大家快来看看吧....大功率灯塑件都烧没了.......有图
85W灯 点一个星期就烧成这样了.500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1879971210382627.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1879971210382642.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(29)
@凡平
是不是塑件质量问题?
塑件是没有质量问题, 烧坏塑件的灯管都已漏气了, 塑件没烧坏的灯管.灯管都黑头了. 请各位多给点意见,谢了!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1879971210470636.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/65/1879971210470651.jpg');}" onmousewheel="return imgzoom(this);">
@快乐每一天
塑件是没有质量问题,烧坏塑件的灯管都已漏气了,塑件没烧坏的灯管.灯管都黑头了. 请各位多给点意见,谢了![图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/65/1879971210470636.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/65/1879971210470651.jpg');}"onmousewheel="returnimgzoom(this);">
兄弟不要灰心.
我来说说自己的看法
灯管为什么只是一头烧毁呢?
这是典型的灯管寿终,整流效应引起灯丝损耗加大.
而且大多数情况坏的是连接到半桥的那端先坏,相对接负极的另一端
连接到半桥的我称之为热端,灯丝的溅射比较厉害.
楼上的大哥说的很有道理, 整流效应引起灯丝损耗加大. 这句话我不太明白,还请楼上的大哥出来在说说吧,在此谢过!
我来说说自己的看法
灯管为什么只是一头烧毁呢?
@快乐每一天
兄弟不要灰心.我来说说自己的看法灯管为什么只是一头烧毁呢?这是典型的灯管寿终,整流效应引起灯丝损耗加大.而且大多数情况坏的是连接到半桥的那端先坏,相对接负极的另一端连接到半桥的我称之为热端,灯丝的溅射比较厉害.楼上的大哥说的很有道理,整流效应引起灯丝损耗加大.这句话我不太明白,还请楼上的大哥出来在说说吧,在此谢过!
灯丝上的电子粉老化消耗殆尽后导致电子发射能力下降,灯丝周围形成了很强的电场,然后大量的没有与电子结合的离子就会直接轰击在灯丝上,造成灯丝温度升高.
灯丝老化极少同时发生,而先老化的灯丝在离子的轰击下加速老化并且恶化,灯管的2个方向的阻抗严重不相等.以上情况造成半桥电路中点漂移,这时灯管的整流效应便出现.
