如下:
输入:AC 100--240V 50-60Hz
输出:DC 1.2V 5号1275mA×2(Quick槽)/ 565mA×4,7号 310mA×2
放电:电流:250mA 截至电压:1.0V
体积:65×105×27.5mm,
重量:约100g
电源插头:直插式
.各种充电保护功能齐全.
.100-240V全球通用电压设计
体积:65×105×27.5mm,
重量:约100g
电源插头:直插式
@大林电源
zt--快速充电器和超快速充电器的用途差别很大,超快速充电器更加注重充电速度,而忽略便携性,所以其体积和重量一般都比较大,而且多数还带有一个大的电源适配器,它比较适合在固定场所需要短时间内超高速完成充电的情况下使用.超快速充电器一般在充电过程中电池发热较大,对电池寿命不利.而快速充电器则更加注重兼顾充电速度和便携性,比较适合一般大众的需要.所以大家应该根据自己的使用定位确定是选择超快速充电器和快速充电器..要选择能够对单节电池进行充电的快速充电器(即我们通常所说的4个独立充电回路控制).虽然我们在实际使用时多数情况下都是2或4节电池同时充电,1或3节电池同时充电的情况比较少,但是只有能够对单节电池进行充电的快速充电器,才能在对每个电池进行快速充电的过程中使充电得到最好的控制.众所周知,即使是同一品牌、同一容量的电池,在使用过程中电池的性能也会出现一些差异,这种现象在国产电池中更加严重,在充电过程中如果不对每个电池进行独立控制,那就很难保证充电控制的精确性,因为将2或4节电池串联起来充电时,就会出现一节电池充满的时候而另一节电池可能还没有充满或者已经过充了,这样长期使用,对电池寿命极其不利..目前快速充电器的电源接入方式一般有两种,即直插式和电源线方式.这两种方式可以说是各有优缺点.直插式就是充电器本身带一个可折叠的活动电源插头,需要充电的时候只要将活动插头扳出来,直接插在墙上或桌上的接线板上就可以了.由于其电源插头是和充电器一体的,所以具有携带方便的特点,特别适合旅行时使用.这种直插式设计在绝大多数日版的快速充电器中被采用.但这种直插式充电器的缺点就是占用接线板面积较大,在接线板比较满的情况下不是很方便.电源线方式则是充电器带一根电源线,通过电源线和接线板连接,在家里使用比较方便,旅行时除充电器外还需要多带一根电源线,略显麻烦..按照常理,镍氢电池的记忆效应很小,在正常使用的时候是不需要放电的.在实际使用中却发现,由于数码产品耗电量较多,当提示电池没电的时候其实电池还剩余较多的电量,再通过快速充电,经过一段时间的使用,一部分电池确实会出现容量、电压降低等记忆效应,这时通过完全放电功能,就可以消除电池的这种记忆效应,恢复电池的容量.SONY公司对放电功能的使用效果进行了测试,电池初期的容量是100%,经过50次的循环使用后,电池的容量下降为87%,通过完全放电,电池的容量可以恢复到98%,可见放电功能确实有一定作用.但电池并不是每次充电前都需要放电,一般使用30-50次后,彻底放电一次即可.所以选择带放电功能的快速充电器,能够自己进行充电前的放电操作,在消除电池记忆效应方面还是有一定优势的.如果充电器没有放电功能,也可以用手电筒、剃须刀或者收音机等小电器自行放电,也能够达到消除电池记忆效应的效果,不过要手工操作,并且要注意不要过放电..日本品牌中的Fujifilm、Maxell、Toshiba、Olympus、Fujitsu等,其快速充电器和镍氢电池都是从SANYOOEM的,它们的快速充电器除了颜色和品牌和SANYO不同外,其内部电路和功能和SANYO对应的型号完全相同,而销售的价格却比SANYO品牌的略低,所以相对于SANYO品牌具有更高的性价比,是不错的选择.目前日本品牌的快速充电器主要集中在三个品牌:三洋、索尼、松下.SANYO日本三洋是全球最大的镍氢电池生产厂家,自从几年前收购了日本东芝公司的电池部门后,技术研发得到了很大地增强,技术水平一直处于世界领先的地位,其2500mAh(Min.2300mAh)的5号(AA)镍氢充电电池目前仍然是世界上最大容量的5号镍氢充电电池.凭借着镍氢电池的技术优势,其快速充电器的技术也是十分优秀的,SANYO具有多款快速充电器产品,具体型号如下:NC-M70 30分钟超快速充电器(日本国内专用,在中国未销售),2003年11月推出NC-M60 1小时超快速充电器,2003年5月推出NC-MR57带放电功能的快速充电器,NC-MR56的升级版本,2004年8月推出NC-M57不带放电功能,NC-M55的升级版本,2004年8月推出NC-M54 早期的型号,配1700mAh电池.其中,NC-MR57是SANYO系列快速充电器中最新型号,其主要特点是: .4回路独立控制,可以充电1-4节5号镍氢充电电池或1-2节7号镍氢充电电池,不同容量和不同型号的电池可以混合充电. .带4个充电指示灯和1个放电指示灯,明确指示充放电状态和4个电池分别的充电状态..具有放电功能,可以消除电池记忆效应,放电结束后自动进行充电..好脉冲充电算法,充电过程中电池发热很校.充电判断准确,加入新电池或者长期放置的电池检测机制,对这类电池充电曲线发生变化进行监视,大幅度减少充电失败的现象..大幅度减少因电池电极不洁或者接触不良造成的充电失败现象..满充电保持功能,弥补电量的自然流失,使电池始终保持满充电状态..具有2个快充槽,当充电1-2节电池时,可以人为选择倍速充电/快速充电..各种充电保护功能齐全..100-240V全球通用电压设计NC-MR57(NC-MR56)的最大特点就是在充电控制方面功能最好,保护最全面,电池发热最校是购买快速充电器的首选,SANYONC-MR57快速充电器的参数如下:输入:AC100--240V50-60Hz输出:DC1.2V 5号1275mA×2(Quick槽)/565mA×4,7号310mA×2放电:电流:250mA 截至电压:1.0V体积:65×105×27.5mm,重量:约100g电源插头:直插式
看来,氢镍电池还是采用大电流充电为好,可以抑制电池的晶枝生长.
@大林电源
![](http://u.dianyuan.com/bbs/u/26/1108613385.jpg?x-oss-process=image/format,webp)
@大林电源
听说都是广东飞宏电子OEM的
@大林电源
请教!国内快速充电器市场!价格在什么范围!三洋的产品有没有外观专利?
大林电源网友真是问到关键问题了.我也非常头痛这个问题.
我到一些经销商哪里问,什么氢镍电池的充电器最好销售,结果是10~30元零售价的最好销.打开这种充电器,就是一个小变压器带半波整流,一个指示灯.稍微好一点点的充电器基本上无人问津.而另外的就是打洋商标的充电器好销.
我给几个朋友了单体循环寿命600次以上的氢镍电池,在这种充电器上使用,也就是几十次电池就不能够使用了.
我顺便了解客户的购买心里.客户也说,不知道什么是真名牌.用户不会是专家,无法判断.甚至在我们这个坛子里,可以判断氢镍电池充电器性能的人也不多.这样,就是一些好得出带去也难以买上好价.
所以,我认为中国不缺少优秀的工程师,太缺少优秀的营销策划的人了.
@大林电源
主控芯片是MEGA8吗?
@abt-bj
大林电源网友真是问到关键问题了.我也非常头痛这个问题.我到一些经销商哪里问,什么氢镍电池的充电器最好销售,结果是10~30元零售价的最好销.打开这种充电器,就是一个小变压器带半波整流,一个指示灯.稍微好一点点的充电器基本上无人问津.而另外的就是打洋商标的充电器好销.我给几个朋友了单体循环寿命600次以上的氢镍电池,在这种充电器上使用,也就是几十次电池就不能够使用了.我顺便了解客户的购买心里.客户也说,不知道什么是真名牌.用户不会是专家,无法判断.甚至在我们这个坛子里,可以判断氢镍电池充电器性能的人也不多.这样,就是一些好得出带去也难以买上好价.所以,我认为中国不缺少优秀的工程师,太缺少优秀的营销策划的人了.
对!英雄所见略同!"中国不缺少优秀的工程师,太缺少优秀的营销策划的人了.
@大林电源
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108613385.jpg');}"onmousewheel="returnimgzoom(this);">
Panasonic松下BQ-390 剖析内部图片
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108633485.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108633485.jpg?x-oss-process=image/format,webp)
@大林电源
Panasonic松下BQ-390剖析内部图片[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108633485.jpg');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108633561.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108633561.jpg?x-oss-process=image/format,webp)
@大林电源
Panasonic松下BQ-390剖析内部图片[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108633561.jpg');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108633612.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108633612.jpg?x-oss-process=image/format,webp)
@大林电源
Panasonic松下BQ-390剖析内部图片[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108633612.jpg');}"onmousewheel="returnimgzoom(this);">
Panasonic松下BQ-390 剖析内部图片 C
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108633677.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108633677.jpg?x-oss-process=image/format,webp)
@大林电源
Panasonic松下BQ-390剖析内部图片C[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/26/1108633677.jpg');}"onmousewheel="returnimgzoom(this);">
Panasonic松下BQ-390 剖析内部图片 D
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/26/1108633712.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/26/1108633712.jpg?x-oss-process=image/format,webp)
