业界第一颗真正的高压inverter IC.(NXP2074)
NXP - Industry's first high-voltage full bridge inverter for LCD backlights
Published Nov 29 2007 [Printer friendly version] [Email article to a friend] [More Semiconductor articles]
Availability of its high-voltage, full bridge fluorescent backlight controller IC, the UBA2074, and its low-voltage twin, the UBA2072, has been announced by NXP Semiconductor, the independent semiconductor company founded by Philips.
Together, the device form a new family of full-bridge fluorescent backlight controller ICs, designed specifically to address the trend toward growing display sizes and supporting the increased use of high-supply voltage backlight inverter solutions in LCD-TV applications. In response to customer requests, the company will manufacture DC-AC inverter controller ICs to drive cold-cathode fluorescent lamps, CCFL, or external electrode fluorescent lamps in LCD back lighting applications to support displays of all sizes.
The NXP UBA2074 is believed to be the industry's first, true high-voltage full bridge inverter controller IC, able to directly drive up to 550V supplied full bridges without the need of external level shifters or gate drive transformer constructions. The ability to drive high voltage full-bridge inverter structures, meets the current and near future requirements of higher POWER, high and medium supply voltage full-bridge backlight inverter solutions. The IC supports the continuously increasing LCD TV panel sizes and growing backlight power requirements and enables the creation of highly efficient high-power fluorescent backlight inverter designs on LCD-TV integrated power boards. Meanwhile the UBA2072 is designed to operate over a wide low voltage inverter supply, ranging from 9V up to 30V, matching the requirements of larger LCD monitors LIPS structures and classical 24V supplied LCD-TV backlight inverters.
"With the falling cost of LCD televisions, consumers are choosing increasingly larger LCD TVs, which require greater amounts of backlight power. This drives up the power requirements and cost of the LCD-TV power supply" said Kees Schetters, marketing director, NXP SEMICONDUCTORS. "In addition, the LCD-TV market is extremely competitive, requiring an ever present focus on driving system cost down. One of the areas where large cost savings can be made is within the power management domain of an LCD-TV. This is achieved by moving from traditionally panel integrated 24V inverter solutions to, set-level LCD-TV Integrated Power Supply Boards containing both the LCD-TV power supply as well as a high voltage supplied backlight inverter. This solution serves two goals as it increases the overall power EFFICIENCY of an LCD-TV, and also drives down the total LCD-TV power management cost."
The end application of the UBA2074 is full-bridge high-voltage and medium-voltage LCD-TV fluorescent lamp, CCFL/EEFL, backlight inverters. The UBA2074A, without hard switching protection, is targeted at 60V full-bridge, medium-voltage backlight applications, while the UBA2074, with hard switching protection has its focus on 155V to 400V full-bridge, high-voltage backlight applications. The UBA2072 is very similar to the UBA2074, with the main difference that it has been designed specifically for a low voltage full bridge application limited to 30V, says the company.
全部回复(13)
ken702
哦,附件为UBA2074的datasheet.听说PHILIPS现在新出了一颗半桥 的高压驱动INVERTER IC,UBA2071,谁有它的DATASHEET拿出来分享一下吧. 2633011213846237.pdf
ken702
UBA2074的DATASHEET.听说philips (NXP)现在新出了一颗半桥的高压inverter芯片,哪位兄弟有它的资料,可以拿出来分享一下吗?
2633011213846796.pdf
ken702
@ken702
UBA2074的DATASHEET.听说philips(NXP)现在新出了一颗半桥的高压inverter芯片,哪位兄弟有它的资料,可以拿出来分享一下吗?2633011213846796.pdf
这周终于有机会见到并测试了一下NXP的高压方案.感觉还不错,主要是板子上面竟然没有散热片,就可以做到220W.还有其它兄弟有用过的吗?分享一下高压inverter方面的经验.
@ken702
專門負責NXP Microsemi INverter方案推廣
有興趣聯絡
luxiaoyongde@126.com
zhanglin
@電源傻子
專門負責NXPMicrosemiINverter方案推廣有興趣聯絡luxiaoyongde@126.com
您好,我司是松木电机(MATSUKI)的中国区代理.松木强势推出 ME4542  ME4544,品质优,价格低,性价比高.可完全替代AO4606 AO4604.松木是专业生产贴片MOS管的厂商,在MOS领域拥有150多项专利.产品广泛应用在笔记本主机板 便携式DVD 高压条(inverter) LCD/PDP电源.
        深圳市胜家科技有限公司
        业务代表:张   林
        0755-21562187
micro-obm
@ken702
板子上面没有散热片,就可以做到220W?220W相当于42寸LCDTV的整机功耗,就算你是移相全桥或者LLC,也不可能没有散热片啊?
@micro-obm
我们公司一直和飞利蒲合作,他们的LCD和高压INVERTER方案我都了解.
LLC用的是TEA1601  反激用是TEA1533 变压器 共模电感都是自己开的模.
业内已有很多家都开始用他们的变压器.
雁单飞
@電源傻子
这里所谓的高压,就是用24V直接输入是吧?可以做到220V直接输入吗?有没有相关的电路图发一份参考一下!leesy737@163.com
@雁单飞
不是的.哥們
是取PFC 的400V
cq_hyb
@ken702
能把实物登上来看下吗?
没散热片  可能么? 220W呢 PFC也不要散热片?
是真的话就牛,否则就是吹牛吧
mamsung
@電源傻子
不是的.哥們是取PFC的400V
顶一把!!!!
  铭城光华科技有限公司是一家集方案开发,产品设计和元器件供应为一体的综合性企业.公司下设技术开发中心,组建专业工程师队伍,专注国际照明领域的最新动态和发展,研究和吸收最新照明技术,推广环保节能的照明工程.先后设计并推出单一芯片驱动的一体化紧凑型荧光灯(CFL)、高压气体放电灯(HID)、可调光荧光灯电子镇流器系列解决方案,相关产品广泛应用于民用,商用,车用以及特种照明领域.
  “专业、专注、专心”的企业精神铸造铭城光华科技的今日品牌!自公司成立以来,我们得到NXP(PHILIPS) ,INFINEON, ST,IR ,ATMEL等知名品牌半导体厂商和通路商的鼎力支持,并始终坚持以优质产品配合卓越完善的技术服务,以满足客户需求为企业未来发展的最高目标.欢迎国内外同行和客户莅临指导合作!以下是目前我司致力推介方案:
*NXP(PHILIPS)半导体系列照明驱动芯片
UBA2014T(P): 600 V driver IC for HF fluorescent lamps 荧光灯可调光电子镇流器
UBA2021T(P): Half-bridge power IC for CFL lamps 节能灯驱动IC
UBA2024P : Half-bridge power IC for CFL lamps 内置MOS节能灯驱动IC
UBA2030T : Full bridge driver IC for HID全桥驱动
UBA2032T(TS): Full bridge driver IC for HID全桥驱动
UBA2033TS : Full bridge driver IC for HID全桥驱动
UBA2035TS : HF Full-bridge control IC for HID lighting 商用全桥驱动
UBA2036TS : Full-bridge control IC for HID automotive lighting 高级车用全桥驱动
UBA2037T(TS) : Full-bridge control IC for HID automotive lighting 全桥驱动
UBA2070T(P) : 600 V CCFL ballast driver IC for CCFL backlighting LCD 背光驱动
UBA2071T(TS) : Full bridge control IC for. CCFL backlighting LCD 背光驱动
UBA2072T(TS) : Full bridge control IC for. CCFL backlighting LCD 背光驱动!
*NXP(PHILIPS)半导体系列快恢复二极管
BYC8-600 : Rectifier diode ultrafast, 超快恢复19ns,8A/600V TO220
BYC8X-600 : Rectifier diode ultrafast, 超快恢复19ns,8A/600V TO220F
BYC10-600 : Rectifier diode ultrafast, 超快恢复19ns,10A/600V TO220
BYC10X-600 : Rectifier diode ultrafast, 超快恢复19ns,10A/600V TO220F
BYV29-600 : Rectifier diode ultrafast, 超快恢复60ns,9A/600V TO220
BYV29X-600 : Rectifier diode ultrafast, 超快恢复55ns,9A/600V TO220F
BYT79-600: Rectifier diode ultrafast, 超快恢复60ns,16A/600V TO220
BYC15-600:Rectifier diode ultrafast, 超快恢复 19ns,15A/600V TO220
BYQ28E-200:Rectifier diode ultrafast, 超快恢复 25ns,10A/200V TO220
BYQ30E-200:Rectifier diode ultrafast, 超快恢复 25ns,15A/200V TO220
BYV32E-200:Rectifier diode ultrafast, 超快恢复 25ns,20A/200V TO220
BYV72EW-200:Rectifier diode ultrafast, 超快恢复 28ns,30A/200V TO247
*NXP(PHILIPS)半导体MOSFET:
PSMN010-55D : 75A 55V 10.5毫欧 125W TO252 , 电源MOSFET
PSMN015-100B :75A 100V 15毫欧 300W D2PAK(TO263) ,电源 MOSFET
PSMN015-100P :75A 100V 15毫欧 300W TO220 , 电源MOSFET
PSMN015-110P :75A 110V 15毫欧 300W TO220 , 电源MOSFET
PSMN009-100P :75A 100V 9毫欧 300W TO220 ,电源 MOSFET
PHP45NQ10T : 47A 100V 25毫欧 150W TO220 ,电源MOSFET
*NXP(PHILIPS)其它主推产品:
TDA1308T:Class AB stereo headphone driver  耳机专用功放芯片 SOP8
UDA1330ATS:Low-cost stereo filter DAC多媒体音频数字/模拟转换器 SSOP16
UDA1341TS:Low-cost stereo filter DAC多媒体音频数字/模拟转换器 SSOP28
PDIUSBD12D:USB interface device with parallel bus USB接口芯片 SOP28
PDIUSBD12PW:USB interface device with parallel bus USB接口芯片 SSOP28
*INFINEON英飞凌半导体:
ICB1FL02G : 荧光灯,大功率节能灯电子镇流器控制芯片 SOP18
TDA4863-2G :PFC 功率因数校正集成电路 SOP8
ICE3B0565J:COOLSET,小功率充电器应用12W-20W DIP8
TDK5110(F):汽车胎压检测项目,发射集成电路TSSOP10/TSSOP16
SPA06N80C3: COOLMOS 6A 800V 0.9欧 39W TO220F
SPP04N80C3: COOLMOS 4A 800V 1.3欧 63W TO220
IDD06E60 : 快恢复二极管 6A 600V 50ns DPAK(TO252)
IHW20N120R2 :20A 1200V 330W TO247  电磁炉专用单管IGBT
IHW25N120R2 :25A 1200V 365W TO247  电磁炉专用单管IGBT
IHW30N120R2 :30A 1200V 412W TO247  电磁炉专用单管IGBT
*STM意法半导体:
L6561D : PFC 功率因数校正集成电路 SOP8/DIP8
L6562D : PFC 功率因数校正集成电路 SOP8/DIP8
L6574D : 电子镇流器控制驱动集成电路 SOP16/DIP16
TDA7297SA:10W+10W DUAL BRIDGE AMPLIFIER 音频功率放大器
*IR国际整流器公司:
IRS2453DSPBF : Full bridge driver IC for HID全桥驱动
IR2520DSPBF : CFL镇流器控制集成电路
IRF7832TRPBF : 20A 30V 4.0毫欧 SOP8 低压 MOSFET
IRF7805TRPBF : 16A 30V 6.8毫欧 SOP8 低压 MOSFET
*ADI模拟器件公司:
ADXRS150ABG : 角速度转感器 航模产品专用
ADXRS401ABG : 角速度转感器 航模产品专用
ADXRS610BBGZ: 角速度转感器 航模产品专用
*其它产品:
LM2940T-9.0:三端稳压管,1A /9V  TO220
TLC2272CP: 双路,低噪声,满电源幅度高电压运放 DIP8
6N138: 高倍率达灵顿光藕合IC DIP8
6N139: 高倍率达灵顿光藕合IC DIP8
相应方案的应用及元器件供应事宜,请联络我们的客服代表.
服务专线:TEL:+86-755-8301 4048(四线),FAX:+86-755-8301 4248
HTTP://WWW.MAMSUNG.COM   E-mail:msgwu@hotmail.com  QQ:564592456
地址:中国深圳市 福田区振中路 鼎诚大厦 南座25楼
ken702
@micro-obm
sorry. 文章中所指的是:inverter部分没有散热片.因为我只有inverter的板子.PFC当然要用heat sinker.
药师佛
@ken702
哦,附件为UBA2074的datasheet.听说PHILIPS现在新出了一颗半桥的高压驱动INVERTERIC,UBA2071,谁有它的DATASHEET拿出来分享一下吧.2633011213846237.pdf
关于UBA2074我的看法:
1.IC本身价格高,又是全桥架构成本更高,现在的高压LIPS都用半桥方案
2.适合做EEFL背光并联点灯,不适合做CCFL,不用平衡电感你的电流平衡不好控制
