一些电容词汇
feedback capacitance
反馈电容量
doubler, capacitive voltage
电容性电压增倍器
capacity, electrostatic
静电电容
capacity
容量;电容
capacitive voltage inverter
电容性电压反相器
capacitive voltage doubler
电容性电压增倍器
capacitive load
电容负载
capacitance, shunt
分流电容
capacitance, series
串行电容
capacitance, overlap
重迭电容
capacitance, inter-winding
跨绕线电容
capacitance, fringe
边缘电容
capacitance, feedback
反馈电容
capacitance coupling
电容耦合
capacitance
电容
body capacitance
体电容
balanced capacitance
平衡电容
Buried Capacitance
隐性电容,隐埋电容
Capacitance
电容
Inductance Capacitance Resistance
电感,电容,电阻
Inductance and Capacitance
电感和电容
unit-area capacitance
单位面积电容
shunt capacitance
分流电容
resistor-capacitor-transistor logic (RCTL)
电阻电容晶体管逻辑
permitivity
介电常数;电容率
overlap capacitance
重叠电容
near-body capacitance
近体电容
lumped capacitive load
总集电容负载
logic, resistor-capacitor-transistor (RCTL)
电阻电容晶体管逻辑
load, capacitive
电容负载
inverter, capacitive voltage
电容性电压反相器
interwinding capacitance
互绕电容
inter-winding capacitance
跨绕线电容
grid-to-plate capacitance
栅极-板极电容
fringe capacitance
边缘电容
free capacitance
分离电容
全部回复(1)
tks
