贴片电阻是怎么分类的?
贴片电阻怎么识别?比如说0805怎么跟1206去区分?
全部回复(7)
電阻不管 0603, 0805 , 1206其實大多用英制去算, 若用公制那就好算多了.....
1000mil = 25.4mm , 所以 1mm = 39.37mil
0603為長 60mil, 寬 30mil 所以長 60mil / 39.37 = 1.52mm 寬30mil / 39.37 = 0.76mm
0805為長 80mil, 寬 50mil 所以長 80mil / 39.37 = 2.03mm 寬50mil / 39.37 = 1.27mm
1206為長 120mil 寬 60mil 所以長 120mil/ 39.37 = 3.04mm 寬60mil /39.37 = 1.52mm
以此類推.......................................
@juntion
電阻不管0603,0805,1206其實大多用英制去算,若用公制那就好算多了.....1000mil=25.4mm,所以1mm=39.37mil 0603為長60mil,寬30mil所以長60mil/39.37=1.52mm寬30mil/39.37=0.76mm0805為長80mil,寬50mil所以長80mil/39.37=2.03mm寬50mil/39.37=1.27mm1206為長120mil寬60mil所以長120mil/39.37=3.04mm寬60mil/39.37=1.52mm以此類推.......................................
0603 0805 1206已经是英寸了
所以换算为mm应当分别是 1608 2012 3216
直接乘2.54
@juntion
谢谢
精华推荐 换一换
