电量管理 BQ2063 附配置数据
自放电 内部电路放电均设置为0.充电到RM=设计容量后放置.发现RM值逐渐减少!!大约每小时3mAH.
   配置好EEPROM之后,没学习,只是把电充满.
全部回复(5)
msc51
大约20多分钟 减少1mAH. 读电流为0,应该不是采电流不准造成的.
配置数据如下:
0x7F,//0x00//Check Byte
0x3C,
0x0A,//0x02//Remaining Time Alarm
0x00,
0x90,//0x04//Remaining Capacity Alarm
0x01,
0x00,//0x06//EDV A0 Impedance Age Factor
0x00,//0x07//EDV TC Cold Impedance Factor
0xC3,//0x08//Misc Options
0x00,//0x09//Safety Overtemperature
0x38,//0x0a//Charging Voltage
0x31,
0x80,//0x0c//Reserved
0x00,
0x00,//0x0e//Cycle Count
0x00,
0x00,//0x10//Reserved
0x00,
0x30,//0x12//Design Voltage
0x2A,
0x21,//0x14//Specification Information
0x00,
0xAC,//0x16//Manufacture Data
0x38,
0x01,//0x18//Serial Number
0x00,
0xB8,//0x1a//Fast_Charging Current
0x0B,
0x00,//0x1c//Maintenance Charging Current
0x00,
0x0C,//0x1e//Pre_Charge Current
0x8C,
0x0A,//0x20//Manufacturer Name Length
0x4A,//0x21//Character 1
0x4A,//0x22//Character 2
0x4B,//0x23//Character 3
0x4A,//0x24//Character 4
0x4B,//0x25//Character 5
0x4A,//0x26//Character 6
0x5A,//0x27//Character 7
0x5A,//0x28//Character 8
0x4A,//0x29//Character 9
0x4A,//0x2a//Character 10
0x00,//0x2b//Character 11
0x00,//0x2c//Reserved
0x00,
0xA2,//0x2e//Maximum Overcharge
0xFE,
0x06,//0x30//Device Name Length
0x42,//0x31//Character 1
0x42,//0x32//Character 2
0x32,//0x33//Character 3
0x42,//0x34//Character 4
0x42,//0x35//Character 5
0x32,//0x36//Character 6
0x00,//0x37//Character 7
0x88,//0x38//Last measured Discharge
0x13,
0x88,//0x3a//Pack Capacity
0x13,
0xa0,//0x3c//cycle Count Threshold
0x0f,
0x00,//0x3e//Reserved
0xA2,//0x3f//Pack Configuration
0x04,//0x40//Device Chemistry Length
0x4C,//0x41//Character 1
0x49,//0x42//Character 2
0x4F,//0x43//Character 3
0x4E,//0x44//Character 4
0xC6,//0x45//MaxT DeltaT
0x70,//0x46//Overload Current
0x17,
0x32,//0x48//Overvoltage Margin
0x20,//0x49//OverCurrent Margin
0x79,//0x4a//Cell Under\Over Voltage
0xFF,//0x4b//Fast Charge Termination%
0xA1,//0x4c//Fully Charged Clear%
0xFF,//0x4d//Charge Efficiency
0x0A,//0x4e//Current Taper Threshold
0x40,//0x4f//Current Taper Qual Voltage
0x07,//0x50//manufacturers Data Length
0x05,//0x51//control Mode
0x2d,//0x52//Digital Filter
0x00,//0x53//Self_Discharge Rate
0x12,//0x54//Battery Low%
0x64,//0x55//Near Full
0x00,//0x56//Reserved
0x00,
0x00,//0x58//Reserved
0x00,
0x00,//0x5a//Reserved
0x00,
0x00,//0x5c//Reserved
0x00,
0x00,//0x5e//VFC Offset
0x00,
0x00,//0x60//VFC Offset
0x00,//0x61//Temperature Offset
0x00,//0x62//ADC Offset
0x01,//0x63//Cell 2 Calibration Factor
0x00,//0x64//Cell 3 Calibration Factor
0x00,//0x65//Cell 3 Calibration Factor
0xD4,//0x66//ADC Voltage Gain
0x30,//
0x61,//0x68//ADC Sense Resistor Gain//0x30d4?
0x51,
0x55,//0x6a//VFC Sense Resistor Gain//0x2000?
0x35,
0x5E,//0x6c//VOC 25%
0xD4,
0x96,//0x6e//VOC 50%
0xD3,
0x2E,//0x70//VOC 75%
0xD2,
0xB8,//0x72//EDVF\EDV0
0x0B,
0x69,//0x74//EMFI\EDV1
0x0D,
0x00,//0x76//EDV T0 Factor
0x00,
0xEF,//0x78//EDV C1\C0 Factor\EDV2
0x0D,
0xE0,//0x7a//EDV R0 Factor
0x00,
0x00,//0x7c//EDV R1 Factor
0x00,
0x5A,//0x7e//Check Byte 2
0xA5,
msc51
从昨天晚上9点半到今天早晨8点半,RM又降了29mAH.
有人能给解释一下么?
msc51
有人能解释一下么?
msc51
电量减少比较有规律,大约20多分钟肯定变一次!!
这样应该不是自放电引起的!!
msc51
查到原因了!!修改EEPROM之后重新上电初始化!!
不过新问题是,充满 之后放电到EDV2以下,RELEARN_FLAG没有清零.
