如何设计高频变压器??
要做一个开关电源,是低压(44V-60V)输入,我的输出要求多路的,有5V/0.3A,+12V/0.1A,-12V/0.1A,+15V/0.3A,+12V/1A,用UC3842控制,开关频率选用40K,效率0.85,占空比最大0.45,请问如何设计高频变压器啊??
全部回复(9)
设计如下:
Po=5*3+12*0.1+12*0.1+15*0.3+12*1=33.9W
Pi=33.9/0.85=39.9W EE25/19,DMR40,TP4,PC40,3C90 Ae=40mm2,ΔB=0.2T
Np=(0.45*44)/(40*0.2*40*10-3)=61.9 Turns Np=62
Ns1=(5*0.55*62)/(44*0.45)=8.6 Turns Ns1=9
Ns2=Ns3=N5=(12*0.55*62)/(44*0.45)=20.7 Turns Ns2=Ns3=N5=21
Ns4=(15*0.55*62)/(44*0.45)=25.8 Turns Ns4=26
Δ=7.65/200=0.038cm=0.38mm Dwire=0.72mm 21#AWG,Swire=0.41mm2.
Iin=39.9/44=0.91A Din=0.54mm 24#AWG
Dsec1=0.32mm 28#AWG
Dsec2=Dsec3 33#AWG
Dsec4=0.32mm 28#AWG
Dsec5=0.56mm 24#AWG
Dsec1=0.32mm 28#AWG
Dsec2=Dsec3 33#AWG
Dsec4=0.32mm 28#AWG
Dsec5=0.56mm 24#AWG
@greenmantis
设计如下:Po=5*3+12*0.1+12*0.1+15*0.3+12*1=33.9WPi=33.9/0.85=39.9W EE25/19,DMR40,TP4,PC40,3C90 Ae=40mm2,ΔB=0.2TNp=(0.45*44)/(40*0.2*40*10-3)=61.9Turns Np=62Ns1=(5*0.55*62)/(44*0.45)=8.6Turns Ns1=9Ns2=Ns3=N5=(12*0.55*62)/(44*0.45)=20.7Turns Ns2=Ns3=N5=21Ns4=(15*0.55*62)/(44*0.45)=25.8Turns Ns4=26Δ=7.65/200=0.038cm=0.38mm Dwire=0.72mm 21#AWG,Swire=0.41mm2.Iin=39.9/44=0.91A Din=0.54mm 24#AWGDsec1=0.32mm 28#AWGDsec2=Dsec3 33#AWGDsec4=0.32mm 28#AWGDsec5=0.56mm 24#AWG
多谢你的分析计算过程,但是有个参数你看错了,是5V/0.3A
@greenmantis
另外能给出有输出功率到磁芯选择的依据吗,我看好多论文的公式不太一样啊!
@greenmantis
现在我改变一下参数:输出,5V/0.5A,+15V/0.15A,-15V/0.15A,+15V/0.3A,+12V/1A;反馈13V/0.05A.用UC3842控制,开关频率选用40K,效率0.85,占空比最大0.45,电路图如图
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/74/2678911235136460.jpg');}" onmousewheel="return imgzoom(this);">
按照你给的公式计算:
Po=5*0.5+15*0.15+15*0.15+15*0.3+12*1+13×0.05=24.15W
Pi=24.15/0.85=28.4,取Pi=30W,根据经验公式磁芯截面积Ae=0.15*Pi(0.5)=0.82cm2选用什么磁芯好??EE28×33.6×10.7,Ae=87.2mm2,这个可否,还是选EE30×26.4×10.7,Ae=109mm2
![](http://u.dianyuan.com/bbs/u/74/2678911235136460.jpg?x-oss-process=image/format,webp)
按照你给的公式计算:
@londonz
现在我改变一下参数:输出,5V/0.5A,+15V/0.15A,-15V/0.15A,+15V/0.3A,+12V/1A;反馈13V/0.05A.用UC3842控制,开关频率选用40K,效率0.85,占空比最大0.45,电路图如图[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/74/2678911235136460.jpg');}"onmousewheel="returnimgzoom(this);">按照你给的公式计算:Po=5*0.5+15*0.15+15*0.15+15*0.3+12*1+13×0.05=24.15WPi=24.15/0.85=28.4,取Pi=30W,根据经验公式磁芯截面积Ae=0.15*Pi(0.5)=0.82cm2选用什么磁芯好??EE28×33.6×10.7,Ae=87.2mm2,这个可否,还是选EE30×26.4×10.7,Ae=109mm2
EE28即可
