我做的两个双变自激J
在坛子看到有朋友说双变J好,一动心,自己做了两个.
超薄J:3对15A PNP功放管,EE42主变;0.5*5-3+3T,0.75-85T;EE10副变:0.5*2-30T,0.75-30T/30T.高度只有2包香烟左右.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213878534.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213878931.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
直带100W灯:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213879075.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
大个J: 4对15A NPN功放管,EE55主变;1.0*3-3+3T,0.5*2-100T;EE42副变:0.5*2-30T,0.75-30T/30T.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213879275.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213879375.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
直带200W灯泡:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213879528.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
目前在城市呆,没有地方电鱼所以没有装后级.
全部回复(48)
liuyi2468
请问,能发个图吗,还有第一个哪个二极管有什么作用的啊,能上个图吗
@liuyi2468
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213884506.jpg');}" onmousewheel="return imgzoom(this);">
就这图,只是元件有些变动.二极管是反并在三极管的C---E脚的,防止初级自感浪涌电流将功率管击穿,起旁通作用,此旁通电流还同时对蓄电池充电,边消耗边充电.一般朋友都好象没有这个设计,他们烧管没有我不知道,刚开始烧了4个管我才意识到可能E---C极反向电压过高.接了二极管就没有烧管了.
@liuyi2468
你眼光锐利啊!真正的精华被你看到了.
@11455355
你眼光锐利啊!真正的精华被你看到了.
这个二极管最好用高频整流管,如304,305
liuyi2468
@11455355
做的漂亮啊,能不能把哪二级管的并法画个图了,
还有EE55怎么不搞个500W以上的啊
@liuyi2468
做的漂亮啊,能不能把哪二级管的并法画个图了,还有EE55怎么不搞个500W以上的啊
二极管我用的是FR305
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/2452941213887128.jpg');}" onmousewheel="return imgzoom(this);">
liuyi2468
@11455355
二极管我用的是FR305[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/66/2452941213887128.jpg');}"onmousewheel="returnimgzoom(this);">
谢谢,EE55怎么才搞200W左右, 怎么不搞大点,直接加管会加大功率吧
@liuyi2468
我没有绕太多线,别看EE55外面是很饱满,其实里面绝缘层很厚,为了好看.
@liuyi2468
谢谢,EE55怎么才搞200W左右,怎么不搞大点,直接加管会加大功率吧
加粗初级线圈罗.
ya1678
@11455355
R1  你用了多少欧的电阻
豆芽菜
@ya1678
R1  你用了多少欧的电阻
这个双变能用场管吗?要不要变动?
xuling
@虾鬼
画错了  改:[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/66/1691251214020349.jpg');}"onmousewheel="returnimgzoom(this);">
继电器后极声音很大
@ya1678
R1  你用了多少欧的电阻
我用的启动电阻是1K,要根据管子的型号和数量来定的.过大不起震,过小会有较大直流一直在一边半桥电路中效率不高.
@豆芽菜
这个双变能用场管吗?要不要变动?
场管自激我还没有做过,我不看好.MOS太娇气了,弄不好"砰砰"声炸管.
@虾鬼
请问虾鬼先生:这继电器后级你用过没有.会否烧触点,告知我效果,如果好我也这样做,手头有12V20A,12V25A的继电器.
胜仔
@11455355
好东西
虾鬼
@11455355
0.1U是消点电用
虾鬼
@虾鬼
0.1U是消点电用
听说R1去掉后会加大功率     我没式过
liuyi2468
@虾鬼
听说R1去掉后会加大功率    我没式过
R1是起动电阻,去掉能起振吗?
飞飞鱼
@11455355
这个电路不适合,用555做推动继电器
飞飞鱼
管子用什么型号的?
@飞飞鱼
管子用什么型号的?
我用的是东芝功放对管,JJ在公司,我不记得型号,其实双变JJ门槛低,几乎只要是三极管就行.
虾鬼
@11455355
画错了  改:500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/1691251214020349.jpg');}" onmousewheel="return imgzoom(this);">
虾鬼
@虾鬼
我花了点时间把图画出来了500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/66/1691251214053372.jpg');}" onmousewheel="return imgzoom(this);">
pengqizhen
@11455355
请问大家的双变有没有啸叫现象,我做了一个啸叫很大声.我的主变初级(0.1*20)双线绕6T+6T.次级180T.副变0.6*30T.   1.0*20T+1.0*20T.是不是频率太高了?
liuyi2468
@pengqizhen
主变初改5+5就不会叫了
huangbinw
@liuyi2468
主变初改5+5就不会叫了
是频率太底了才叫的,还有变压器不能留气缝,要把变压器粘好,这样声音就小了
@飞飞鱼
管子用什么型号的?
超薄JJ用的是东芝2SA1943,大个J用的是:东芝2SC5200;他们其实就是功放配对管,前者PNP,后者NPN型.在同一功放上拆的.
pengqizhen
2008-06-22 20:52
@huangbinw
感谢大家!变压器是不留气缝的,今天浸了油声音明显减小了.刚又换了主变(0.08线*100)*3T*2.副变不变,6对3DD15,100W灯烧了.我想把副边改一下,改为初级(1.0*2)*6T*2次级1.0*30这样会提高频率吗?
虾鬼
2008-06-23 12:42
@11455355
