IP2716 快充协议芯片, 目前市面上兼容性最全的快充协议芯片
IP2716 样品,评估板咨询电话 13828760986 赵工 微信同, 可以支持客户全面解决快充设计到的技术问题。
IP2716的Feature 性能参数:
1. 集成TYPE-C DRP protocol 协议 Auto detect TYPE-C device plug in or plug out Auto detect the capability of the sink and the source
2. USB Power Delivery(PD3.0) Hardware BMC transmitter and receiver Full feature physical layer Hardware CRC protect the data integrity Integrate PD3.0 protocol engine
3. 支持 E-MARK cable Support VCONN swap Hardware reset
3. 集成Integrate QC3.0/2.0 Quick charge protocol QC3.0/2.0 High voltage output protocol CLASS A and CLASS B Including BC1.2/APPLE/SUMSAMG charging protocol Provide feedback voltage to adjust the output voltage dynamically
4 Support支持 MTK PE+1.1 Fast charging technology Power Manage Build in VCONN power path switch External P-MOSFET switch control
5. 内置 ADC to monitor the current of the external MOSFET 内置电源路径管理.
6. Power supply by VBUS or battery Support application with no battery supply ADC Build 14bit ADC Monitoring Voltage and current of VBUS Monitoring Voltage of the battery Monitoring Voltage of the VCONN Support 3 general ADC input Peripheral interface SPI、I2C、UART、PWM、GPIOs
7. 低功耗 待机电流少于 100uA
8. 封装 Package 5 mm × 5 mm QFN32 Applications 应用包括 AC power Adapter电源适配器 for cellphone, notebook, tablet, 虚拟现实眼镜 box, , robot 机器人, Power-Bank 移动电源快充 Car charger 车充
9. IP2716 is a highly-integrated, flexible high voltage charging protocol controller. It supports the most popular high voltage高压充电协议 charging protocol.
10. 特别支持 PD3 Such as TYPE-C PD3.0, QC3.0, MTK PE+1.1, DCP, BC1.2 etc. The SOC could be a powerful protocol controller used in AC adapter, power-bank, Car charger or other power charging solution.
是目前支持PD 3 的最全的协议芯片
